Wet under the Hood and then the transmission goes wierd!? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-20-2012, 12:06 PM   #1
suznal
Fan#: 102830
What I Drive: 2005 Gray ZXW
Points 390, Level 7
Points: 390, Level: 7 Points: 390, Level: 7 Points: 390, Level: 7
Level Up 80% Completed
FF Reputation: 1 suznal Good Standing Member
2005 ZXW (wagon)
Car runs fine, no major complaints Ė until it rains.
Car will operate just fine in a shower, but as soon as I hit standing water (enough to make a decent splash) the tranny (automatic) slips. It will go in and out of gear Ė I end up barely driving 10mph!
Sitting still, in drive or neutral, the engine idles fine.
Sice this only happens after driving through water deep enough (2 inches) to make a splash, Iím assuming that something is getting wet and confusing the heck out of the car. After an hour or so of sitting and drying out, the car is fine.
What do I need to check Ė Iím thinking a sensor? But which ones should I look at? Or perhaps there is another problem?
PLEASE HELP!
suznal is offline
Old 08-20-2012, 06:22 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,412, Level 75
Points: 13,412, Level: 75 Points: 13,412, Level: 75 Points: 13,412, Level: 75
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
Forum Activity 99%
Disassemble, clean, and grease (dielectric type) all the wires that go to the tranny - it's electronic, so any bad connections (exacerbated by water) will cause issues....
Luck!
sailor is online now
Old 08-22-2012, 01:02 PM   #3
suznal
Fan#: 102830
Points 390, Level 7
Thanks,
Iíll give it a go. By the way - dielectric type grease, why can I not find anyone who knows what it is? Iíve called three auto parts stores and they have no clue!
suznal is offline
Old 08-22-2012, 01:38 PM   #4
Chris_HT
Chris_HT's Avatar
Fan#: 86229
What I Drive: Blue SVT 2002
Points 1,558, Level 22
Points: 1,558, Level: 22 Points: 1,558, Level: 22 Points: 1,558, Level: 22
Level Up 58% Completed
FF Reputation: 4 Chris_HT Good Standing Member
minimum wage employees that's what it is, most of them can't even use their own computer catalog, let alone any technical knowledge about cars - I used to get frustrated at 'autozonelike' stores but now I just go there and ask for specific part numbers.
..ok I still get frustrated, the autozone close to where I live will always have 1-2 ppl on counter, and all others just walking around trying to look busy or will just stand there in plain view and chat about whatever it is that isn't related to their jobs, so often I need to wait 20 minutes in long line just to pick one part :/
Blue SVT 2002
Our Lady of blessed acceleration
Originally Posted by Black&Tan View Post
But.... why read facts and investigate a claim when it supports your ideology?
...that should be written as 'The First Law of Internet Forums'
Chris_HT is offline
Old 08-22-2012, 02:38 PM   #5
scott7278
Fan#: 100021
What I Drive: 2012 Red Candy SEL Hatchback
Points 1,506, Level 22
Points: 1,506, Level: 22 Points: 1,506, Level: 22 Points: 1,506, Level: 22
Level Up 6% Completed
FF Reputation: 5 scott7278 Good Standing Member
Originally Posted by suznal View Post
Thanks,
Tell them to look around the cashier counter - they always have dialectric grease in single-use packets. From there, they can find the bigger bottle (hopefully).
It's also known to those guys as bulb grease.
scott7278 is online now
Old 09-04-2012, 11:27 AM   #6
suznal
Fan#: 102830
Points 390, Level 7
Luck!
OK, I was about to tackle it this weekend, but I received conflicting information about using the grease on the connectors.
I was told that if i grease the pins and re-connect, if the pins don't make actual metal-to-metal contact that it could screw things up even further. I did some looking around on the internet and found information backing this up.
Can I disconnect the connectors, clean up the contacts, put the grease on the pins and re-connect without a problem?
suznal is offline
Old 09-05-2012, 08:04 AM   #7
Now534
Now534's Avatar
Fan#: 76549
What I Drive: 2013 Tuxedo Black ST2
Points 1,793, Level 24
Points: 1,793, Level: 24 Points: 1,793, Level: 24 Points: 1,793, Level: 24
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
FF Reputation: 6 Now534 Good Standing Member
They will still make contact. Go ahead and put the grease in. If you put to much in it will be just a little stiff to push in but it is pushing the excess grease out in any available openings. We use it all the time at work in lights and harnesses and what not.
Now534 is online now
Old 09-13-2012, 10:42 AM   #8
suznal
Fan#: 102830
Points 390, Level 7
Thanks Now534
Do you put the grease on the pins or do you spread it on the female half of the connecter?
suznal is offline
Old 10-07-2012, 07:44 PM   #9
Now534
Now534's Avatar
Fan#: 76549
Sorry for the late reply i normally just squeeze a little across the connector so it pushes it in. Then just connect it.
Old 10-07-2012, 11:12 PM   #10
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Grease won't affect the electrical connection, it will just prevent water from getting in there and making cross connections or affecting the electrical. Use as much as you like. You can purchase bottles of the stuff. It's typically somewhere near the RTV, glue, brake anti-squeal, anti-seize, etc.
You can also use it on battery terminals- inside and out- to prevent corrosion. That's an old trick, except we used to just use whatever grease was on hand. Most grease is non-conductive.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
