2006 Focus Front Brakes Sticking - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-23-2012, 11:16 PM   #1
dfiedler2012
Fan#: 102997
What I Drive: 2006 Gold Ford Focus ZX4
FF Reputation: 1 dfiedler2012 Good Standing Member
For about 3 weeks now I can be driving along and the front disc brakes, both of them, begin to close on the rotors. The longer I drive, the more the front brakes engage. I didn't believe it at first, but I've proven it to myself. After searching the Internet almost everyone is told to replace calipers, brake pads, rotors, master cylinder etc. I wish it were that straight forward. I've seen that this problem could be related to a faulty vacuum booster unit vacuum hose non-return valve. I check that tonight and it appears to only flow in one direction. Has anyone else ever experienced this and know what the issue is? Nothing is leaking. There are no lines collapsing, they are all metal until they get to the last foot before connecting to the calipers. This one has me stumped. Any help would be appreciated. Thanks!
dfiedler2012 is offline
Old 09-23-2012, 06:15 PM   #2
dfiedler2012
Fan#: 102997
Apparently no one knows the answer so I diagnosed myself. Hopefully this will help someone else. The vacuum brake booster is a large diameter cannistor that is divided in two by a diaphram. Vacuum is created by the intake and pulls a vacuum on both sides of the diaphram. As you push the brake peddle, air is allowed in on one side, lowering the vacuum on that side of the diaphram. The other side is still under full vacuum. That full vacuum side is pushed by the lower vacuum side and moves a rod going to the master brake cylinder, assisting the driver in applying the brakes. If a small leak occurs on the side of diaphram where air is allowed in during braking, the brakes will engage ALL BY THEMSELVES. I replaced the vacuum brake booster (tremendously difficult due to no room to pull it out) and that solved the issue. About $90, and there is a core charge.
Old 09-23-2012, 06:39 PM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,736, Level 98
Level Up 39% Completed
Forum Activity 5%
I didn't even see this, but thanks for the write-up.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 09-24-2012, 07:29 PM   #4
canadianlarry
Fan#: 102604
What I Drive: 2012 sterling grey 5spd se
Points 237, Level 4
Points: 237, Level: 4 Points: 237, Level: 4 Points: 237, Level: 4
Level Up 74% Completed
FF Reputation: 2 canadianlarry Good Standing Member
I had the same problem with my 2003 se 5 speed. All kinds of weird intermittent brake dragging over months. Tried the usual fixes of brake flex lines and calipers. Finally tried a used booster and problem was fixed . You are right, it is very tight to get it out.
canadianlarry is offline
Old 01-18-2015, 02:49 AM   #5
redeemed
Fan#: 48366
What I Drive: 06RED FOCUS
Points 31, Level 1
Points: 31, Level: 1 Points: 31, Level: 1 Points: 31, Level: 1
Level Up 62% Completed
FF Reputation: 1 redeemed Good Standing Member
Exclamation Help please
I am having this problem! I think everything has been replaces except the booster. This last time the auto shop said it is the brake light switch. I just got it back. I was not having any problem with the brake lights. This has been going on for about 6 months. The brakes or calibers have stuck so bad they have smoked twice. What parts have been damaged from getting so hot all these months? How do I convince the shop it may be the booster? Thank you!
redeemed is offline
Old 01-18-2015, 03:17 AM   #6
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 324, Level 6
Points: 324, Level: 6 Points: 324, Level: 6 Points: 324, Level: 6
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 10%
FF Reputation: 8 Milton Good Standing Member
Please start a new thread and not resurrect a >2 year old thread.
Milton is offline
Old 01-18-2015, 09:01 AM   #7
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,736, Level 73
Points: 12,736, Level: 73 Points: 12,736, Level: 73 Points: 12,736, Level: 73
Level Up 72% Completed
Forum Activity 99%
Moved to the Brakes, Suspension & Chassis section.
Lack of free play between pedal push rod & brake booster can cause trouble as well as booster problems mentioned by the OP.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
