Old 08-25-2012, 10:04 AM   #1
custommoggy
Fan#: 103049
What I Drive: 1966 zetec powered morris minor
FF Reputation: 1 custommoggy Good Standing Member
No pump voltage
1998 1.8 Mk1 petrol zetec, chopped into a custom car, using all the original harness ecu etc, there is no supply to the fuel pump, all the ecu voltages seem to be correct, I believe pin 53 is supposed to ground the pump relay to complete the circuit? I believe this is not happening, there may be a sensor unplugged somewhere or another issue such as immobilizer? If I hook up the pump to a 12v supply, the car will start and run for a second or two, then stop, the pump is running continuously like this but it shows there's a spark, if I turn the key again it'll start again for a second or two.
Now I believe the fuel regulation is controlled by the ecu so the correct amount of fuel is injected and by running the pump direct from 12v this will just deliver the maximum fuel, thus the car starts, then I suspect the ecu is seeing something it doesn't like and switching off the ignition thus stopping the car, now that bit is just guesswork, any ideas anyone? would it have a spark if either the cam or crank sensor was not connected for example?
I've driven myself mad reading the haynes manual! any help appreciated
custommoggy is offline
Fan#: 1
Old 08-25-2012, 10:22 AM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 2002 Land Yacht (Windstar)
FF Reputation: 263 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
Fuel cut-off switch? Also known as the inertia switch, or maybe what you call the immobilizer. It's designed to cut the fuel pump off in an accident. In US vehicles it's located on the right side kick panel of the vehicle. I'm not sure about RHD vehicles though, so check your owner's manual. To double check this switch: unplug it, use some solid insulated wire to bridge the 2 points on the conncector, try to start car. Do not run the vehicle for very long like this. If you have an accident, are unconscious, and your key is still ON, fuel will still pump. I've seen accidents on other vehicles without this safety feature where the fuel continues to pump out of the vehicle as fast as the pump will do it.
There is also the fuel pump controller which on US cars is located under the RH side rear seat. Lift the seat up, and you'll see the electronic controller there. Unplug and check to be sure you have power to the power supply side with the key On. If you have power there, and not power going out- that might be indicative of your problem. I think you'll find it in the fuel cut-off switch though.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 08-25-2012, 10:56 AM   #3
custommoggy
Fan#: 103049
If only it was that simple not the inertia switch, there's no votage to that either and i've bypassed it, think it's possibly to do with the ecu seeing something elsewhere and not switching on the pump relay, what would result in that? I know the relay is fine, changed it, but the relay is switched on by the ecu or not in this case.
Old 08-25-2012, 01:11 PM   #4
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
What I Drive: 2001 Red ZX3
FF Reputation: 82 BC_ZX3 Excellent Standing Member
Is the fuel pump driver module correctly grounded? The ECU regulates fuel pressure by varying the pump duty cycle via the fuel pump driver module. It in effect turns the pump ground on and off very rapidly.
Lots of good operational information/links and wiring schematics here:
http://www.focusfanatics.com/forum/showthread.php?t=295181
BC_ZX3 is offline
Old 08-26-2012, 04:20 AM   #5
custommoggy
Fan#: 103049
FPDM? There's no priming, or running, the only way I can get it to start
is to connect 12v directly to the pump, then it starts for a second and dies.
the lead back to the ecu I think is the control lead and it's not doing it's job,
may be a connection missing somewhere else causing the ecu to shut the
fuel pump control off. "I" has a 12v feed and I assume "K" is the control, ie
the ecu grounding K would switch on and off the pump the same way as the
FPDM would if it had one, I'm guessing the ecu is seeing an error elsewhere
and refusing to start the pump.
Old 08-26-2012, 10:09 AM   #6
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT , Turbocharged
FF Reputation: 146 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
The US car the 12v+ stays on all the time and its the ground that controls the pump , have you confirmed this with your UK car
There is a fuel pump driver in the ECU , inertia switch , driver module then the fuel pump , there is some fuses throw in there as well
Curious what you did about the PATS , maybe the UK cars dont have this ?
Customer Support
AIM: hpdyno
Email: tom@focus-power.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 08-26-2012, 12:39 PM   #7
custommoggy
Fan#: 103049
it's the same system, as for PATS I used the entire harness, key, column with switch gear, modules etc, not the door locks and I can't tell if the immobilizer is on or off but like I said previously it does start if i pump fuel in but only for a second or 2
Old 08-26-2012, 03:47 PM   #8
custommoggy
Fan#: 103049
How would I know if the immobilizer had kicked in? would the car crank?
Old 08-26-2012, 04:05 PM   #9
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Car wouldn't crank if the immobiliser was active.
BC_ZX3 is offline
Old 08-30-2012, 11:19 AM   #10
custommoggy
Fan#: 103049
Starting issue,
Turn the key, engine starts but wont tick over, start it and rev and there's a huge delay between throttle and engine revving, in fact if I press th accellerator pedal to the floor it revs on the way back up, here's a video, turn your sound up and you'll see what I mean, mid range is rough and misfiring. http://www.youtube.com/watch?v=Hi3C59qt1So
