2002 Ford Focus ZX5 Hanging Idle - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-28-2012, 06:31 AM   #1
Dave0106
Fan#: 100174
What I Drive: 2014 Red Titanium
FF Reputation: 1 Dave0106 Good Standing Member
Hello all,
I have been trying to fix a Idle issue. I have read several threads about rough Idle and Idling Low RPM making the car shake and Hanging Idles. I Had / Have all these issues.
First I replaced all three motor mounts. This helped a little bit with the shaking motor issue and yes the motor mount on the passenger side was bad and needed to be replaced.
I replaced the Plugs and wires
The rough Idle continued. I cleaned out the TB I am sure it did some good but it did not resolve the issue.
I replaced the IAC, Idle speed control; PCV Hose from the intake to the PCV valve all three parts.
When the car is started the RPM jumps to about 1500 and hangs there then settles down. When you rev the motor it will hang around 2500 then slowly make its way down to normal idle.
When driving the car and you get to a stop the motor will rev to 2000 or so and slowly return to idle.
I am out of ideas; I have read so many threads here and have thrown so many parts at this problem.
Any Ideas?
Dave0106 is offline
Old 07-28-2012, 01:02 PM   #2
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
Just ideas; Cruise control fitted? Check cable for snags, lubrication. Check throttle cable for snags and smooth operation. Check the Throttle Position Sensor (TPS). It may be worn or faulty.
Car should idle high briefly (about 1200-1500 rpm) when first started from cold. Once temp gauge moves normal idle should be 750 - 800 rpm.
BC_ZX3 is offline
Old 07-28-2012, 09:12 PM   #3
Dave0106
Fan#: 100174
I already replaced the TPS but I will check the cruise control and throttle cable. What do I use for lube on the cables?
Dave0106 is offline
Old 07-29-2012, 03:22 PM   #4
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Forum Activity 5%
I'd use any lightweight oil. If it improves the idle situation, I'd consider replacing the entire cable since the innards are likely worn.
BC_ZX3 is offline
Old 10-02-2012, 10:39 AM   #5
zx003
zx003's Avatar
Fan#: 104291
What I Drive: 2003 Red ZX3
FF Reputation: 1 zx003 Good Standing Member
I too have similar problems. Although, sometimes when in neutral and revved, my RPM does not hang.
I read around here that possibly it's an electrical problem. I just read it today so I haven't tried it on my ZX3 yet. The reason why the rpm hangs is because the ECU is trying to compensate for low charge to your battery. It's trying to give the battery a little more juice before the rpm goes down to normal.
look at this thread
http://www.focusfanatics.com/forum/s...ight=cold+idle
zx003 is offline
