so im shooting for 450whp in the future... how to get there? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-25-2012, 04:06 AM   #1
focusmaniaczx3
I need BOOOOST!!!!!!
focusmaniaczx3's Avatar
Fan#: 55157
What I Drive: zx3 turbo, kia soul, 71 chevy c/10
Points 14,948, Level 79
Points: 14,948, Level: 79 Points: 14,948, Level: 79 Points: 14,948, Level: 79
Level Up 20% Completed
Forum Activity 11%
FF Reputation: 35 focusmaniaczx3 Great Standing Member
Buy-Sell-Trade Rating: (14)
well im starting to shop around for what i need for 450whp. i was asking a question over in a Massive thread
here ---v--- about a clutch
http://www.focusfanatics.com/forum/showthread.php?t=281747
and it got me thinking. tons of people have hit this power mark in the past. ive looked into it in the past kind of half hearted like but never really retained any of the information because i never really thought i would do it. well now its starting to look like i am going to do it so its information gathering time. i have a good idea of what i will need but im sure there are things im overlooking which is where you guys come in. those of you who have done it before and have suffered through the heartache and all the hours of busted knuckles and bruised heads can help me now just cut through all the bull and go strait for the prize instead of figuring it out on my own along the way spending thousands of dollars and hours that i dont have to and that i frankly dont have to start with.
the plan for getting there is simple. i have the basic focus power turbo kit with the turbonetics super60. in a few weeks im going to put this on my car with the stock motor and run it at 10-12psi for a few months or maybe even a year or so. it just depends how long it takes me to get the motor built. over that period of time i am going to acquire a junk yard zetec. i can get one for about $150. i bring it home and put it on an engine stand and build the crap out of it. once everything is done i will take a few days doing the engine swap. pull the stock motor out, swap some little things from the stock motor to the built motor like A/C, P/S, and any other miscellaneous bits and pieces. wire in the boost a pump, bolt up the exact same turbo kit and crank the boost up to as much as the turbo can make without making too much heat. i figure that will put it around the 330whp mark maybe. at the same time as the engine swap i will pull the fidanza flywheel off the stock engine and put it on the built one and pair it with whatever clutch i choose that will fit the bill for my FINAL HP goal. this will be the last time the motor or tranny gets pulled unless i break something so i want to get the right clutch in the car the first time. i already have a torsen LSD in my tranny. i will then drive the car in that configuration for a few weeks or maybe months until i am satisfied that the engine is solid at which point i will go down again to receive a return fuel system, bigger turbo, bigger intercooler, and much much more boost. at this point i hope to have attained my power goal.
this is what i have so far that im going to need... i think
donor engine on a stand. im just using block, crank, and accessories (A/C, power steering, etc) cook and clean the block, balance the crank to 9k rpm
all ARP that i can get
OEM main and rod bearings.
return fuel setup for big boost
eagle rods
supertech 9:1 pistons
FRPP head
top speed intake manifold
aftermarket cams
crower springs and retainers
adjustable cam gears
dry sump oil system
and a clutch to take the juice
now we get into hypotheticals.
i plan on running the biggest down pipe that i can. 3.5 or 3inch i think is the biggest ill be able to pull off and keep my A/C. i will run it into an electric exhaust cutout that will pipe the exhaust out right in front of the passenger side front tire and when the cutout is closed it will pipe down to a 2.5 inch custom exhaust. im keeping the car quiet and low key unless i nail it and open the cut out at the flip of a switch. good or bad idea?
i need to track down a clutch to take that amount of juice. and 450whp is my goal on PUMP gas. who is to say that i dont decide to get a race gas tune? i might end up making well over 500whp. i have easy access to 110 octane. roushturboedzx3 seemed to really like the clutch in the massive speed thread that i linked to. any feedback on that clutch in this thread or the massive thread would be excellent.
cams. i would love to run different cams. i know the stock cams work fine with boost but good lord it will make me crazy just knowing all the work that has been done with the car but im still running stock camshafts! i think mcnews used to make some custom turbogrind cams but are they even still around or available? if not then what cams would work well with what im planning?
not going to lie, im a little concerned about running eagle rods with this much power. its just a feeling nagging me in the back of my mind but i cant shake the feeling that i read at some point in the past that eagle rods cant take but about 400whp. is that right or am i being paranoid?
what turbo and intercooler should i upgrade to once im to that point? i dont have a brand preference really but this wont be a track only car so an intercooler that you have to keep ice in wont fly. i still plan on driving this car. maybe not as a DAILY driver but at least on the weekends. right now im just running the standard focus power kit with an old turbonetics super60. is there anything else i would have to change with the kit once im to that point? i mean i think it would be NICE and maybe a bit more efficient to run larger piping but if enough boost gets forced in there i can still get the same power numbers with the smaller pipes. obviously ill need BOV and wastegate springs. but would i have to change the entire BOV and WG out or could i get away with just the springs?
i cant really think of anything else right now. if there is anything i missed then please by all means pipe in. i need information. i want to pick the cleanest, cheapest, and most efficient path to my goal but i cant do that if im blind and i am blind as a bat without information.
and by the way im updating this first post as plans and the shopping list change and mutate and adapt. this is going to happen one way or another. it just might not happen the way that i thought it would in the very beginning.
focus-power P&P head $1100
focus-power DIY turbo kit $1495
tom's first time in Vegas? PRICELESS!
