General Forced Induction The place to chat about turbochargers, superchargers and Nitrous systems.
#1 | ||||
New Turbo - Little Help Please
My car is 01 Se Zetec.
I just picked up a Top Speed Stage 2 Turbo kit. I have been doing some research to figure this out. Question: Do I need a Diablo Mafia? If yes then I was looking at this one and it had a Note "II. F7324 MAF Interface is used to install the smaller more efficient 2005-2006 MAF sensor on 1996-2004 Ford vehicles. Built in 24" length for MAF relocation, this is a plug and play part. " Is this what I should get and a new 05 or 06 MAF sensor? Also, what about a J&S, should I get that as well??? Also, what should I get for a fuel pump. Top Speed says I can just run a stock 04 fuel pump but Turbo Tom said they are nuts and I need to get a return style fuel pump. Can you please point me to where I can buy one? Thanks for your help Joe |
Remove Advertisements |
Fan#: 1
#2 | ||||
FF Affiliate
You told me ts said you could do 400HP on the stock pump , I says that cannot be done safely ,
Yes you need the diablo MAFia but for your year of car , there is no need in going to the slot style MAF and added cost , get a 3 inch MAF tube for your MAF and be done with it No you do not need the J&S Tom
Focus-Power: Your #1 Source for Ford Focus Speed, Tuning & Performance! Customer Support AIM: hpdyno Email: tom@focus-power.com Phone: 704-249-3745 Site: focus-power.com Elder 1turbofocus |
#3 | ||||
Thanks Tom
Will this work for my oil feed to the turbo? http://www.ebay.com/itm/T3-T3-T4-Tur...f264a1&vxp=mtr Thanks, Joe |
#4 | ||||
Or should I go with something like this that feed from the oil pressure sensor
http://www.ebay.com/itm/Turbo-Oil-Fe...24715a&vxp=mtr |
#5 | ||||
i <3 my ST
I wouldn't buy that kind of stuff from eBay. I've watched those fittings shear off with just hand tightening.
You need to find out what oil line size, fittings, drain line size, etc are recommended from the turbo manufacturer and then purchase quality parts. Don't forget the water lines if your turbo uses them.
'07 ST ; formally bewst'd '86 XR4Ti ; 2.3L Turbo, 15psi D23 Crew: #07 |
#6 | ||||
FF Affiliate
You need to use the oil hole behind the coil , fitting for there is a 1/8 NPT 90 deg to -3 or -4 oil line what ever size your using
The second link with the line doesnt say what size the line is -3 or -4 ?? Tom
#7 | ||||
Gets more V8
watch out for the cheap? bay oil fees lines. may have just been my bad luck but my old one decided to lay across my manifold and that melted like crazy causing me to be stuck on the highway.
SR #127 | '02 Focus SE "Foci" (5.0 in progress) | '90 Mazda 626 GT "Greenie" (2.2L turbo T3/T4 rebuild-selling) | '94 Toyota 4Runner SR5 "Roach" (daily-stockish) Moderating General Chat Lounge, General Technical Chat, Ford Focus & General Car Chat, and Rocky Mountain Fanatics |
#8 | ||||
FF Affiliate
Laid accross you Exh manifold ? If so even the highest quality wouldnt of held up to 600+ deg
| Thread Tools | |
| Display Modes | |
