Installed FRPP kit. Now hearing a noise - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-21-2012, 02:30 PM   #1
RAF_S197
RAF_S197's Avatar
Fan#: 91991
What I Drive: 2014 Oxford white Sport Black Pack
Points 7,708, Level 58
Points: 7,708, Level: 58 Points: 7,708, Level: 58 Points: 7,708, Level: 58
Level Up 79% Completed
FF Reputation: 21 RAF_S197 Great Standing Member
Buy-Sell-Trade Rating: (4)
Hey guys,
I recently installed the FRPP kit (new) on my 2009 from Tousley Ford.
When I go over bumps I hear a clunk in the front end. I believe it's the springs on the struts making the noise. While installing the FRPP kit I did notice that the top of piece that goes on top of the spring (which is attached to the strut mount) is different than my stock one. Also there is a small thing worn out rubber piece that goes over the top coil of my stock front spring which did not come with the FRPP kit.
Any ideas as to what might be wrong? I'm prett positive I installed everything right.
2014 Oxford white Focus SE Sport Black pack
Instagram: 5_POINTOH
RAF_S197 is offline
Old 08-21-2012, 03:12 PM   #2
nov173
nov173's Avatar
Fan#: 29840
What I Drive: 2014 Focus ST
FF Reputation: 79 nov173 Excellent Standing Member
is your spring sitting in the strut right? is it shifting possibly? or tie rod
SVT header kit, 2.25 MBRP cat-back & flex, r/t high flow cat. aem cai, frpp kit
For Sale: Rear bumper(stock). SVT side skirts FS as well. Buy em!!!!
nov173 is offline
Old 08-21-2012, 03:17 PM   #3
RAF_S197
RAF_S197's Avatar
Fan#: 91991
I made sure the spring is on the strut right. Unless it could have moved. Not sure on the tie rod but I never had the noise before the FRPP kit. I also replaced the end links thinking that was the problem but it wasn't
RAF_S197 is offline
Old 08-21-2012, 03:26 PM   #4
nov173
nov173's Avatar
Fan#: 29840
ya i don't even know why i typed tie rod... i mean to say end links.. cuz that's usually the issue. I didn't have an issue when i installed mine many moons ago on my old car. do you have an idea where the clunking is coming from? have someone stand outside the car when you go over a bump
nov173 is offline
Old 08-28-2012, 11:39 PM   #5
RAF_S197
RAF_S197's Avatar
Fan#: 91991
Anyone?
RAF_S197 is offline
Old 09-01-2012, 01:12 AM   #6
RAF_S197
RAF_S197's Avatar
Fan#: 91991
Hey guys. I just remembered. The kit didn't come with any front isolators. Could this be the cause?
I re used the stock rear isolators but there's nothing in the front of the new kit to be reused nor with the FRPP kit
RAF_S197 is offline
Old 09-01-2012, 01:36 AM   #7
billand
Fan#: 103046
What I Drive: 2012 Ford Focus Titanium
Points 404, Level 8
Points: 404, Level: 8 Points: 404, Level: 8 Points: 404, Level: 8
Level Up 8% Completed
FF Reputation: 2 billand Good Standing Member
I would look for new rubber prices between the spring and the strut mount also go back and check your torque specs on all bolts. For recommends changing bolts and hardware every time you remove shocks and struts so that my be why your hearing a noise.
billand is offline
Old 09-01-2012, 01:00 PM   #8
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,622, Level 31
Points: 2,622, Level: 31 Points: 2,622, Level: 31 Points: 2,622, Level: 31
Level Up 15% Completed
Forum Activity 2%
There are no rubber isolaters in the front.
The pre-assembled SVT struts have nothing but steel springs on steel mounts, and they don't make noise.
Often, it is the top strut mount bearing that makes the clunking noise.
elsolo is offline
Old 09-01-2012, 01:15 PM   #9
billand
Fan#: 103046
Points 404, Level 8
Check the strut mount they are open ball bearings and some times the break and the bearing come out
billand is offline
Old 09-02-2012, 02:47 PM   #10
elsolo
elsolo's Avatar
Fan#: 96835
Forum Activity 2%
There are no ball bearings in a stock Ford focus strut mount assembly.
The "bearing" is a plastic flange bushing that goes between the spring retainer plate and the strut mount.
elsolo is offline
