2.0L head swap for a 2.3L Duratec - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Tech Discussions > Engine & Transmission Swap
Engine & Transmission Swap The place to chat about any engine and transmission swap.
Old 08-18-2012, 12:46 PM   #1
NOSfusion
NOSfusion's Avatar
Fan#: 102748
What I Drive: 05' Ford Focus ZX4 2.0L Duratec
FF Reputation: 1 NOSfusion Good Standing Member
Hey. So, my 2.0L Duratec head (2005 Focus) is about to take a $h!t. Can I put a 2.3L head onto a 2.0L bottom end? Has anyone done this swap? Am I crazy or is this possible? Assuming this is okay, would I need a 2.3L harness/ECU? If I have to replace the head I figured I would try and get a little more bang for my buck.
Thanks in advance... be gentle
NOSfusion is offline
Old 08-18-2012, 12:50 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,506, Level 100
Points: 52,506, Level: 100 Points: 52,506, Level: 100 Points: 52,506, Level: 100
Level Up 0% Completed
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
Buy-Sell-Trade Rating: (28)
Yes it can and has been done , I did this swap back in 2005 , it would be best to also swap the 2.3 intake and use the 2.3 cams
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 08-18-2012, 01:09 PM   #3
NOSfusion
NOSfusion's Avatar
Fan#: 102748
Sweet. Any idea as to where I could get a decent 2.3L head, cams and intake? And will the 2.3 bolt right on?
Wins:
1991 VW Corrado G60, 1989 Ford Mustang, 1996 Acura Integra, 1995 VW Jetta, 1996 Honda Civic, 1999 Honda Del Sol, 2002 Ford Focus, 2010 Ford Focus
Losses:
1996 Honda Civic Type R, 2004 Ford Focus SVT
Old 08-18-2012, 02:11 PM   #4
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 61%
It will bolt right on , I would surface the head about .015 and add some cams , would be the perfect time , then add a tune
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 08-18-2012, 03:26 PM   #5
Minchkin
Minchkin's Avatar
Fan#: 92792
What I Drive: 2009 Black SES Coupe
Points 948, Level 16
Points: 948, Level: 16 Points: 948, Level: 16 Points: 948, Level: 16
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 3 Minchkin Good Standing Member
What would this do, exactly? And would this be possible on a 2nd gen?
Originally Posted by Fact Core from Portal 2
Before the Wright Brothers invented the airplane, anyone wanting to fly anywhere was required to eat 200 pounds of helium.
SES #032
Minchkin is offline
Old 08-18-2012, 07:22 PM   #6
WSkobra
Fan#: 93397
What I Drive: 2007 Focus SE 4dr Dark Shadow Gray
Points 675, Level 13
Points: 675, Level: 13 Points: 675, Level: 13 Points: 675, Level: 13
Level Up 50% Completed
FF Reputation: 1 WSkobra Good Standing Member
This helps me out a lot. I have an 07 2.0L dtec and have been thinking about doing this head swap. Probably would be a good idea to replace your water pump while your at. If you do this let me know what kind of gains you get.
WSkobra is offline
Old 08-18-2012, 09:36 PM   #7
NOSfusion
NOSfusion's Avatar
Fan#: 102748
Absolutely. I plan to make the change here in a few weeks. Ill take pictures as I go and upload them when I can. As for a water pump, I am thinking about doing a complete rebuild since I will be replacing the head. Intake, cams, Water pump, rings, alternator, belts, plugs, and maybe even my coil packs.
Wins:
Losses:
Old 08-18-2012, 09:46 PM   #8
NOSfusion
NOSfusion's Avatar
Fan#: 102748
More power. When you bolt a 2.3 head on a 2.0 block, you get instant improvement in flow through the head and can make more HP at higher RPM. Add a header, a decent intake manifold and some stage I or II cams and you can easily get about 180-190 WHP from the 2.0L engine, depending on your tune and type/octane of fuel used.
PS: not sure about the 2nd gen thing... ask around. Someone has to know. In theory, you can.
Wins:
Losses:
Old 08-18-2012, 09:53 PM   #9
Minchkin
Minchkin's Avatar
Fan#: 92792
The Dtec in my car is the same as the 07, so I think I would just need a tune.
SES #032
Minchkin is offline
Old 08-20-2012, 06:59 AM   #10
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
Points 19,182, Level 87
Points: 19,182, Level: 87 Points: 19,182, Level: 87 Points: 19,182, Level: 87
Level Up 67% Completed
Forum Activity 7%
FF Reputation: 7 badazz2010focus Good Standing Member
I think theres some constraints on 2 g guys because of the throttle by wire and the cht sensor I'm not sure what years use it.
badazz2010focus is offline
