alternator changed = still problems - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-28-2012, 11:59 PM   #11
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,585, Level 100
Points: 138,585, Level: 100 Points: 138,585, Level: 100 Points: 138,585, Level: 100
Level Up 0% Completed
Forum Activity 59%
Activity: 59% Activity: 59% Activity: 59%
Buy-Sell-Trade Rating: (11)
I live in Rosenberg or next town past Sugar Land on the south west side.
Your battery is good right?
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 08-29-2012, 08:48 AM   #12
FLYLOW
FLYLOW's Avatar
Fan#: 34077
What I Drive: Gen Coupe Rspec
FF Reputation: 4 FLYLOW Good Standing Member
Buy-Sell-Trade Rating: (7)
Bat is brand new.
Did a quick check last night. All the wires seam to be good! All are connected.
787-431-2257 is my #. text me when u see this. U can swing by anytime
FLYLOW is offline
Old 08-29-2012, 09:33 AM   #13
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 59%
They may be connected well but the wires may be burnt up or not even making a good connection. If you have a voltmeter measure the positive side terminal at the alternator and see if your getting voltage from the battery there. Sending you a PM
Moderator for
Technical Chat
Old 08-30-2012, 09:07 AM   #14
birdman_a15
birdman_a15's Avatar
Fan#: 75473
What I Drive: 2003 Red SVT Focus ZX5
FF Reputation: 1 birdman_a15 Good Standing Member
Sounds like a grounding issue to me.
birdman_a15 is offline
Old 08-30-2012, 12:25 PM   #15
FLYLOW
FLYLOW's Avatar
Fan#: 34077
thanks sleepy for all the suggestions and thanks everyone
checked all the wires today, ripped off the flexible plastic cover on almost all the lines, none seemed damaged. checked all the fuses, fuse box and wires = nothing. the new alt is grounded correctly, took the pigtail out and cleaned it. also took the bat to ford yest under warranty. they said it was good just need charging. so they charged/reset it or whatever it is they do to it and car started this morning but same problems. now the instr cluster is all crazy. radio works, ac works, horn works.
also the bat water was boiling/bubbling after starting the car for like 20 seconds. took the caps off and water rushed out sprayed in my hands and face
maybe i was delivered the wrong alt?
FLYLOW is offline
Old 09-02-2012, 03:24 PM   #16
FLYLOW
FLYLOW's Avatar
Fan#: 34077
bump? any one? :(
took the car back to the shop, theyve tested a bunch a stuff still dont know what it is. Car was left over night and batt was drained empty once again.
me needs my car running :(
FLYLOW is offline
Old 09-02-2012, 03:32 PM   #17
MEJY1988
Fan#: 101883
What I Drive: 2006 Burgandy ZX5
Points 160, Level 3
Points: 160, Level: 3 Points: 160, Level: 3 Points: 160, Level: 3
Level Up 20% Completed
FF Reputation: 3 MEJY1988 Good Standing Member
Sounds like the voltage regulator, part of alternator, is defective. Did you check voltage at the battery with the car running? Have the alternator tested, may have to remove. Do not run the car if it is causing the acid to boil. This is usually an over-voltage problem. Check the voltage on your battery. If within specs then it is being over-charged.
I was a Shade Tree Mechanic, but had to cut down the Shade Tree to make room for the garage. Does this make me a Mechanic now?
MEJY1988 is offline
Old 09-02-2012, 03:33 PM   #18
FLYLOW
FLYLOW's Avatar
Fan#: 34077
k thanks! car is locked in the shop, i guess theyll reopen tuesday. Last time i spoke to the guy he said he would pull the alt out for test so i guess hes headed in the right direction.
FLYLOW is offline
Old 09-02-2012, 03:40 PM   #19
MEJY1988
Fan#: 101883
Points 160, Level 3
Just to let you know, in case you don't know already, if you run the car to long with an over-charging situation, it can cause the battery to explode.
MEJY1988 is offline
Old 09-03-2012, 03:59 AM   #20
amc49
Fan#: 96610
Points 3,277, Level 35
Points: 3,277, Level: 35 Points: 3,277, Level: 35 Points: 3,277, Level: 35
Level Up 52% Completed
Forum Activity 12%
The battery won't explode. It will simply boil all the water out.
Depends on how much boiling, instant and spews acid is probably an internally shorted battery, THAT could explode. Instant means it comes out of the vents.
ALL batteries bubble a little bit in normal charging.
On these, if you are running a bad battery and continue trying to charge it up then you generally torch the alternator pretty quick, they don't like that at all. The diodes run hot and the solder points break. Or regulator fails, it's a race.
amc49 is offline