Originally Posted by 1turbofocus
I love this big little city HOOTERS !
Every time you drink a beer somewhere an ugly woman becomes beautiful, so get to it!
focusmaniaczx3 is offline
Old 08-25-2012, 04:14 AM   #2
focusmaniaczx3
Fan#: 55157
Forum Activity 11%
ah yes and an oil pump! when i get it on a dyno its going to be twisting out until it quits making power. if it peaks at 8500 then thats where it peaks. that is why im going to get the crank balanced to 9k. and ill definitely need an oil pump to do that. and springs to keep the float at bay. what springs would work well for that rpm range with stock ish cams?
Old 08-25-2012, 06:26 AM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,816, Level 100
Points: 51,816, Level: 100 Points: 51,816, Level: 100 Points: 51,816, Level: 100
Level Up 0% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
Buy-Sell-Trade Rating: (28)
The Crower springs and retainers will do the job , to turn 8500-9000 safely you will need a dry sump oil system
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 08-25-2012, 07:21 AM   #4
focusmaniaczx3
Fan#: 55157
Forum Activity 11%
still trying to hammer it all out in my head. need to know what clutch, what cams, whether eagle rods can take the heat, what turbo and intercooler pair would get me there, where to get all of the miscellaneous parts from for the best deal and need to know if im forgetting about anything...
is there anybody currently selling a dry sump? i dont think CFM has that anymore...
i can get in touch with massive and ask about the clutch they sold roush
i can try to track down some of those mcnews cams unless someone knows of a better camshaft to run
and i havent even got the foggiest idea on what turbo or intercooler to run or where to get them. that will have to come entirely from you wonderful people because that is simply knowledge i do not posses.
Old 08-25-2012, 09:02 AM   #5
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
You pretty much have the idea. Don't worry bout the eagle rods they are good for the HP
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 08-25-2012, 09:29 AM   #6
focusmaniaczx3
Fan#: 55157
Forum Activity 11%
pretty much aint gonna cut it though. i need the whole entire picture! i want to know for fact that i have at the very least a complete shopping list of all the bits and pieces i need to do this.
AHA! another thought just came to me! will 60lb injectors get me there? and just curious about e85? i know you burn alot more of it but it seems to be good for more power. alot of people are running that stuff nowadays. sooo why not try it in a focus? if i understand the concept of the stuff it would be like running 140 octane gasoline basically but i would have to have water hoses for fuel injectors and other than bigger injectors and tuning there are no other modifications that need to be made. maybe there are special spark plugs or something but otherwise nothing. any input on that anyone? the e85 thing is just for curiosity though. im not even sure as to where i can get it at around here. ive never actually looked
Old 08-25-2012, 09:47 AM   #7
700whpfocus
Fan#: 40899
What I Drive: 2000 zx3 twillight blue focus
Points 5,458, Level 47
Points: 5,458, Level: 47 Points: 5,458, Level: 47 Points: 5,458, Level: 47
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 2 700whpfocus Good Standing Member
The eagle rods will hold the power, unless you want crower rods. way more for them.
700whpfocus is offline
Old 08-25-2012, 09:54 AM   #8
focusmaniaczx3
Fan#: 55157
Forum Activity 11%
another thought. what gauges are good to have with a build of this magnitude? A/F, oil temp and pressure, boost, and what else? im tired, ive been up all night, what am i forgetting? i always end up forgetting something simple that is extremely important when i think about something this hard... what is it?!
so what will crower rods hold power wise and what will eagles hold power wise? what is the difference between the two besides the price? cheaper is better but i am a firm believer in overkill. if eagles are good for 500 and crowers are good for 1000 then ill spend extra on the crowers. even though the crank wouldnt hold that i would still like the peace of mind
Old 08-25-2012, 11:42 AM   #9
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
Go with 80lb injectors, stay off E85 run C16, a CM stg4 will do for the power and is compatible with the fidanza flywheel.
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by Fernando@RacingPartsSolution.com
Mother Focus is online now
Old 08-26-2012, 12:34 AM   #10
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 4%
Agreed here definately
FF MODERATOR
RIFF CREW
