catch can ? read whole post before answerering,plz - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-20-2012, 04:58 PM   #1
burke_024
burke_024's Avatar
Fan#: 94039
What I Drive: 2000 focus zx3, almost boosted : )
Points 1,562, Level 22
Points: 1,562, Level: 22 Points: 1,562, Level: 22 Points: 1,562, Level: 22
Level Up 62% Completed
FF Reputation: 1 burke_024 Good Standing Member
i need a straight forward answer on how to route a catch can into the pcv system ,i keep searching but either its a foriegn language to me or the explanations are not complete ,if anyone has a pisture of a setup on a zetec 16v turbo that would help ,do i delete the vacuum from the intake? do i run a tube from the valve cover to the can and then to the pcv baffle ,and then just put a filter in the can ,do i need to tune for it ,just please no blown up post just a simple straight forwaqrd answer thnx guys ,im building the can to so any pics of the insides would be awesome
burke_024 is offline
Old 08-20-2012, 05:23 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,859, Level 100
Points: 51,859, Level: 100 Points: 51,859, Level: 100 Points: 51,859, Level: 100
Level Up 0% Completed
Forum Activity 30%
Buy-Sell-Trade Rating: (28)
What I do is
Valve cover :1/2 inch hose run down the back of the engine to about 2 inches below the trans
PCV : I cut the bottom of the PCV and remove the ball and spring , replace the PCV , hook a 3/8 hose to the PCV then run the hose up over the top raid hose then down to about 2 inches below the trans , remove the hose from the intake to the PCV and plug this off
You can just as easy run these 2 hoses to a catch can , make sure the hoses still breath well and dont rought the can back to the intake manifold
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 08-20-2012, 06:43 PM   #3
burke_024
burke_024's Avatar
Fan#: 94039
ok i have the setup figured out now thnx tom my question is when i make the can is there a specific direction it should flow http://www.034motorsport.com/oscthum...hCanInside.jpg
which one should the pcv side hook up to and ...well i think ill know where the other one goes haha ,thnx for the help
Old 08-21-2012, 09:43 AM   #4
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
Did u ever get the car running?
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 08-21-2012, 10:39 AM   #5
burke_024
burke_024's Avatar
Fan#: 94039
yea but my license got taken fml but i either have,had to much oil in it or , alot of blow by so im gonna hook up a catch can before i drive it again so if it is blow by at least oil doesnt go everywhere ,as soon as i get all that hooked up im gonna do a leakdown,compression test to see what i can find out compression was at 120-125 on all four ,ill post some numbers and results as soon as i can
Old 08-21-2012, 11:08 AM   #6
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 30%
You will have to install another bung in that catch can for 2 connections
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 08-21-2012, 02:07 PM   #7
burke_024
burke_024's Avatar
Fan#: 94039
1.so the top one would be the filter
2. the pcv goes to the one that goes into and down into the can
3. the valve cover hooks up to the one that has no tube on the inside
correct?
thats not the one im using i just found that pic ,but there should also be a medium inside such as steel wool ?
Old 08-21-2012, 04:09 PM   #8
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 30%
You need a total of 3 holes , one in the top for a breather and then 2 for the engine
you need a drain on the bottom and there doesnt have to be anything in it
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
