The best Rpm right off the start... - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Drag Racing
Drag Racing The place to discuss information about drag racing stats, tips and events. Track sanctioned events only.
Old 07-21-2012, 09:15 PM   #11
Texas Ghost
Texas Ghost's Avatar
Fan#: 97937
What I Drive: 2006 Black ZXsumthin Hatchback
FF Reputation: 2 Texas Ghost Good Standing Member
lol i guess i should have mentioned to burn out i just ASSumed he knew that
Real Eyes Realize Real Lies
16.256 @ 84.17
HatchNation #157
Texas Ghost is offline
Old 07-22-2012, 06:15 PM   #12
SMITHBOY76908
SMITHBOY76908's Avatar
Fan#: 56301
What I Drive: 2007 Turbo ZX3
Points 14,482, Level 78
Points: 14,482, Level: 78 Points: 14,482, Level: 78 Points: 14,482, Level: 78
Level Up 8% Completed
FF Reputation: 18 SMITHBOY76908 Great Standing Member
Buy-Sell-Trade Rating: (4)
Originally Posted by sporadic View Post
The answer: give it as much RPM as you can without spinning the tires or breaking an axle.
If you spin, get stickier tires. Increase RPM until axle breaks.
This.
I launch from 5k with about 8psi built up on the 2-step. If the track is decently prepped, it hooks right up (slicks). My clutch slipped last time out though. Even dead hooking dropping the clutch from 5k, I haven't broken an axle from launching. I've broken 2 axles due to potholes though.
There's way too many variables to say what RPM to launch from, even with a stock car. Differences in track prep, track surface material (asphalt, concrete, etc...), and time of day can all make a difference. You just have to get out there and find where it likes it best.
Don't do a burnout on street tires, you're wasting your time. Street tires actually lose traction when heated due to the rubber used in radial tires. If you're working with slick compound, then yes heat them up. Slicks become stickier when hot, the opposite of a street tire. Also, going through the water with street tires is just going to get water trapped inside the grooves that will make you spin off the line even worse.
Russia... is... awesome!
SMITHBOY76908 is offline
Old 07-22-2012, 08:11 PM   #13
Texas Ghost
Fan#: 97937
Don't do a burnout on street tires, you're wasting your time. Street tires actually lose traction when heated due to the rubber used in radial tires. If you're working with slick compound, then yes heat them up. Slicks become stickier when hot, the opposite of a street tire. Also, going through the water with street tires is just going to get water trapped inside the grooves that will make you spin off the line even worse.[/QUOTE]
see i have always heard tha you dont have to heat your streets, but the track i go to you have no way around the wter puddle so i go thru the water fast, stop and burn out just to get the water off or i just spin forever.
16.256 @ 84.17
HatchNation #157
Old 07-24-2012, 12:54 AM   #14
SMITHBOY76908
Fan#: 56301
Ah, yeah I hate those kind of tracks. In that case, spin 'em to get the water off like you said.
Old 08-01-2012, 03:27 PM   #15
AllOutZX2
AllOutZX2's Avatar
Fan#: 80930
What I Drive: 1998 Ford Escort ZX2
FF Reputation: 1 AllOutZX2 Good Standing Member
alright, after a night of fun research of trying to figure things out here is what i came up with.
6000 rpm clutch dumping w/ 67mm tb & cone filter drop in - 17.121 @83.45
2000 rpm w/ 67mm tb & filter - 16.785 @ 83.29
2000 rpm w/ 67mm tb & w/ stock air filter house back on - 16.552 @ 83.74
2500 rpm w/ 67mm tb & stock air filter house - 16.355 @ 84.24
2900ish rpm w/ 67mm tb & stock air filter house - 16.256 @ 84.17
thats what i came up with if you need to know the 1/8 mile times i can post that.
i will be up graded with a header in the next month ( i hope ) i will post new times again
p.s. man there was some sick ass rides out there last night.
We need to know the 60ft times of each run. :)
Shawn
Full Bolt-On's, SCT VCT Tuned ECU, 3500rpm Edge Racing Stall, 205/60R13 M&H D.O.T Street Slicks
AllOutZX2 is offline
Old 08-11-2012, 04:09 PM   #16
_Auricom_
_Auricom_'s Avatar
Fan#: 101454
What I Drive: 04 ZX5 SVT & 01 Eclipse GT
Points 504, Level 10
Points: 504, Level: 10 Points: 504, Level: 10 Points: 504, Level: 10
FF Reputation: 1 _Auricom_ Good Standing Member
good stuff my man,
... I had gone to our drag strip here in phoenix last, got raped due to my noobishnessness.
I now know that droping the clutch at 3k has a higher probability in getting better numbers yo.
The next question is, when shifting afterwards ... is it recommended to let off the clutch slightly. I seemed to have been letting off it alot since I did miss engaging third gear in one of my runs for not letting off the clutch enough? Any input on this?
_Auricom_ is offline
Old 08-12-2012, 09:39 PM   #17
evanmdzx3
evanmdzx3's Avatar
Fan#: 94289
What I Drive: 2007 Silver ZX3 SE
FF Reputation: 1 evanmdzx3 Good Standing Member
red line/ dump it! =P
"If I'm not driving than I'm not living" - ME
Hatch Nation #166
evanmdzx3 is offline
Old 10-23-2012, 03:09 PM   #18
Quickone4u
Fan#: 104673
What I Drive: 2004 Pitch Black SVT
FF Reputation: 1 Quickone4u Good Standing Member
Originally Posted by _Auricom_ View Post
good stuff my man,
umm....I let off of the clutch after every gear change
Quickone4u is offline
