Glove box door disassembly - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-30-2012, 12:53 PM   #1
Dondi
Dondi's Avatar
Fan#: 91943
What I Drive: 2012 Oxford White Sedan 5 spd
Points 444, Level 8
Points: 444, Level: 8 Points: 444, Level: 8 Points: 444, Level: 8
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 Dondi Good Standing Member
Hello all,
I let something slip into the slot on the inside of the glove box door that was to small to stay put in the slot. It was a small card about 1/3 the size of a credit card. Now I need to get it out to use it. The only way I can figure is to remove and disassemble the glove box door. Has any one needed to do this (for any reason) that could give some hints? I can't even figure out how to remove the door from the car.
Thanks.
My other car is a classic 1973 VW Super Beetle.
Dondi is offline
Old 07-30-2012, 02:35 PM   #2
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Points 3,286, Level 35
Level Up 58% Completed
I wish it was as easy as the Mazda 3 is where the whole box assembly is held on by a few screws and some plastic clips but I doubt that's the case, when you open the door there should either be exposed screws or caps on top of screws that may be holding the two pieces of the door together, try there first? Otherwise check a parts site like Tousleyfordparts.com and find the glovebox assembly, they show the diagram of the parts which may give away how it's constructed.
Sonic Crew #28
feta_mgp is offline
Old 07-30-2012, 02:40 PM   #3
Dondi
Dondi's Avatar
Fan#: 91943
Points 444, Level 8
Thanks,
No screws. I think it's snap together (isn't the whole car?). I'll check out Tousleyfordparts.com and see if it's helpful.
Dondi is offline
Old 07-30-2012, 03:03 PM   #4
feta_mgp
feta_mgp's Avatar
Fan#: 88210
Originally Posted by Dondi View Post
Thanks,
Probably is snapped together. You're right about that one.
Sonic Crew #28
feta_mgp is offline
Old 07-31-2012, 06:46 AM   #5
SterlingArcher
Fan#: 100651
What I Drive: 2012 SE hatch, Sterling Gray
FF Reputation: 1 SterlingArcher Good Standing Member
You could try removing the cardboard piece below in the footwell. Theres two plastic posts that slide off on either side of the footwell light and that cardboard piece will come off. Thats where my registration ended up when I put it in that slot, which only appears useful for the manual.
SterlingArcher is offline
Old 07-31-2012, 10:50 PM   #6
Chaddz3
Fan#: 96992
What I Drive: 2012 Ford Focus S Ingot Silver
Points 1,795, Level 24
Points: 1,795, Level: 24 Points: 1,795, Level: 24 Points: 1,795, Level: 24
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
FF Reputation: 17 Chaddz3 Great Standing Member
Removing the glovebox....
1. open passenger side door and remove the dash end cap (the part of the dash that butts up against the door when closed...) Its held on with just clips, and pulls straight off
2. Remove the Torx screw holding the glovebox in behind the dash end cap..
3 Open the globebox. Reach up inside the little access hole in the upper left corner of the glovebox and disconnect the AUX IN socket from the wiring harness, and remove the top two torx screws holding in the glove box..
4. Remove the Interior BCM/Fuse Block access panel by squeezing the two yellow retaining "things" and pulling them off.. Look up inside at toward the rear of the the bottom of the glove box to locate and remove the final two torx screws...
5. glove box pulls straight out toward you...
Installation is reverse of removal..
as far as getting the door off from it once removed.. I didnt have to do that when i took mine out as I was trying to access the Body Control Module and wiring harness behind it, so your on your own as far as how to get the door off the thing once its out.
Chaddz3 is offline
