Flex Fuel...Why? - Page 10 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-20-2013, 11:20 AM   #91
dervari
Fan#: 113761
What I Drive: 2013 Performance Blue Titanium
FF Reputation: 1 dervari Good Standing Member
Originally Posted by cessna1 View Post
[Where? It's about a 5% price differential in Atlanta.
I'm in NW Iowa. Being close to the source helps cut out to many middlemen. Our E0 is $4. If you look at the link, you can see Ohio also has a very good spread, as well as Mn.
http://e85prices.com/
You definitely have it better there! I don't know why anyone even sells the stuff here. 3% price break for 10% worse MPG? I don't think so.
If only they could make it out of peanuts or pecans.... :)
dervari is offline
Old 05-20-2013, 11:30 AM   #92
amoosenamedhank
Fan#: 96374
What I Drive: 2012 SE Hatch
Points 880, Level 15
Points: 880, Level: 15 Points: 880, Level: 15 Points: 880, Level: 15
Level Up 80% Completed
FF Reputation: 3 amoosenamedhank Good Standing Member
Originally Posted by StingRay View Post
This isn't a political thread, so how about just knock it off in general.
I ran E85 for it's performance benefits, and it did its job fairly well. End of story. If my ST was flex fuel, I'd use it now. Its not for everyone. Run it if you want, if not, don't.
Cobb should be able to help you out with that. Your physical setup will run E-85, your current setup just doesn't have the ability to sense ethanol content in the fuel.
You can't switch back and forth like a flex fuel car. You'd have to have separate tunes for it.
Cobb released scalars for the Mazdaspeed world to make a quick solution for running E-85. You can always tune it the hard way with changing your MAF curve to compensate for the difference in the fuels lambda
What's that?? You'd like an eco-tune...
amoosenamedhank is offline
Old 05-20-2013, 12:08 PM   #93
cessna1
Fan#: 97921
What I Drive: 2012 Red Candy Sedan
FF Reputation: 1 cessna1 Good Standing Member
There may be hope for other places.
http://domesticfuel.com/2013/05/20/d...-for-biofuels/
cessna1 is offline
Old 05-20-2013, 01:57 PM   #94
garyd9
Fan#: 114024
What I Drive: '13 Dark Gray Focus Titanium Hatch
FF Reputation: 1 garyd9 Good Standing Member
Is flexfuel somehow incompatible with PZEV? I've noticed that any time I see a Focus that's PZEV, it's NOT E85 capable.
(The question is based on seeing about a dozen PZEV focus cars that are NOT flexfuel, and the only FF I've seen wasn't PZEV.)
garyd9 is offline
Old 05-20-2013, 02:39 PM   #95
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,049, Level 66
Points: 10,049, Level: 66 Points: 10,049, Level: 66 Points: 10,049, Level: 66
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 24%
Yes, all PZEV MK3 Foci have two catalysts for emissions, as well as it's more difficult to meet the evaporative emissions requirements (i.e. no vapor is allowed to escape for 150,000 miles) for a PZEV model, and due to the fact that Ethanol evaporates more readily than gasoline it is not compatable with the PZEV models.
Partial Zero Emission Vehicle PZEV Extremely clean conventional vehicle with 150,000
mile extended warranty for the emissions system
and zero evaporative emissions
http://www.arb.ca.gov/msprog/zevprog...ets/zev_fs.pdf
suss6052 is online now
Old 05-20-2013, 05:40 PM   #96
cessna1
Fan#: 97921
One thing to remember, E10 does have a higher vapor pressure(evaporates more easily) than the same gasoline portion that is E0 or in it's pure for. However, ethanol in it's pure form has a very low vapor pressure and that's why it doesn't start as easily in cold weather and needs gasoline for help. In cold climates E85 is only 70% ethanol in the winter months. A friend that has done a lot of research says that at about 30 to 40% ethanol in the blend is where it becomes less volatile than pure gasoline.
cessna1 is offline
Old 11-01-2013, 07:01 PM   #97
lnfloyd
Fan#: 120386
What I Drive: 2006 silver Focus Ghia MK1 facelift
FF Reputation: 1 lnfloyd Good Standing Member
Originally Posted by Power Surge View Post
I've always understood what flex fuel cars were, but this is my first time owning one so now I pay more attention to it.
I am very curious as to WHY have a car that can run off E85?
It gets worse fuel mileage. It seems to be cheaper, but the lower MPG negates that. It's much more corrosive. And it's not like there's an ethanol station at every corner. I doubt too many people will be in the scenario of desperately needing gas and there not being a gas station nearby, but hey, "there's an ethanol station over there".
What is the point of Flex Fuel?
I belive the reason to this is environment concerns and, if you have lived in Brazil, about some years ago, when flex fuel was "invented" in here, ethanol could save a lot of money for you when you have to fill the tank...
I guess it is a way to have competitive alternative to fill the tank. Those who has performance and authonomy concerns, should avoid to have flex fuel cars. They really suck for us...
But, belive me, I hate flex fuel too... Ethanol increases HP (I saw some projects which owner has converted his car to ethanol to have even more HP gain). But in Brazil, in now days, with standard prices policy*, if an ethanol litre costs 70% or more than the gasoline litre price, that's indicates you will be burning money if you fill your tank with that...
*Here, government decides when to increase gasoline price and how much, not the market... but, Petrobras and our government are changing that, so ethanol versus gasoline could be a nice fight for our money again.
So, it's all about to save money (but you are right... much people aren't noticing that corrosion can destroy parts earlier and money saved when they fill the tank with ethanol, just in case it was/is or would the better choice, goes away).
Best regards!
lnfloyd is offline
Old 11-01-2013, 07:29 PM   #98
FoFoTi
FoFoTi's Avatar
Fan#: 119990
What I Drive: 2014 hatch
Points 574, Level 11
Points: 574, Level: 11 Points: 574, Level: 11 Points: 574, Level: 11
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 1 FoFoTi Good Standing Member
Not sure why we don't use sorghum (not corn) for ethanol in the US
http://64.34.211.82/Bioproducts/Default.aspx
FoFoTi is offline
Old 11-01-2013, 10:47 PM   #99
cessna1
Fan#: 97921
We probably should. Also, you should check the price of corn currently---it's about half of what it was a year ago and probably going lower since everybody is finding better yields than expected. Just rode with my cousin in the combine and the yield monitor was hitting 270 bushels per acre on non irrigated Iowa dirt. My field just did a little over 200 bpa. The genetics keep getting better and better but it takes money for the research which is paying off.
cessna1 is offline
Old 11-02-2013, 01:14 AM   #100
GoldenHour
GoldenHour's Avatar
Fan#: 103427
What I Drive: 2014 Tuxedo Black ST
Points 1,148, Level 18
Points: 1,148, Level: 18 Points: 1,148, Level: 18 Points: 1,148, Level: 18
Forum Activity 2%
FF Reputation: 3 GoldenHour Good Standing Member
Originally Posted by feta_mgp View Post
Also, ethanol is a renewable source of energy, so the efficiency isn't as important as far as gas mileage is concerned. People want better mileage now because we have this whole energy crisis with oil, but you give me a bigger gas tank and cheaper ethanol, and the fact that they end up negating the differences in cost vs efficiency means that it doesn't matter.
which crisis are you referring too -- peak oil? we're awash in oil. there is no crisis.
GoldenHour is offline
