Adding puddle lamps? - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-29-2012, 03:18 PM   #21
champjfocus
champjfocus's Avatar
Fan#: 96072
What I Drive: 2009 Ford Focus SES in Sangria Red
Points 4,379, Level 42
Points: 4,379, Level: 42 Points: 4,379, Level: 42 Points: 4,379, Level: 42
Level Up 15% Completed
FF Reputation: 1 champjfocus Good Standing Member
The lights do not and I went back to the place I got it installed and they are not there anymore. Apparently after 30 years he and his family decided to stop so as of now no one is holding my warranty.
SES #035:
LED plate lights, LED map lights, LED cargo lights, remote start system, Sylvania LEDriving reverse lights
champjfocus is offline
Old 04-20-2014, 01:00 PM   #22
VTEK1
Fan#: 59607
What I Drive: 2014 Blue Focus SE
Points 208, Level 4
Points: 208, Level: 4 Points: 208, Level: 4 Points: 208, Level: 4
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
FF Reputation: 1 VTEK1 Good Standing Member
I know this is a wicked old thread but how do you get the power from the interior lights to the door? Is there wiring already running to door? I looked for factory install puddle lights in the wife's 2010 but there doesn't seem to be any sockets or wiring under the dash.
VTEK1 is offline
Old 04-20-2014, 05:54 PM   #23
Snyper
Snyper's Avatar
Fan#: 96688
What I Drive: 2009 Black SE
Points 1,478, Level 21
Points: 1,478, Level: 21 Points: 1,478, Level: 21 Points: 1,478, Level: 21
Level Up 78% Completed
Forum Activity 3%
FF Reputation: 2 Snyper Good Standing Member
I did this with a simple LED strip and spliced into a wire up in the A pillar. It comes on when I open the door and shuts off shortly after closing the door, just as the map lights do. The strip is weather proof.
I plan on adding a similar light under the door as well, but have yet to get that far.
Snyper is offline
Old 04-22-2014, 08:28 PM   #24
VTEK1
Fan#: 59607
Points 208, Level 4
any chance you could identify that wire for me? color stripping? Thanks for the help!
VTEK1 is offline
Old 04-24-2014, 10:39 PM   #25
andermac
Fan#: 158130
What I Drive: 2008 Silver SE
Points 156, Level 3
Points: 156, Level: 3 Points: 156, Level: 3 Points: 156, Level: 3
Level Up 12% Completed
FF Reputation: 1 andermac Good Standing Member
Here's mine, just have a 12v charger > Wire connection to a few LED strips around the car. Adhesive doesn't work well underneath the door but it looks decent. I am going to redo the entire setup soon, once I get more wire.
3 Strips in the pic, One in the door "pocket", and one underneath that. One under the dash, it isn't as obnoxious when driving.
andermac is offline
Old 04-24-2014, 11:50 PM   #26
Snyper
Snyper's Avatar
Fan#: 96688
Forum Activity 3%
How did you tuck the wires for the pocket light and the one under the door? Also, 3M tape should hold the LED's up. It's holding my rear spoiler on, lol.
http://www.focusfanatics.com/forum/s...ated+door+sill
I followed this How To. Very easy to do. The wire is listed there for you.
Snyper is offline
Old 04-25-2014, 07:45 AM   #27
andermac
Fan#: 158130
Points 156, Level 3
Didn't really "hide" the wires technically. At this point most are exposed because I wasn't going to get too far into it this winter. Like I said, I will be redoing the wiring hopefully hiding some more wires, but it probably won't be easy to get those ones out of the way. I got as much wire as I could under the dash and into the rubber trim on the rim of the door/frame. I have some more lights in the back that those just joined with.
The tape won't work because of the texture on the door. It doesn't hold any of the tapes I would normally use, I have some black paint/rubber holding it on. Its not a strong bond, but enough that I won't have to do much to take it off.
I like what you did with yours, I might be switchin it up to that, just need to find some cheap wire.
andermac is offline
Old 04-25-2014, 08:47 AM   #28
Snyper
Snyper's Avatar
Fan#: 96688
Forum Activity 3%
Best bet to get those ones out of the way would be to poke a hole in the door panel and wire the line through that. And then slide the wire under the door panel for the light under the door. Makes the job much more in depth, but leaves for a clean installation.
Snyper is offline
Old 04-30-2014, 11:26 PM   #29
VTEK1
Fan#: 59607
Points 208, Level 4
Thank you Snyper for the help. Great write up.
VTEK1 is offline
