2003 ZTS - horrible gas mileage - 16.3mpg - HELP - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-28-2012, 02:54 PM   #1
PWGuy
Fan#: 91777
What I Drive: 2003 Pitch Black ZTS Sedan
Points 2,131, Level 27
Points: 2,131, Level: 27 Points: 2,131, Level: 27 Points: 2,131, Level: 27
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 PWGuy Good Standing Member
Question 2003 ZTS - horrible gas mileage - 16.3mpg - HELP
I know this thread pops up ALOT around here but I am at a complete loss as to why I'm getting such horrific gas mileage (just filled up - 16.3mpg achieved in last tank) over the last couple months.
I got the car in November 2011 from my father-in-law. I think the mpg at that time was about 23-25 highway or so - definitely room for improvement. Oh, the car is running on stock rims with stock tire size but Blizzaks for tires as it is more of a winter car or for bopping around town. Last I checked the tire pressure was up pretty high - can't recall exact figure at the moment.
Since November 2011 I've replaced:
Fuel Filter (Motorcraft)
PCV Valve (Motorcraft)
PCV Hose Elbow (Motorcraft)
PCV Valve Hose - Exhaust (Motorcraft)
PCV Vavle Hose - Intake (Motorcraft)
Thermostat Housing and O-Ring (Motorcraft)
Thermostat (Motorcraft)
Valve Cover Gasket (Motorcraft)
Air box - mine was cracked (Motorcraft)
Air Filter - K&N
Upper/Front O2 Sensor (Motorcraft)
Spark Plugs (Motorcraft SP-478 - platinum)
Spark Plug Wires (Motorcraft WR-5974)
Other:
  • Cleaned the MAF a few months after installing the K&N
  • Replaced power steering fluid with ATF Mercon V (won't affect mpg)
Considering:
  • Cleaning IAC to help with idle issues with A/C
  • Tranny fluid flush & filter change (won't affect mpg)
  • Seafoam
I'm not sure when the gas mileage began to drop from 23ish to 16 - maybe the last 3-4 months?
I'm not sure what else to do and am really frustrated.
PWGuy is offline
Old 08-28-2012, 02:56 PM   #2
MEJY1988
Fan#: 101883
What I Drive: 2006 Burgandy ZX5
Points 160, Level 3
Points: 160, Level: 3 Points: 160, Level: 3 Points: 160, Level: 3
Level Up 20% Completed
FF Reputation: 3 MEJY1988 Good Standing Member
Tune-up?
I was a Shade Tree Mechanic, but had to cut down the Shade Tree to make room for the garage. Does this make me a Mechanic now?
MEJY1988 is offline
Old 08-28-2012, 02:58 PM   #3
Wagone
Fan#: 100532
What I Drive: 2003 Wagon SE MTX
Points 430, Level 8
Points: 430, Level: 8 Points: 430, Level: 8 Points: 430, Level: 8
Level Up 60% Completed
FF Reputation: 1 Wagone Good Standing Member
Exhaust or cat restriction?
WaGone
2003 2.3 MTX Wagon
Wagone is offline
Old 08-28-2012, 03:17 PM   #4
PWGuy
Fan#: 91777
Originally Posted by MEJY1988 View Post
Tune-up?
What would consist of a "tune-up" that I haven't already performed??
PWGuy is offline
Old 08-28-2012, 03:20 PM   #5
MEJY1988
Fan#: 101883
Points 160, Level 3
Sorry, over looked plugs and wires.
MEJY1988 is offline
Old 08-28-2012, 03:29 PM   #6
PWGuy
Fan#: 91777
Oh, I gapped the plugs to .52, btw
PWGuy is offline
Old 08-28-2012, 03:33 PM   #7
PWGuy
Fan#: 91777
Is there a way to tell without taking the cat and/or exhaust apart?
PWGuy is offline
Old 08-28-2012, 04:29 PM   #8
PWGuy
Fan#: 91777
Could it be a problematic fuel pump? I hesitate to call it "bad" since I guess it is working?
PWGuy is offline
Old 08-28-2012, 04:48 PM   #9
PWGuy
Fan#: 91777
Ok after some reading/research, I realized that when I did the spark plugs and spark plug wire change, I didn't remove the negative battery terminal, thus the computer may never have reset with the new plugs. I'm doing that now and cleaning off the oxidized battery terminal and post.
Will report back in a few days or so to see if it helps..
PWGuy is offline
Old 08-28-2012, 04:50 PM   #10
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
Points 25,851, Level 96
Points: 25,851, Level: 96 Points: 25,851, Level: 96 Points: 25,851, Level: 96
Level Up 51% Completed
Level up: 51% Level up: 51% Level up: 51%
FF Reputation: 47 DrkKnight614 Great Standing Member
Posted via FF Mobile Hmm, in the beginning years of my car thats pretty much what I was getting, no matter what I did. Let my car break in, nothing changed, blah blah blah. Finally after I Seafoamed the thing with some friends, mileage went up. I'm sure you've unhooked the battery and reset the ecu sometime during all those replacement parts...if not do it. Tranny flush may gery well fix the issue, if its not working properly it'll suck up your mileage greatly for sure. Id say clean the IAC if you are having idle issue, if you think you are having trans issues or it has a lot of miles do that next, if not do seafoam. If that doesnt work do trans work. If NOTHING WORKS, go back and check everything. Such as, did you clean your MAF before or after the K&N, excessive oil from a new filter can guck up the sensor. Did you use any fuel cleaner after u put in the fuel filter. Well diesnt matter because if you seafoam you'll want to replace your fuel filter anyway. Whatever the seafoam frees up will get clogged in it, but go thru your entire gas in the tank first. Good luck
DrkKnight614 is offline
