svt delayed throttle response??????? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-31-2012, 09:10 AM   #1
Buhda420
Buhda420's Avatar
Fan#: 85611
What I Drive: 2003 svt, silver. 5dr
FF Reputation: 1 Buhda420 Good Standing Member
Okay I have had my svt for 4 months now and so far done,,,,,,
Timing belt kit
Accessory belt
Flush all fluids
New transmission
Clutch and master cylinder
Speed sensor
Pcv valve
Plugs and wires
K & n drop in filter
And others I can't think of
And it seems like she's running worse and worse..... When I'm at a light stopped ready to take off.... I let out clutch and go to accelerate and I just sit there pettle to the floor and no response and maybe 3 seconds go by and then she takes off like a the little honey bee she is.......... Soo what could be the delay in response?????????
Mr.Snay's bone stock svtf.... Well a few minor appearance upgrades;)
Buhda420 is offline
Old 07-31-2012, 09:46 AM   #2
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 2,489, Level 30
Points: 2,489, Level: 30 Points: 2,489, Level: 30 Points: 2,489, Level: 30
Level Up 26% Completed
FF Reputation: 24 6SPD_soul Great Standing Member
The engine doesn't rev accordingly with the throttle? As a first step I'd take the take the MAF/air filter tube (don't really know the stock setup at all) off the throttle body and have somebody else push the throttle while you watch the throttle body and see if there's a noticeable lag between the two things, I've never heard or read about that here but it sounds like the throttle cable could be binding or something on initial throttle tip in.
The throttle blade could also be sticking but I think you can usually feel that as a slight resistance in the gas pedal.
6SPD_soul is offline
Old 07-31-2012, 03:53 PM   #3
Buhda420
Buhda420's Avatar
Fan#: 85611
It revs when I give gas accordingly just not when I need to take of fast from a stopped at a light....... If I rev like for a launch its good most of the time..... But like foot from brake to let's take off, no..... I will step on the gas and it like makes bogging sound then the power kicks in and she takes off.......
Buhda420 is offline
Old 07-31-2012, 04:07 PM   #4
Sniper Focus
Sniper Focus's Avatar
Fan#: 84221
What I Drive: '03 SVT EAP "Eurotrish"
Points 2,077, Level 27
Points: 2,077, Level: 27 Points: 2,077, Level: 27 Points: 2,077, Level: 27
Level Up 52% Completed
Forum Activity 6%
FF Reputation: 22 Sniper Focus Great Standing Member
Buy-Sell-Trade Rating: (13)
I'm thinking you're experiencing what all SVTs do. I hear a tune is supposed to fix it, but I don't know firsthand since I don't have a tune. I feather the gas a little before I clutch and I usually get a smooth take off.
Fox Hound: Liquid Stang - Sniper Focus - Decoy Escort (or was it a Tracer...)
Sniper Focus is offline
Old 07-31-2012, 04:37 PM   #5
Buhda420
Buhda420's Avatar
Fan#: 85611
U know I was thinking tune....... I mean there has just been soo my h work done to it over the past few months it feels like the cars off a bit and my gas mileage has even declined dramatically...........man I wanted to get new tires and shocks n springs because those are all worn, befor I got the tune........ Wow when I upgraded from zx3 to svtf I thought I was saving money to get those hp gains but wow the maintenance has becom a lot........... I will never ever sell this car now...... I'm way too much into her!!!!!!! Thank you!!!!!!! Now to save 500$$$$ for live wire tune...........
Buhda420 is offline
Old 07-31-2012, 07:52 PM   #6
NJSVTGUY
NJSVTGUY's Avatar
Fan#: 46519
What I Drive: 86 GN, 11.1@128, 20 psi
Points 4,511, Level 42
Points: 4,511, Level: 42 Points: 4,511, Level: 42 Points: 4,511, Level: 42
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
Forum Activity 8%
FF Reputation: 8 NJSVTGUY Good Standing Member
Buy-Sell-Trade Rating: (10)
All the symptoms of a bad intake manifold controller. Do a search I think it's called a IMRC it's real easy to check it it is. On start up the cable pulls taunt.
If this is it you are in for a surprise when it's fixed because it really kills performance and mileage.
NJSVTGUY is offline
Old 07-31-2012, 09:26 PM   #7
Buhda420
Buhda420's Avatar
Fan#: 85611
Are u talking about the dyi clip or the thread where you actually take out the imrc, open it up and clean the metal connection part??????? Are those actually easy to do cause I have been hesitating to try and remove the clip and box!!!!!!!!!
Buhda420 is offline
Old 07-31-2012, 09:46 PM   #8
NJSVTGUY
NJSVTGUY's Avatar
Fan#: 46519
Forum Activity 8%
Just locate the cable end then have someone start the car. The motor pulls the cable and the flapper on the intake moves toward the radiator. This is sooo comon. If it doesn't work then I would check fuse first then consider repair or replacement. But check it first, it's free.
NJSVTGUY is offline
Old 07-31-2012, 10:42 PM   #9
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2009 BMW 335i
Points 36,504, Level 100
Points: 36,504, Level: 100 Points: 36,504, Level: 100 Points: 36,504, Level: 100
Level Up 0% Completed
FF Reputation: 34 tukaniSVT Great Standing Member
Interesting. I am experiencing the same problem. Now for me, I have had my car since it first hit 2 miles on the clock back in 2003.
And I have also gone through 2 engines in the car.
But now that I think about it, I have not changed out my IMRC. (Moved over from engine to engine) That does sound like something that would be stopping the acceleration.
Good suggestion, NJSVTGUY.
-Ray-
Hatch Nation Member: #147
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
Old 07-31-2012, 10:46 PM   #10
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,625, Level 100
Points: 138,625, Level: 100 Points: 138,625, Level: 100 Points: 138,625, Level: 100
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
Buy-Sell-Trade Rating: (11)
Seriously Raymond? I asked you about it and you said it was fine months darn near years ago of course it wasn't no where near this bad back then. Could have been on it's way out?
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
