#11 | ||||
Mine did this as well. Check the PCV valve, run your hand down all the way to the bottom.
Another possibility is the idle control solenoid. |
| Sponsored Links | |||
Advertisement | |||
#12 | ||||
#14 | ||||
If it's this one, then i've already changed it, the rest of the hoses didn't seem to have any problems:
http://imageshack.us/photo/my-images/844/imag0252rr.jpg |
#15 | ||||
A few other questions; Does this only happen when the A/C is on? Maybe it could be the ECT sensor? I still 90% believe it's a vacuum leak. |
#16 | ||||
At every car service i went, they checked for leaks, they used some kind of special spray that would show if any air is leaking, i don't think 4 services could miss that. They checked and rechecked, everything seemed fine, plus, i doesn't behave like a leak, there's no fluctuation. This happens if the AC is OFF, so i don't think it has anything to do with it. |
#17 | ||||
Using carb spray is risky and you won't be able to find leaks non-accessible. |
#18 | ||||
#19 | ||||
Gets more V8
its a better idea than just spraying Carb cleaner until the idle changes. I found a leak on car yesterday at the intake manifold (2.3 duratec) and It looks like the manifold warped or cracked because its plastic. smoke would have pointed it out faster but j
I don't have one here.
SR #127 | '02 Focus SE "Foci" (5.0 in progress) | '90 Mazda 626 GT "Greenie" (2.2L turbo T3/T4 rebuild-selling) | '94 Toyota 4Runner SR5 "Roach" (daily-stockish) Moderating General Chat Lounge, General Technical Chat, Ford Focus & General Car Chat, and Rocky Mountain Fanatics |
#20 | ||||
and I tell you why, In my understanding: computer will keep higher RPMs to keep up with increased electrical load - so, if there is a problem with cable charging the battery, or grounds, it's not getting enough 'juice', and the 'normal load' becomes 'high load' for the computer, and it ends up reving. Now why would A/C make any difference? well with A/C on the computer will keep higher RPMs to keep up with extra load that A/C compressor adds, which means alternator has a little higher output at that time too, which may be just enough of difference to keep computer satisfied with it's energy output. And why would I said it all? Because I had problem with electric installation in my SPI, and it did weird things, almost like having an annoying ghost in your car who just likes to mess up with everything :P so ye, I experienced higher revs for a few seconds after coming to a full stop, and just taking care of the wiring fixed my problem. Now I'm a noob, so feel free to point out why i'm wrong :D |
| Thread Tools | |
| Display Modes | |
