Wet under the Hood and then the transmission goes wierd!? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-19-2012, 10:28 AM   #11
suznal
Fan#: 102830
What I Drive: 2005 Gray ZXW
Points 390, Level 7
Points: 390, Level: 7 Points: 390, Level: 7 Points: 390, Level: 7
Level Up 80% Completed
FF Reputation: 1 suznal Good Standing Member
(frustrated)
Well, I used the grease on all of the connectors going to the transmission, as well as other connectors that were in the general area that I found -
Now when I drive through a puddle, the car just stalls!
I can't let it idle, or it will stall out - and when I'm on the throttle it kicks and sputters!
I'm thinking something else is getting wet, but not sure what.
One thing I did notice - there are two connectors for where the wiring harnesses pass into the cabin - and they are located in the driver side fender well! Best part is that the liner has a cut-out for the strut which leaves a direct line of sight to those connectors! I see that both of these connectors bolt in - are they supposedly waterproof?
suznal is offline
Old 01-15-2013, 01:08 PM   #12
suznal
Fan#: 102830
Points 390, Level 7
Finally found the problem!
The connector for the wiring harness (in the fender well) was cracked, and missing a piece. I filled in the missing piece with epoxy, greased it up real good and wrapped it in electrical tape before re-assembling. Then I got the hose out and tested to make sure the car was hurricane proof.
Problem solved and have no incidents since the repair (about a month and a half now).
suznal is offline
