Running a bit rich - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-23-2012, 10:49 PM   #11
2003 Ford Focus
2003 Ford Focus's Avatar
Fan#: 91951
What I Drive: '03 Focus SE and '03 ZTW
Points 1,312, Level 20
Points: 1,312, Level: 20 Points: 1,312, Level: 20 Points: 1,312, Level: 20
Level Up 12% Completed
FF Reputation: 4 2003 Ford Focus Good Standing Member
Smile
Originally Posted by VEGAS View Post
you used a sealer? for a head? why not repair/replace head?
Thanks for the reply. Figure the machine shop should have found it during the clean and milling.
Too much spent already. Once I discovered the cracked head, the cost becomes unmanageable ($200+ for the reman head; - over the $700+ already spent). Car isn't worth it. So we patched it and will drive it until it dies, unfortunately.
I don't like chemicals either. But this was a last ditch effort to get it to run right.
First Ford: '62 Falcon Futura 2-door / Modified Production 302 / 270 HP / Close Ratio 4-speed / 3.50 ratio 8" Fairlane Differential (289-271 HP cam / heads / exhaust / medium high rise / 600 CFM Holley / dual-point) Low 15's at 90+ MPH
2003 Ford Focus is offline
Old 10-20-2012, 12:06 PM   #12
2003 Ford Focus
Fan#: 91951
Smile
Well ya, temporarily, but eventually did the right thing and pulled the head a third time! I can do this in my sleep now. Can almost make flat rate now!
Turned out the head wasn't cracked, just not sealing well between #3 and #4.
Root cause of the leak: Cylinder head bolts could not bottom because the backyard mechanic neglected to clear all the old oil from the cavity below the threads in the block. So while I got a good torque reading, the bolts would hydraulic on the old oil.
Red faced and embarrassed I am.
Running fine now, 200 lbs compression across four cylinders, no pressurized cooling system and oil consumption dropped significantly.
"I love it when a plan comes together!" - Hannibal Smith, The A-Team
