2003 SVT turns over but wont start - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-17-2012, 02:31 PM   #1
Allaboutit
Fan#: 102720
What I Drive: 2003 Silver SVT
FF Reputation: 1 Allaboutit Good Standing Member
Hello,
I have a 2003 focus svt that turns over but will not start.
I had it in the shop last week and they told me that all 4 plugs were dripping with fuel when they removed them. They said they took them out for a couple hours to air dry and put them back in and it started fine.
I talked to the mechanic directly and he just said its pry a sensor but he wasnt for sure. BTW this was a ford dealership.
I drove the car home and it ran fine. But now i went to drive it yesterday and now it wont start again.
I noticed that it had died on me briefly when coming to a stop but then would start up right away again. This only happend twice though over the last few weeks leading up to it not starting.
Another thing to mention is that i do park it on an incline if that makes any difference.
Any ideas what might cause this?
Or does anyone know what sensor it might be?
Allaboutit is offline
Old 08-17-2012, 04:16 PM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,517, Level 100
Points: 52,517, Level: 100 Points: 52,517, Level: 100 Points: 52,517, Level: 100
Level Up 0% Completed
Forum Activity 62%
Activity: 62% Activity: 62% Activity: 62%
Buy-Sell-Trade Rating: (28)
Very hard to say , not enough info , do you have a xcal to datalog with or barrow , only thing I can think of that would do this would be the mass air and TPS but they both would have to be bad at the same time
Injector drivers in the ECU could do this but every time I have seen a Inj driver go out they stayed bad
If you kept trying to start it over and over then the fuel in there could of come from that , the plug in on the coil is known to go bad and the crank trigger sensor rub the end off over time , these can be checked by the eye
What did Ford say ?
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 08-17-2012, 04:29 PM   #3
Allaboutit
Fan#: 102720
Thanks for your reply.
Ford really hasnt been much help. They more or less said bring it back in.
l will take another look at the car when i get home to try and get more info.
Old 08-20-2012, 12:29 PM   #4
Allaboutit
Fan#: 102720
Noob question but what is a xcal? is that like a diagnostics tool?
If so what would you recommend if i were to buy one?
Old 08-20-2012, 12:56 PM   #5
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 62%
www.sctflash.com is who makes the xcal
I wouldnt buy one just for this , check your state in the forums here and see if some one local has one and is willing to come over on the weekend and see whats happening , I will be glad to help with this and get you logging , I can do this just like I was sitting in the car with you over the internet
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 08-20-2012, 08:23 PM   #6
Allaboutit
Fan#: 102720
Over the weekend i decided to try starting it after holding the gas peddel to the floor for a sec. I was informed that this might help if the motor is flooded.
The motor instantly made a loud pop sound when i turned the key.
I tried starting it again normally and it went back to the same thing turning over but not starting.
Anyways i was just in it again and tried starting it normal for the hell of it and it made the loud pop sound (like all my neighbors heard it). I got out to look under the hood and my air intake? the black plastic piece that connects my ram air to my motor, was half way off my motor!
Old 08-21-2012, 10:58 AM   #7
Allaboutit
Fan#: 102720
I found a local mechanic that is willing to come to my house this afternoon and data log for me.
I will post back with the results
Old 08-21-2012, 01:04 PM   #8
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,402, Level 75
Points: 13,402, Level: 75 Points: 13,402, Level: 75 Points: 13,402, Level: 75
Level Up 38% Completed
Forum Activity 99%
Backfire from starting when flooded blew the intake off from your description, hopefully nothing broken - but you'll need to reinstall, pull plugs and dry things out B4 another starting attempt.
Foot to the floor clears a flooded engine, even with electronic systems 9it's designed to work that way) BUT you need to do it BEFORE there's a LOT of unburned fuel in there!
Luck!
sailor is online now
Old 08-21-2012, 05:37 PM   #9
Allaboutit
Fan#: 102720
I am putting the intake back together with a little help from my uncle and his friend with the code reader.
The code it reported was..
P0303 cylinder 3 misfire (stored)
and cylinder 2 misfire (pending)
Old 08-21-2012, 07:26 PM   #10
Missourileo
Captain Retard
Missourileo's Avatar
Fan#: 55980
What I Drive: 2002 Black SVT ZX3,93 SVT Lightning
Points 5,373, Level 47
Points: 5,373, Level: 47 Points: 5,373, Level: 47 Points: 5,373, Level: 47
Level Up 12% Completed
FF Reputation: 20 Missourileo Great Standing Member
Buy-Sell-Trade Rating: (17)
Bad coil or pigtail(wires going into the coil)?
"It's the Veteran who salutes the flag, serves beneath the flag, and whose coffin is draped by the flag."
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Missourileo is offline
