tps (did a search but need the voltage) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-04-2004, 05:25 PM   #1
Drabert
Fan#: 14645
What I Drive: 2000 Rain Forest Green SE
FF Reputation: 1 Drabert Good Standing Member
i need to know the voltage for the tps sensor while its closed?
i have a pectel so i can measure the voltage but i think the tps is causing some of my problems at idle... i was told the correct voltage when closed should be 1.0 but when i did this the idle went up to 3grand and just stayed there... i also read somewhere that it should be 0.5v but mine bottoms out before it gets that low... i have a FC TB in a 2000 zetec with a mtx tranny
any help would be greatly appreciated!!
Drabert
Drabert is offline
Old 11-04-2004, 05:35 PM   #2
Kicknzx3
AKA Toyotech
Kicknzx3's Avatar
Fan#: 9
What I Drive: A few
FF Reputation: 1 Kicknzx3 Good Standing Member
Buy-Sell-Trade Rating: (4)
0.5 is suitable but on most cars its between .8-1.0...if i have time i'll grab my multimeter and give u an exact...only problem, my car idles at 1200rpm...heh if ur worried about it causing problems swap one with somebody, takes 2 seconds. but i do kind of doubt it being the tps. the tps is known for spiking at wot around 3.5v. got any other questions hit me up
2012 Toyota Camry SE
2012 Chevy Cruze LT/RS
2006 Ford Escape XLE V6
1991 Ford Mustang LX/5.0
Kicknzx3 is offline
Old 11-04-2004, 06:49 PM   #3
Toptech
Toptech's Avatar
Fan#: 2679
What I Drive: 2002 Blue ZX5
FF Reputation: 1 Toptech Good Standing Member
.6 to .9 is good. You have to remember to reset the keep alive memory (disconnect the battery for ten minutes) when increasing the tp voltage; otherwise the pcm will think it is now at part throttle and raise the iac duty cycle causing a high idle.
Toptech is offline
Old 11-04-2004, 09:54 PM   #4
IHateRice
Fan#: 4120
What I Drive: 2003 Black ZX3
FF Reputation: 1 IHateRice Good Standing Member
Which wire should I tap in the TPS harness for a learning WOT switch? It "learns" the voltage curve at WOT but it plugs into 1 wire and I'm not sure which one to plug into.
IHateRice is offline
Old 11-04-2004, 09:58 PM   #5
Kicknzx3
AKA Toyotech
Kicknzx3's Avatar
Fan#: 9
What I Drive: A few
white and brown
Kicknzx3 is offline
Old 11-04-2004, 10:55 PM   #6
IHateRice
Fan#: 4120
White and brown? There is only one wire that I am supposed to hook up to. It is a ZEX WOT activation box.
Old 11-04-2004, 10:59 PM   #7
Kicknzx3
AKA Toyotech
Kicknzx3's Avatar
Fan#: 9
What I Drive: A few
sorry, browns always ground. just used to saying it as i wasn't expecting you to say nitrous
Kicknzx3 is offline
Old 11-05-2004, 12:36 AM   #8
IHateRice
Fan#: 4120
The Zex NMU has 3 wires. A red, black, and white. The black is a ground which is going to my window switch. The red is coming from the arming switch. And the white wire should go to the brown or white wire in the TPS? I'm not getting it because you said brown is ground and it seems the white should go to a white wire and it would have to have power.
Old 11-05-2004, 04:26 AM   #9
Drabert
Fan#: 14645
hmm.. i wonder if i need to reset the computer with the pectel or if it just doesnt matter...
well thanks for the help though that does answer my question.. i will be sure to adjust the screw back out some to help control the idle
now on another note about the same device(i think)... while driving at part throttle i get hesitation.. looking at my boost gauge it shows that it is around 15 pounds of vaccum... i have already tried to add and remove fuel from that section of the fuel map and adding and removing timing so i dont think it is either (i know i need a wideband)
but while logging the voltage of the tps sensor i do see a spike sometimes at the same time as the hesitation, i just cant tell if its cuz the car is jerking my foot off the pedal or if its the tps sensor... so i am just wondering if the tps could be causing that
Drabert is offline
Old 11-06-2004, 02:36 PM   #10
IHateRice
Fan#: 4120
Don't play with the spark and fuel maps too much without an EGT and Wideband O2 system. Any news on how this is going?
Also, I should plug into the white wire?
