Official ST Part Numbers Thread - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus ST > Focus ST
Focus ST The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK3 2013-Current Focus ST.
Old 08-21-2012, 01:04 PM   #1
Twenty
Sonic's Mk3 Crew #17
Twenty's Avatar
Fan#: 90312
What I Drive: 2012 YB SE sedan w/ ST exterior
Points 22,454, Level 93
Points: 22,454, Level: 93 Points: 22,454, Level: 93 Points: 22,454, Level: 93
Level Up 11% Completed
Forum Activity 11%
FF Reputation: 10 Twenty Great Standing Member
This thread will be to list all part numbers found for the 2013+ Focus ST. As more are discovered, please post them in here and I will update the original post as often as I can.
I won't promise that everything posted will be guaranteed to swap onto a non-ST 2012+ Focus, but that will be discovered with time.
Parts are organized alphabetically within the categories below.
Exterior
Badge (ST) - CM5Z-5842528-A
Fog Light Inserts for Front Grille - 17B814
Front Bumper Cover - 17D957
Front Bumper Grille - 17B968
Front Bumper Grille Insert (Bottom Piece) - 17K945
Rear Body Reflector Assembly (RH and LH) -13A565
Rear Bumper Black Insert (RH and LH) - 17D752
Rear Bumper Extension ST Version - 17810
ST front-end conversion part numbers: http://www.focusfanatics.com/forum/showthread.php?t=305741
Bumper cover: CM5Z 17D957 BBPTM
Upper Bracket: CM5Z 17C897 B
Left Foglight Grill: CM5Z 17E811 A
Right Foglight Grill: CM5Z 17E810 A
Lower Grill: CM5Z 17K945 A
Main Grill: CM5Z 8200B A
Ford Emblem: CV6Z 16605 A
ST Emblem: CM5Z 5842528 B
Air Dam: CM5Z 8310 D
Air Deflector: AM5Z 17626 A
Interior
Drivetrain
Suspension/Wheels/Brakes
Front Coil Springs - CV61-5310-SG
Front strut (LH) - AST-12281
Front strut (RH) - AST-12287
Rear Coil Springs - CV61-5560-SG
Rear shock - ASH-24518 (include upper shock mounts/bumpstops) [DOES NOT fit non-STs]
Upper front strut mount - AD-1098
officialTHREETWENTY
2012 YB Focus SE Sedan [featured in Performance Ford, Sept '14]
1992 BW Grand Prix SE Sedan [restomod project]
SR#74/SMk3C#17/YBOC#03
Bill M.
Twenty is offline
Old 08-21-2012, 02:03 PM   #2
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,504, Level 30
Points: 2,504, Level: 30 Points: 2,504, Level: 30 Points: 2,504, Level: 30
Level Up 36% Completed
FF Reputation: 27 Zillon Great Standing Member
Suspension:
AD-1098 - Upper front strut mount
AST-12281 - LH front Strut
AST-12287 - RH front strut
ASH-24518 - Rear shock
Joined the dark side.
Zillon is offline
Old 08-21-2012, 02:09 PM   #3
Twenty
Twenty's Avatar
Fan#: 90312
Forum Activity 11%
Thank you Zillon, updated.
officialTHREETWENTY
Bill M.
Twenty is offline
Old 09-03-2012, 04:08 PM   #4
Twenty
Twenty's Avatar
Fan#: 90312
Forum Activity 11%
Would it be possible to get this stickied, for everyone's reference?
officialTHREETWENTY
Bill M.
Twenty is offline
Old 09-03-2012, 06:56 PM   #5
Ox-y-GenIII
Ox-y-GenIII's Avatar
Fan#: 90008
What I Drive: 2012 Oxford White SEL Hatch
Points 5,318, Level 46
Points: 5,318, Level: 46 Points: 5,318, Level: 46 Points: 5,318, Level: 46
Level Up 84% Completed
Forum Activity 2%
FF Reputation: 4 Ox-y-GenIII Good Standing Member
Good start for this thread. Sounds like a good idea.
