thermostat housing problems - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-24-2012, 11:13 PM   #11
RedSVTrocket
RedSVTrocket's Avatar
Fan#: 100373
What I Drive: 2002 Red SVT, 2001 Excursion
FF Reputation: 1 RedSVTrocket Good Standing Member
You will also need the coolant sensor from the same car, since the SVT is a push in sensor vs the screw in type on the contour housing.
RedSVTrocket is offline
Old 08-25-2012, 12:19 AM   #12
bradshsi
bradshsi's Avatar
Fan#: 58770
What I Drive: 2002 Sonic Blue Turbocharged SVT
Points 326, Level 6
Points: 326, Level: 6 Points: 326, Level: 6 Points: 326, Level: 6
Level Up 52% Completed
FF Reputation: 6 bradshsi Good Standing Member
Buy-Sell-Trade Rating: (4)
CFM is your best bet. I had a similar thermotat housing from a now defunct company and I'm very happy with it.
Sona si latine loqueris
bradshsi is offline
Old 08-27-2012, 10:55 AM   #13
02svtf300
02svtf300's Avatar
Fan#: 83769
What I Drive: 2002 sonic blue SVT(moded)
FF Reputation: 2 02svtf300 Good Standing Member
Doesn't massive performance or top speed make a fancy aluminum...?
02 sonic blue svtf...< modified addiction < DD
88 bronco II (x2)... < the twins
00 yamaha banshee... <will be the end of me
02svtf300 is offline
Old 08-31-2012, 10:36 AM   #14
2004svtfordfocus
2004svtfordfocus's Avatar
Fan#: 102787
What I Drive: 2004 red focus svt
Points 275, Level 5
Points: 275, Level: 5 Points: 275, Level: 5 Points: 275, Level: 5
Level Up 50% Completed
FF Reputation: 1 2004svtfordfocus Good Standing Member
ok thanks everything works great awesome
2004svtfordfocus is offline
Old 09-12-2012, 02:48 PM   #15
qdenning
Fan#: 77729
What I Drive: 2003, Screamin Yellow, SVT Focus
FF Reputation: 1 qdenning Good Standing Member
I wish I had seen this sooner - just had mine replaced.
qdenning is offline
Old 09-12-2012, 03:18 PM   #16
Peregrine
I.S.A.I.K.I.
Peregrine's Avatar
Fan#: 6009
What I Drive: '03 CD Silver SVT, '11 Mazda CX-9
FF Reputation: 112 Peregrine Excellent Standing Member Peregrine Excellent Standing Member
Buy-Sell-Trade Rating: (23)
Nothin' from Massive that I've seen and TS still hasn't been released since I last checked. That was a month ago
Peregrine is offline
Old 09-12-2012, 07:27 PM   #17
Hempster
Hempster's Avatar
Fan#: 29310
What I Drive: 2014 Tuxedo Black Focus ST3
Points 739, Level 14
Points: 739, Level: 14 Points: 739, Level: 14 Points: 739, Level: 14
Level Up 39% Completed
FF Reputation: 3 Hempster Good Standing Member
...or you could just properly maintain the original one, as it is most often oil leaking down the head that causes the large sealing o-ring to swell and crack the housing.
I do wonder what will eventually happen when the oil returns and swells the o-ring in your new, "stronger" and "improved" housing, what will now break, hopefully nothing as cheap as the original housing.
My solution was to change to Vitron o-rings for the sensor and plug, cost $1.00, no leaks after over two years, cross my fingers and knock on wood!
Fortunately/unfortunately it's maintanance that causes most of our little car's problems, not the design!
Tuxedo Black 2014 Focus ST3
CD Silver 02 SVTF, #1336 - R.I.P.
"Brace for the G's, and fast heel-toe work!"- Hunter S. Thompson
Hempster is offline
Old 09-13-2012, 08:17 AM   #18
Peregrine
I.S.A.I.K.I.
Peregrine's Avatar
Fan#: 6009
Completely wrong. The design flaw is putting a valve cover relief hole right above the Tstat housing.
I believe that if the SVT was marketed for a couple of more years, this little issue would've been taken care of.
Old 09-13-2012, 11:35 AM   #19
02svtf300
02svtf300's Avatar
Fan#: 83769
Never had that problem mine leaked from the Weep hole on bottom.... and my CfM one leaks from the temp senser occasionally
Old 09-13-2012, 05:49 PM   #20
Hempster
Hempster's Avatar
Fan#: 29310
I doubt you really know what you are talking about and you should consider this when replying.
The relief hole should never be an issue if you maintain your car properly.
Oil should be housed in the engine block and not running down the head.
Before you buy that useless intake, header or inferior coil pack, fix the issues that need addressing!
The biggest issue this car has is children purchasing this car and driving the $&^* out of them!
This is the reason the European versions suffer no issues with the thermostat housing, clutch or anything else that seems to be complained about over and over on these kind of "specialty" websites.
The cars are basically the same, just different owners!
Sometimes I get a good laugh at people on FF or FJ coming up with a new engineering, thinking that they are more capable than an establish car manufacturer or F1 engineering firm.
I drive my car the way it was intended and maintain it like it should be maintained.
That's why I don't have the issues you are so eager to give advice about!
The SVT Focus costs more to own and operate than its domestic sibling and it should, it was designed that way!
Sorry for being so harsh, but your reply seemed so ignorant and disrespectful!
Hempster is offline
