Wideband A/F Gauge Install With FSwerks Header - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 08-09-2012, 12:32 AM   #1
matmatician
Cars&Corgis
matmatician's Avatar
Fan#: 81361
What I Drive: A ONE COLOR FOCUS, Ducatis
Points 7,177, Level 56
Points: 7,177, Level: 56 Points: 7,177, Level: 56 Points: 7,177, Level: 56
Level Up 14% Completed
Forum Activity 3%
FF Reputation: 4 matmatician Good Standing Member
If you're anything like me, and want to install your AEM Wideband UEGO A/F gauge, but need pictures to learn how to do anything, you're in luck. I'm going to show you how, in the fashion that I need things explained to me in (aka, like a 4 year old, with pictures, and big red crayon.) I searched forever before I started spending money and time, so hopefully I can help someone save some time with this write up. So off we go.
The first thing I would need is a hole welded into the exhaust with a bung for the new 02 sensor to plug into. Unfortunately, I didn't know where to put it. After calling AEM and talking to an exhaust specialist, I found out the answer is in the flex pipe, after the collector, and before the 2nd cat, illustrated here.
NOTE: I mislabeled the picture. The wire goes up towards the engine bay, of course.
The next thing I did was drill a hole in the firewall to get the cable to the 02 sensor. There was probably a better place for this, and if you do drill here, make sure its RIGHT there, because if its not, or you get the angle wrong, you may hit something on the other side of the firewall. Measure twice, drill once.
This is just to the left of the clutch pedal if you have an MTX
Another shot for clarity:
This is also how I secured the massively long cable after it was routed.
Next, I had to route the cable to the 02 sensor. Pretty easy stuff. Keep it away from heat so that it doesn't melt, and try to keep it in a place where it won't get too much exposure to water.
The green is the route i ended up following. Using zipties, I secured the cable to the black existing cables that go under the fusebox
This is where I have the cable feeding up to the dash to plug into the gauge. If you're going to use a gauge pod, your route will probably vary a little bit. There is a small catch securing that part of the plastic to the frame. It pops off pretty easy.
After the cables have been run, you'll need a way to get power to the gauge its self. Instead of splicing into a live wire (which I HATE doing, I'm weird, I know) I bought a littelfuse add-a-fuse kit from O'reily for 6 bucks. You'll only need 1, I got a second one for another project.
With that, wire the littelfuse to the red wire coming from the A/F gauge:
Then, wire it into the fuse shown below, I believe its fuse 48.
If you've done everything right, and hooked into the right fuse, your gauge should now work! If the gauge doesn't turn off when you power off the car, its hooked into the wrong fuse. Just make sure its a 10amp fuse (that's what the instructions say)
Soon, I'll add in a walkthrough on datalogging. I'm still trying to figure things out. I need to call SCT and get things hammered out first. More to come!!
Originally Posted by BertST View Post
Hop on in babe! No really, you're gonna have to hop in. Roll Cage.
ROTM June '13, PNW Crew #42, SR #245, Rally Rev #02
matmatician is offline
Old 08-09-2012, 05:44 AM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,521, Level 100
Points: 140,521, Level: 100 Points: 140,521, Level: 100 Points: 140,521, Level: 100
Level Up 0% Completed
Forum Activity 55%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Moved your thread to the Duratec performance chat area since you don't have a technical problem. If you get good pics and stuff we can even sticky it to the how to archive.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 08-09-2012, 11:22 AM   #3
YellowJellyBean
Love CA / Hate CARB
YellowJellyBean's Avatar
Fan#: 69030
What I Drive: MÜSTÄRD
FF Reputation: 13 YellowJellyBean Great Standing Member
Very nice, I love when people take pictures to show what's going on :]
"My yellow, in this case, is not so mellow" -Jimi Hendrix
Focus Fanatics
Extremely helpful people
I made a haiku
YellowJellyBean is offline
Old 08-09-2012, 02:13 PM   #4
matmatician
Cars&Corgis
Fan#: 81361
Forum Activity 3%
I may get my very own sticky??
I'm way too excited about that lol :P
Old 08-11-2012, 03:05 PM   #5
Slammed_2.0
Boosted HB.
Slammed_2.0's Avatar
Fan#: 84306
What I Drive: 2013 TB ST
Points 6,542, Level 52
Points: 6,542, Level: 52 Points: 6,542, Level: 52 Points: 6,542, Level: 52
Level Up 96% Completed
FF Reputation: 20 Slammed_2.0 Great Standing Member
Buy-Sell-Trade Rating: (4)
Great write up.
I didnt drill anything. Just stuck it through the rubber grommet through the firewall inside driver fender well.
2013 Ford Focus BOOS[ST]ED
2010 Ford Focus "S"edan (11 Psi, GT28RS) - Sold
ROTM Nov '11 (2010 Focus S)
Slammed_2.0 is offline
Old 08-11-2012, 03:40 PM   #6
matmatician
Cars&Corgis
Fan#: 81361
Forum Activity 3%
I think that yours may be different on the 2010, but I did see (after I drilled, of course) that there is a pretty big grommet by the gas pedal. I didn't even look to see if the cable would fit through there though. May be worth someone checking into in the future.
And thanks!
Old 08-11-2012, 04:18 PM   #7
Slammed_2.0
Boosted HB.
Fan#: 84306
I didn realized ur 1.5 gen.
Still a great write up
Old 08-11-2012, 06:44 PM   #8
matmatician
Cars&Corgis
Fan#: 81361
Forum Activity 3%
Thank you, I'm going to try to get this as easy as possible for noobs like myself to do lol. I'm also going to try do some things that no one has done yet, like how to datalog with the new TSX for android app. And, I'm going to try to make the signal from the wideband gauge go through a USB 3.0 cable since no one has firewire anymore.
Old 08-15-2012, 11:51 AM   #9
matmatician
Cars&Corgis
Fan#: 81361
Forum Activity 3%
Bump for new information!
Old 11-27-2012, 06:50 PM   #10
StephenElsbree1986
StephenElsbree1986's Avatar
Fan#: 104271
What I Drive: CD Silver 2003 SVT
Points 1,167, Level 18
Points: 1,167, Level: 18 Points: 1,167, Level: 18 Points: 1,167, Level: 18
Level Up 67% Completed
Forum Activity 3%
FF Reputation: 1 StephenElsbree1986 Good Standing Member
Little old thread and I'm not a Dtec and this is a digital Wideband but beside that, could I do the same thing for an analog wideband since it has two red wires? Or do I need to go a diffrent route
StephenElsbree1986 is offline