Ox-y-GenIII
2012 Oxford White Focus Hatchback
Dyno #'s 164.35 HP 147.12 TQ
Ox-y-GenIII is offline
Old 09-03-2012, 07:53 PM   #6
misfire
Moderator
misfire's Avatar
Fan#: 31379
What I Drive: 2012 SEL Hatch, 2014 Mazda CX-5
Points 17,083, Level 83
Points: 17,083, Level: 83 Points: 17,083, Level: 83 Points: 17,083, Level: 83
Level Up 47% Completed
Forum Activity 7%
FF Reputation: 31 misfire Great Standing Member
Buy-Sell-Trade Rating: (13)
done
Will aka Misfire
2003 LX "traded in"/2010 SES "traded in"/2012 SEL Hatch "current"
misfire is offline
Old 09-03-2012, 08:05 PM   #7
Twenty
Twenty's Avatar
Fan#: 90312
Forum Activity 11%
You're awesome, thank you!
officialTHREETWENTY
Bill M.
Twenty is offline
Old 09-04-2012, 01:23 AM   #8
20Focus13
20Focus13's Avatar
Fan#: 92454
What I Drive: 2013 Focus ST ST3,2012 GT500 750HP
FF Reputation: 1 20Focus13 Good Standing Member
Here are some specs out of the ST manual. Besides the struts, it looks like Ford made changes to the knuckles and stabilizers too.
•2.0L GTDI EcoBoost I4 engine
•Over boost function for increased torque
•Electronic over-rev function with 6800 rpm redline
•ST tuned 2.5 in. center exit exhaust system
•Getrag-Ford MMT6 6-speed manual transaxle
•Active sound symposer
•Variable ratio steering
•Modified front suspension knuckle for improved wheel end geometry
•Cast rear knuckle (improved stiffness) and alternative anti-roll-bar
mounting for improved efficiency
•ST tuned springs and dampers
•Increased diameter (320 mm) front brake rotors and unique calipers
with ST tuned pad formulation front and rear
•Enhanced torque vectoring control with cornering under steer control
•ST tuned electric power assisted steering with torque steer compensation
•AdvanceTrac stability enhancement system with three modes:
Normal, Sport and Disabled
•18in.x8in.55mm offset aluminum ST Wheels
•P235/40-18 directional Goodyear Eagle F1 tires
•ST engineered front and rear fascias and rear wing
Focus ST Unique Features
20Focus13 is offline
Old 09-04-2012, 11:19 AM   #9
wantz12
wantz12's Avatar
Fan#: 89237
What I Drive: 2012 White FF Hatch
Points 2,610, Level 31
Points: 2,610, Level: 31 Points: 2,610, Level: 31 Points: 2,610, Level: 31
Level Up 7% Completed
FF Reputation: 2 wantz12 Good Standing Member
All from fordparts.com
http://www.fordparts.com/Commerce/Ca...o=Focus#Search
17D957 - Front Bumper Cover - $489.60
17B968 - Front Bumper Grille - $251.17
17B814 - Fog Light Inserts for Front Grille - Price Not Listed
17K945 - Front Bumper Grille Insert (Bottom Piece) - Price Not Listed
2012 Ford Focus SEL Hatchback
K&N Typhoon Intake | 3d Carbon Wing
HN #167
wantz12 is offline
Old 09-04-2012, 11:25 AM   #10
wantz12
wantz12's Avatar
Fan#: 89237
17810 - Rear Bumper Extension ST Version - $239.50
17D752 - Rear Bumper Black Insert (RH and LH) - $38.47
13A565 - Rear Body Reflector Assembly (RH and LH) - $305.33 (seems steep)
I'm not gonna bother listing all the mounting hardware for these, visit the webpages.
HN #167
wantz12 is offline
