'07 ST charging light wont extinquish - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus SVT > Focus SVT
Focus SVT The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK1 2002-2004 Focus SVT.
Old 08-07-2012, 02:14 PM   #1
4flattires
Fan#: 76250
What I Drive: 2007 ST
FF Reputation: 2 4flattires Good Standing Member
Hi all, looking for qualified help here. The application is noted in the title.
The background was a bad regulator, where one brush was sticking. I've replaced the VR and had new slip rings installed. Alternator puts out 14.1 volts (bench test and on-vehicle) and there are no "charging" issues now.
The charge light will illuminate as normal with the key on/engine not running. It stays UNLIT for 23 seconds, then...without fail after 23 seconds...every run cycle the light will then LIGHT UP for the duration of the engine run cycle.
Belt is fine, grounds are no issue, battery fully checks out (load/proper group size/CCA's). I have all this test equipment (DVOM, carbon pile load tester), and it seems the next step is the dealer for install their scan tool. I'd like to avoid this charge. All wiring is in order, solid connections/connectors.
I've narrowed this down to Charging System Diagnostic, Pinpoint Test D, section 414-00-12
Insightful responses would be appreciated.
4flattires is offline
Old 08-07-2012, 03:11 PM   #2
Chris_HT
Chris_HT's Avatar
Fan#: 86229
What I Drive: Blue SVT 2002
Points 1,543, Level 22
Points: 1,543, Level: 22 Points: 1,543, Level: 22 Points: 1,543, Level: 22
Level Up 44% Completed
FF Reputation: 4 Chris_HT Good Standing Member
Did you really swap engine for SVT zetec? And if yes, do you experience this issues since the swap?
Blue SVT 2002
Our Lady of blessed acceleration
Originally Posted by Black&Tan View Post
But.... why read facts and investigate a claim when it supports your ideology?
...that should be written as 'The First Law of Internet Forums'
Chris_HT is offline
Old 08-07-2012, 04:01 PM   #3
4flattires
Fan#: 76250
My bad on the title, thinking of another family vehicle. No engine swap, all stock 2007 ST 2.3l.
Old 09-18-2012, 05:04 PM   #4
4flattires
Fan#: 76250
Case closed.
I drove for about 30 days with the charge light on and the system charging at normal rate, not really wanting to head to the dealer.
Eventually the new volt regulator failed. A replacement new regulator fully extinguishes the charge light now. 3 weeks and no further issue.
Old 09-18-2012, 07:25 PM   #5
Chris_HT
Chris_HT's Avatar
Fan#: 86229
i remember I tried to google around for this problem but didn't find anything worth mentioning - glad you got this solved.
Blue SVT 2002
Chris_HT is offline
