Ford Racing suspension - Which kit / Funkin Klunkin - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-24-2012, 01:29 PM   #1
TommyTooHi
TommyTooHi's Avatar
Fan#: 90859
What I Drive: 2004 Red Focus SVT
FF Reputation: 1 TommyTooHi Good Standing Member
I am about to order up new shocks/struts -
Q1: Do the 2 kits (below) have the same bits, i.e., does the assembled set have everything included in the no-spring set?
At his point, I'm thinking new springs would not be a bad idea (with 117k on the original parts!)
Q2: And... what else should I order that might eliminate the funkin right front (especially) clunking that would be relatively easy cheap?
Sway bar end links, other???
Kits:
M-3000-ZX3A 00-05 Stock SVT kit w/o rear sway, but with strut top mounts and springs
M-18000-ZX3 00-05 Stock SVT shocks & struts (comes with mounts, bearings, etc., but no springs)
Ford Racing Suspension
Thanks for any tips/info!
-TooHi
Aw, heck - you mean what I know...
Mods: Caffeinated nut behind the steering wheel
TommyTooHi is offline
Old 08-24-2012, 05:09 PM   #2
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
Unless you have abused the car the current springs should be OK. Definitely replace the shocks as they are long gone (about 50K miles ago). Yes, replace the end links as they are a wear item and are the source of most front end noises. That said, get the shock kit without springs if the car hasn't been beat on.
Geezer is offline
Old 08-24-2012, 06:19 PM   #3
TommyTooHi
TommyTooHi's Avatar
Fan#: 90859
understood...
Got it.
Most of the previous history is unknown; what I'm now thinking is that for what works out to about $34 a spring (difference between the 2 kits) and the pre-assembled lack of time, I'm gonna step up.
Found this fine post:
SVT Focus Suspension upgrade (general)
and the Moog bits look nice too-
(NOTE: Part #'s below are unverified)
Moog front sway bar end links (Part # K80066, quantity: 2)
Moog rear sway bar end links (Part # K90129, quantity: 2)
Sway bar bushings, maybe, too... what the heck.
Prothane Front sway bar bushings (part # 6-1152-BL)
Prothane Rear sway bar bushings (part # 6-1156-BL)
And, what the heck - LCA's can be had for less than $50 each as well. Being that they come with wear items preinstalled, doing them at the same time makes sense.
NEXT: I have to see if Mr Fordahl's new shop is open and if racing season is winding up so he can play with my lowly daily driver <g>
(http://www.fordahlmotorsports.com/) - he DA MAN for suspension setup in the Seattle Metro area!!!
Thanks,
-T_T
Old 09-30-2012, 03:26 PM   #4
TommyTooHi
TommyTooHi's Avatar
Fan#: 90859
Got the kit, got the Moog 'Problem Solver' front sway bar end links.
Popped the Moog parts in first, and yeah, that fixed the clunking. Woo hoo.
Went back under and swapped out the front struts/spring assemblies, and THAT helped, too. The old ones were worn, a noticeable but not major change.
Next: Into Greg's to finish up the rear- springs/shocks and sway bar bushings and get a good alignment.
He has a scale to step on, gets your weight, puts sand bags/weights in the drivers seat before he starts. Niiiiiiiiice.... just a bit $ more than say, Sears or Goodyear. Like I'd do THAT... NOT!
I stopped in and chatted with him, and he's very familiar with the car as he has friends that campaign SVT's locally.
-T_T
Old 09-30-2012, 03:33 PM   #5
TommyTooHi
TommyTooHi's Avatar
Fan#: 90859
interesting measurement / observation!
After a few drive cycles, the front end is about 3/8" higher with the new assembly (strut/spring assembled by the fine folks that work for Ford).
So, the springs were sagging a bit after about 118k miles. Glad I did it.
Aside: A few winds of the springs had some shiny areas - the inner wheel well has what appears to be a corresponding series of rubbed marks.
Could it be they were whapping??????????????
-T_T
Old 09-30-2012, 03:34 PM   #6
GreySkorpion
saved from the grave
GreySkorpion's Avatar
Fan#: 94674
Points 6,225, Level 51
Points: 6,225, Level: 51 Points: 6,225, Level: 51 Points: 6,225, Level: 51
Level Up 38% Completed
FF Reputation: 11 GreySkorpion Great Standing Member
Awesome, glad you have a go to guy!!
GreySkorpion is offline
