Ford Racing handling kit now available - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-24-2012, 12:13 AM   #41
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,810, Level 76
Points: 13,810, Level: 76 Points: 13,810, Level: 76 Points: 13,810, Level: 76
Level Up 40% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
Originally Posted by Sonic_HedgeHog View Post
Axle back is a waste of money and the time to install it
Totaley ^
felixthecat is online now
Old 08-24-2012, 07:23 AM   #42
SterlingArcher
Fan#: 100651
What I Drive: 2012 SE hatch, Sterling Gray
FF Reputation: 1 SterlingArcher Good Standing Member
Yeah, truth is there's nothing I've seen that really excites me exhaust wise. I'm sticking with my suspension and style goals, and thats about it. Plus I learned with my other cars that exhaust tends to invite every DB with a 90's era 100hp Civic to want to race me at every stop light, and thats not what I do. I've enjoyed being left alone the last few months since I got the Focus.
SterlingArcher is offline
Old 08-24-2012, 10:11 AM   #43
nerdrage
nerdrage's Avatar
Fan#: 100392
What I Drive: 2012 Focus SEL Ingot Silver
FF Reputation: 1 nerdrage Good Standing Member
Tire Rack now has the Eibach Sport-System Plus Kit up on their site now... $424. Might give Ford a run for its dollars!
I called eibach about this because its not on their website. They are not making dampers for the Focus. Tirerack was supposed to fix this 2 months ago when I saw this kit and tried to pre-order it.
Here is the actual kit on Eibachs website
SPORT-PLUS (SPORTLINE Springs & ANTI-ROLL-KIT Sway Bars
nerdrage is offline
Old 08-24-2012, 11:22 AM   #44
Joey D
Joey D's Avatar
Fan#: 86391
What I Drive: 2012 Tuxedo Black Titanium 5-Dr
FF Reputation: 2 Joey D Good Standing Member
Why would you have a handling kit without dampers? You'll blow the OEM ones really quick, especially if you're lowering the car at all.
Joey D is offline
Old 08-24-2012, 11:44 AM   #45
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
Points 1,277, Level 19
Level Up 77% Completed
Is that a sure thing? There are several members on here running Sportlines or Steedas with stock dampers, and haven't heard of any issues.
Hatch Nation #90
TboneZX3 is offline
Old 08-24-2012, 11:53 AM   #46
Joey D
Joey D's Avatar
Fan#: 86391
No issues yet, but the dampers will wear out prematurely. You're using the damper in a way it wasn't intended to, not to mention you're screwing even more with the suspension geometry. Just about every company that sells lowering springs recommends replacing the damper with ones made for a lowered vehicle.
I refuse to lower mine until the proper stuff is made available for the car and I know it isn't cheaply made. Koni yellows and lowering springs are the way to go if you want low without coilovers. The Koni's will last and your ride won't be horrid.
I've owned three lowered vehicles and I ran a 2" drop on my Blazer for a while with OEM struts. They lasted maybe 5,000 miles after I dropped it and the truck didn't have that many miles on it when I did it either. But I ripped everything out, put a 7" drop on it with struts made for a lowered vehicle and ran em for 25,000 miles with no issues. I learned with the other two cars just to do it right the first time.
Joey D is offline
Old 08-24-2012, 12:24 PM   #47
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 JCW GP
Points 2,504, Level 30
Points: 2,504, Level: 30 Points: 2,504, Level: 30 Points: 2,504, Level: 30
Level Up 36% Completed
FF Reputation: 27 Zillon Great Standing Member
The only real option right now is to just buy the ST dampers, as I have, since the ST is a half inch lower than other Foci, and those dampers should be up to the demands of handling a higher spring rate and lower ride height.
Konis are a great choice, but I don't think we're going to see a dedicated Mk3 Focus fitment from Koni for a little while. If I had my pick, though, I'd go with Bilsteins.
I've called both companies to get an estimated ETA, and both have given me answers that leave me with no real timeline for expecting product on US shores anytime soon. If anything, we might see something from Bilstein sometime in the next year, as they at least have part numbers listed for the Euro Focus, but good luck finding those parts over here.
The Mazdaspeed3 fitment won't work because the distance from the knuckle to the strut tower is shorter, and the MS3 spring buckets are higher on the strut body. When compared to a Mk3 specific fitment, the MS3 dampers will leave the front of your car sitting higher than it would otherwise.
Joined the dark side.
Zillon is offline
Old 08-24-2012, 04:59 PM   #48
nerdrage
nerdrage's Avatar
Fan#: 100392
Originally Posted by Zillon View Post
The only real option right now is to just buy the ST dampers, as I have, since the ST is a half inch lower than other Foci, and those dampers should be up to the demands of handling a higher spring rate and lower ride height. .
Where'd you get the ST dampers from? Price? Part numbers from Ford?
nerdrage is offline
Old 08-24-2012, 05:47 PM   #49
SterlingArcher
Fan#: 100651
That makes much more sense, there was no way that kit was $424 with dampers. A little odd that tirerack hasn't updated their site, and flat out told me that it does come with dampers. They're usually much more reputable.
Old 08-24-2012, 07:10 PM   #50
Sonic_HedgeHog
Sonic Mk3 Crew #00
Sonic_HedgeHog's Avatar
Fan#: 50003
What I Drive: '12 Sterling Focus SE 5dr Sport Pkg
Points 126,755, Level 100
Points: 126,755, Level: 100 Points: 126,755, Level: 100 Points: 126,755, Level: 100
Level Up 0% Completed
FF Reputation: 19 Sonic_HedgeHog Great Standing Member
Check the clunk thread and the new ST Part thread
Hatch Nation #156. Sonic's Mk3 Crew Founder and #00
Moderator: DURATEC Ti-VCT Performance, ST Performance, MK3 Focus, SW Fanatics, Sonic's MK3 Crew
Sonic_HedgeHog is offline
