2nd time around, need some ideas, SPI will not stay running - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-17-2012, 11:55 AM   #1
ponddogs
Fan#: 101885
What I Drive: 2003 white focus
FF Reputation: 1 ponddogs Good Standing Member
2003 SPI engine, bought the car with a pining noise when accelerate and wanting to die after the engine warm up, ford house said bad gas, drained fuel tank 3 times, change out filter 3 times and the in-tank fuel pump, change out plugs, wires, coil pack, crank sensor and cam sensor, had the engine cat tested for back pressure, had the fuel injectors checked, getting 35 psi at injector rail, then engine drop number 1 cylinder valve exhaust seat, change out head assy, piston and piston rod, timing belt and engine gasket set, engine would not start, back to ford house, they said engine oil pump is not working, change out pump, oil light now goes out when cranking but when cranking engine it's sound like if the engine timing is too far advance, had the ECM reflashed, rechecked the engine timing belt both dots and key way locations, checked the engine compression 160 160 155 160, change out the throttle body off a running focus, now if you pour some fuel in the throttle body it will start but only stay running if you feather the throttle and the pining noise is back with a miss, no engine codes, any ideas will help
ponddogs is offline
Old 08-17-2012, 12:11 PM   #2
MEJY1988
Fan#: 101883
What I Drive: 2006 Burgandy ZX5
Points 160, Level 3
Points: 160, Level: 3 Points: 160, Level: 3 Points: 160, Level: 3
Level Up 20% Completed
FF Reputation: 3 MEJY1988 Good Standing Member
IMO, if you have 35 psi at fuel rail, but need to dump fuel into throttle body to get it started, you either have a clog in the fuel rail, faulty injectors, or the injectors are not firing. You can get noid lights to check the voltage at the injectors. I would start there.
Good luck.
MEJY1988 is offline
Old 08-18-2012, 11:41 AM   #3
ponddogs
Fan#: 101885
Thanks for diffrent starting point, I will order a noid light set today, Question ? what control the engine timing, crank, cam and ECU, since I have change out crank and the cam sensors and had the ECU reflashed would it be worth the money to have another ECU reporgram, because I found out you just can't swap them out
ponddogs is offline
Old 08-19-2012, 01:27 PM   #4
ponddogs
Fan#: 101885
got the noid light set today and went out and tested the fuel system, no light when cranking the engine, I even tested the kit on a running focus to see if it was working, also replaced the wire harness from the firewall to the engine, no light, is there a way to test the ECU without taking it to the ford house?
ponddogs is offline
Old 11-18-2012, 11:26 AM   #5
ponddogs
Fan#: 101885
it's runs, time to sale it
Well after thousands of hours of working on this thing, I finally got it and had to take it to the ford house 5 times, without any luck. took it to the ford house to have a new ECU install, still nothing, they said everything is working the way it's supposed to, but the engine sounded liked it was out of time, well to make a long story short, before I bought the car the owner had the head replaced (didn't know) and they changed out the harmonic balancer with a china replacement, well the timing clods that are press on was not a real tight fit and was moving, did not see this at until I sat a old harmonic balancer on top of the china replacement, it was off almost 45 degrees, put on the old balancer and it started right up, unbelievable
ponddogs is offline
Old 11-18-2012, 02:27 PM   #6
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,726, Level 73
Points: 12,726, Level: 73 Points: 12,726, Level: 73 Points: 12,726, Level: 73
Level Up 69% Completed
Forum Activity 99%
"Unbelievable" seems to cover it....
That's definitely a "New One" for a no start problem...
sailor is online now
Old 11-18-2012, 03:35 PM   #7
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,629, Level 94
Points: 23,629, Level: 94 Points: 23,629, Level: 94 Points: 23,629, Level: 94
Level Up 28% Completed
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
agh...
mikebontoft is online now
