Bluetooth with MFT and Android 4.0.4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-27-2012, 01:03 AM   #1
MGbox
MGbox's Avatar
Fan#: 87878
What I Drive: 2012 Focus Titanium Hatchback
FF Reputation: 1 MGbox Good Standing Member
Since upgrading my Samsung Galaxy S2 LTE (SGH-I727R) from Android 2.3.4 to 4.0.4 a few months ago I've had trouble keeping my phone connected to the the bluetooth in my car.
Connects fine every start up. But every 2-3 minutes it randomly disconnects which prompts a large pop up on the MFT system saying it's trying to reconnect, which 20-30 seconds later it usually does. This is quite annoying if you're trying to do something else on the system like change radio station or browse music, etc, because it only gives you the option to cancel the attempt to reconnect instead of letting you minimize the popup.
The bluetooth has never dropped during an active call. But if it disconnects as you're approaching someones house and you wanna call to let them know you're here, it's quite annoying and defeats the whole purpose of having bluetooth in a car.
Anyone else experienced this or have a fix? I've searched other android related sites without finding a solution.
My signature was "too long" with all the revised ETAs I've received. Finally took delivery October 7th.
MGbox is offline
Old 08-27-2012, 01:28 AM   #2
oritpro
oritpro's Avatar
Fan#: 96148
What I Drive: 2012 Subaru Impreza Sport Limited
Points 749, Level 14
Points: 749, Level: 14 Points: 749, Level: 14 Points: 749, Level: 14
Level Up 49% Completed
FF Reputation: 2 oritpro Good Standing Member
Yes, this happens to me once in a blue moon but usually corrects itself in a day or two without any action on my part.
I've found a couple of work-arounds though:
1. Turn bluetooth off on your phone for a few seconds, re-enable and it should re-connect automatically. If not, connect through the bluetooth menu on your phone.
2. Reboot phone.
I am running CM9 stable release (Android v4.04).
oritpro is offline
Old 08-27-2012, 01:30 AM   #3
Burns098356GX
Burns098356GX's Avatar
Fan#: 94777
What I Drive: 2013 Focus ST
Points 1,136, Level 18
Points: 1,136, Level: 18 Points: 1,136, Level: 18 Points: 1,136, Level: 18
Level Up 36% Completed
FF Reputation: 1 Burns098356GX Good Standing Member
Have you tried a different phone? I have Droid ICS and have no problems.
Burns098356GX is offline
Old 08-27-2012, 11:04 AM   #4
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Points 3,286, Level 35
Level Up 58% Completed
This is a phone issue not an MFT issue.
See the sticky MFT thread there's a good article on it in one of the last posts.
Basically... the Bluetooth interface the car uses is ubiquitous and allows for almost all compatible Bluetooth devices, in a phone however they use Bluetooth drivers specific to the hardware and sometimes those drivers aren't really tested well or written well, and lead to issues. So when you upgraded to 4.0, the Bluetooth driver probably updated as well, and that's giving you the issue, not the car.
Sonic Crew #28
feta_mgp is offline
Old 08-31-2012, 12:15 PM   #5
FordIVTteam
Official Ford Rep
FordIVTteam's Avatar
Fan#: 87765
What I Drive: Ford Focus
Points 2,216, Level 28
Points: 2,216, Level: 28 Points: 2,216, Level: 28 Points: 2,216, Level: 28
Level Up 44% Completed
Forum Activity 3%
FF Reputation: 3 FordIVTteam Good Standing Member
Hey everyone -
Like, feta_mgp said, this is an issue with the phone and not MyFord Touch. Many Android users have experienced concerns after the recent 4.0 (Ice Cream sandwich) update.
Any time an update is made to your phone or SYNC, we recommend resetting the system and pairing your phone again. Below are instructions for how to perform a Master Reset as well as Reverse Pair your phone. Certain phones hold the best connection when paired this way so I highly suggest giving it a try. Instead of the usual process where your phone finds SYNC, SYNC will find your phone:
http://Support.Ford.com/sync-technol...c-myford-touch
Let me know if this helps or if you have any questions.
Jaclyn
FORD IN-VEHICLE TECHNOLOGY TEAM
p: 800.392.FORD (Prompts 1 then 3)
f: facebook.com/FordFocus facebook.com/Ford
FordIVTteam is offline
Old 08-31-2012, 01:22 PM   #6
pozi240
Fan#: 94835
What I Drive: 2012 Focus 5 door SEL Kona Blue
FF Reputation: 4 pozi240 Good Standing Member
Jaclyns advice is spot on. When I upgraded my Samsung Galaxy Nexus to 4.1 (Jellybean), I had the same issues, I actually called the tech support line and they suggested the above (erasing the phone in Sync and on the device) and pairing the phone from scratch again. Over a month later, it's still working fine in multiple Fords.
2012 Focus SEL 5 door 303a w/Lux pkg in KonaBlue
2012 Escape Limited w/park assist
2010 F150 Supercrew XTR 5.4 4x4
2008 Kawasaki Concours 14 (street)
2008 Kawasaki ZX10R (track only)
pozi240 is offline
Old 09-04-2012, 02:28 PM   #7
FordIVTteam
Official Ford Rep
Fan#: 87765
Forum Activity 3%
Glad to hear it, pozi240, thanks for sharing!
Jaclyn
Old 09-05-2012, 09:06 AM   #8
Burns098356GX
Fan#: 94777
Not to hijack the thread but I'm running android 4.3. Txt messages started showing up on my MFT screen, but after a master reset to the system, they no longer show up. Can I remedy this or change a setting to re-enable this? I rather like that feature.
Old 09-05-2012, 09:30 AM   #9
pozi240
Fan#: 94835
Originally Posted by Burns098356GX View Post
android 4.3.
? 4.0.3 maybe? Most users are on a version of 4.0.4 ICS, only a few devices (officially) are on 4.1 JellyBean, there is nothing above 4.1 ... yet. My wife had text capability on Android 2.3.4 (Gingerbread), upgraded to 4.0.3 IceCreamSandwich and lost that ability, but, just recently upgraded again to version 4.0.4 ICS and got it back again. I don't have the ability on 4.1 JB either.... but that could be the device itself (Galaxy Nexus)
pozi240 is offline
Old 09-05-2012, 11:06 AM   #10
Burns098356GX
Fan#: 94777
Ya 4.0.3, my bad. I've for sure seen the text on the touch screen since updating to ICS. I'm just not sure how I've disabled it.
