Thermostat Housing Leak - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-26-2012, 02:19 PM   #1
AlexCA
Fan#: 102754
What I Drive: 2003 Charcoal Grey ZX3
FF Reputation: 1 AlexCA Good Standing Member
2003 ZX3. 123K miles
I have a really bad thermostat housing leak. I also have a valve cover gasket leak. I want to replace both and some questions.
I plan to use the Dorman 902-201 kit to replace the housing kit. What else should I buy to make the repair? Do I need a coolant sensor?
As far as the gasket - Will an OEM one be okay, os should I get an aftermarket one?
Thanks
AlexCA is offline
Old 08-26-2012, 09:37 PM   #2
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
Originally Posted by AlexCA View Post
I plan to use the Dorman 902-201 kit to replace the housing kit. What else shoulhttp://www.reddit.com/r/programming/submit?url=http%3A%2F%2Fwww.focusfanatics.com%2Fforum%2Fshowthread.php%3Ft%3D296164d I buy to make the repair?
Nothing, providing you have the appropriate metric socket and wrench sizes. Re-use the thermostat.
No. Your car has a engine temp sensor that doesn't contact the coolant directly; it's located at the back of the cylinder head by the alternator. The SVT version of the Zetec engine has the sensor in the T-stat housing.
OEMs are generally superior in terms of fit compared to after market ones, imo; either should be fine for such a simple part. Shouldn't be more than $35 - 40. Torque the valve cover down evenly starting at the inner bolts and working outwards in a circular (one adjacent side then the opposite) sequence. Don't over torque.
BC_ZX3 is offline
Old 08-26-2012, 10:20 PM   #3
CotyM
CotyM's Avatar
Fan#: 85558
What I Drive: blue, y2k, 5spd ZX3, zetec inside
Points 945, Level 16
Points: 945, Level: 16 Points: 945, Level: 16 Points: 945, Level: 16
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 3%
FF Reputation: 3 CotyM Good Standing Member
I'm fairly sure that the T-housing uses a 10mm and the valve cover uses an 8mm... or something like that... but just buy a set of metric wrenches and sockets, they will be worth it in the long run...
Originally Posted by BC_ZX3 View Post
Don't over torque.
I cannot highlight this right here enough!!! I put to much into it on my 2000 zetec, snapped the bolt right off in the head, luckily for me in my case it was the bolt over the header so I was able to put a C-clamp on it to keep it from leaking oil...
On the bright side, If I ever want to smoke a honda, I can just take off that C-clamp and oil will drip onto the headers making LOTS of smoke flow out of the cracks of my hood and around through my fender wells
CotyM is offline
Old 08-26-2012, 10:37 PM   #4
AlexCA
Fan#: 102754
Thanks for the reply. I am going to change the motor mounts and wanted to know if these will work/ if the are decent quality:
http://www.ebay.com/itm/00-04-FORD-F...8413ad&vxp=mtr
Anyone know the cheapest place to buy some Gold coolant? I understand that I have to use this coolant.
AlexCA is offline
Old 08-27-2012, 05:12 PM   #5
Andrews-bad-SE
Fan#: 100389
What I Drive: 2003 Arizona Beige SE 4dr Zetec/ATX
FF Reputation: 3 Andrews-bad-SE Good Standing Member
Just get the peak g-05 coolant (advance auto parts... says "mix with any color" on it) its really good, its what I use.
Andrews-bad-SE is offline
Old 08-27-2012, 05:24 PM   #6
TerryB
TerryB's Avatar
Fan#: 34559
What I Drive: Red '01 ZX3
Points 5,215, Level 46
Points: 5,215, Level: 46 Points: 5,215, Level: 46 Points: 5,215, Level: 46
Level Up 33% Completed
FF Reputation: 68 TerryB Excellent Standing Member
I have a Felpro valve cover gasket from a mid 90's Contour. It's nice and thick. It came with my valve cover from Massive Speed. I think they know a thing or two.
http://www.partsgeek.com/gbproducts/...FYTd4AodPXEAVg
TerryB is offline
Old 08-27-2012, 05:31 PM   #7
MEJY1988
Fan#: 101883
What I Drive: 2006 Burgandy ZX5
Points 160, Level 3
Points: 160, Level: 3 Points: 160, Level: 3 Points: 160, Level: 3
Level Up 20% Completed
FF Reputation: 3 MEJY1988 Good Standing Member
You may want to look over this thread: Motor Mounts - Duralast & Anchor Brand.
It appears that most people on this site recommend only using OEM replacements.
I was a Shade Tree Mechanic, but had to cut down the Shade Tree to make room for the garage. Does this make me a Mechanic now?
MEJY1988 is offline
Old 08-27-2012, 05:44 PM   #8
TerryB
TerryB's Avatar
Fan#: 34559
Ummmmm.........that's his thread.
TerryB is offline
Old 08-27-2012, 06:01 PM   #9
MEJY1988
Fan#: 101883
Points 160, Level 3
Good catch. Didn't realize that.
MEJY1988 is offline
Old 08-27-2012, 06:03 PM   #10
TerryB
TerryB's Avatar
Fan#: 34559
Cuz I just read it. I knew it sounded familiar.
TerryB is offline
