#1 | ||||
![]() $26...bit of duct tape...a clamp and 5 mins gets you started.....need to check OD of intake tube and fitment of the filter. Remove top of airbox and old filter...install new filter. My filter TUBE has a 3.5" OD...same as intake tube...ID of filter tube is LESS than plastic intake tube....this MIGHT be why it works? Have since reduced the amount of foam used under the filter...it now only supports just the end of the filter. Also cleaned and re-oiled the filter. Not sure this is the same filter I have....probably same brand though....you'd want one with a 3.5" OD for the rubber filter tube to duplicate the setup I have. http://shop.advanceautoparts.com/web...___#fragment-2 Yes...this pulls some warmer air...not an issue for me...I drive for mpgs....currently seeing ~37 mpg tank to tank...combo of driving techniques and various mods.
2003 2dr ZX3 2.0 L Zetec auto 205/50/16s ...and I am unanimous in that position. |
Remove Advertisements |
Fan#: 1
#2 | ||||
RespectMyAuthoritah!
wow...........
this is basically a home made short ram intake. Looks like you blocked off a little bit of your snorkle intake from the stock airbox location
"I flushed a bag of skittles down the toilet yesterday and watched a NASCAR race in 8 seconds flat." 06 Spring Into Focus Best Sedan/Wagon Winner ![]() 03 SE SVT Wannabe (sold) to help pay for my 08 Cooper Red Mazda CX7 AWD GT |
#3 | ||||
This is something quite common with cars for a while especially zetecs and spis. I hope you didn't get a cheap filter, they usually allow bad crap to be sucked in, and trust me it gets real dirty in there. The extra 10-15 bucks is worth it for a k&n/AEM filter. Why the duct tape? Before I bought a full intake system I just clamped mines without tape to the maf sensor housing. The MPG is probably because your previous filter was dirty.
Sent from my SAMSUNG-SGH-I717 using FF Mobile
Give rep if youve been helped :) |
#6 | ||||
I only get 25-28 mpg
I see you get 37mpg. I have the same car you have and i only get 25-28 mpg. I drive far for work all highway miles. Can you give me ideas how to get better gas mileage?
#7 | ||||
ɔıʇɐuɐɟ snɔoɟ
replace the plugs, wires, use synthetic oil, get a itc filter or fswerks intake, exhaust.
Focus Revolution Focus Central
#8 | ||||
The trick with the above is staying off the Gas because with the exhaust and intake you will like the sound of your car better. and then use cruse control and go 65MPH or so, commute if you can to avoid rush hour (either leave earlier or much later). Keep the RPM's under 3k, go with a skinny tire when you need to replace them. Shed unwanted weight (is it worth a little extra MPG if you have to use your insurances free tow service to get the flat fixed?) Roll windows down when going under 40ish MPH and only use the vents (no AC) when at Freeway speeds. Proper tire pressure, only keep the tank 1/2 or 1/4 full so your carrying around less weight... there are lots of things that can be done in addition to the tune up. it all depends on crazy you want to get.
2001 ZX3 2.0L Zetec- Hatch Nation #42 Going through Rebuild See "The TICK Build Thread" for details (http://www.focusfanatics.com/forum/showthread.php?t=289168&referrerid=62897) |
#9 | ||||
so for what everr reason my car grts like 19 a gallon with 20to 25 reachable some times but not all the 'time i got a magnaflow and a volant so far idk what else though i dont really shift that high maybe 2100 at most....after i bought the cari found that some one cut a whole in the cat for what ever reason cauld this cause bad mpg if its just open or actually clogged or something
#10 | ||||
| Thread Tools | |
| Display Modes | |
