How to install switchbacks - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-18-2012, 11:24 PM   #11
indy_11
Panamasian
indy_11's Avatar
Fan#: 81404
What I Drive: 2011 Blue Flame SES
Points 8,314, Level 61
Points: 8,314, Level: 61 Points: 8,314, Level: 61 Points: 8,314, Level: 61
Level Up 55% Completed
FF Reputation: 7 indy_11 Good Standing Member
Buy-Sell-Trade Rating: (4)
go to ebay and type in focus switchback. there a plenty of prices but this is a example. it comes with the resistors already so you just splice, solder and bam new switchback turn signals
switchbacks
2011 Blue Flame Focus SES #011
December 2011 ROTM Winner! :)
I always take a poo before driving to reduce weight and increase performance
you tell me your auto is fun to drive, I laugh in your face.
indy_11 is offline
Old 07-18-2012, 11:25 PM   #12
indy_11
Panamasian
indy_11's Avatar
Fan#: 81404
o and here's the video as promised
indy_11 is offline
Old 07-19-2012, 08:19 AM   #13
SteezMuffin
SteezMuffin's Avatar
Fan#: 99549
What I Drive: 2009 Sterling Grey Focus SE
Points 783, Level 14
Points: 783, Level: 14 Points: 783, Level: 14 Points: 783, Level: 14
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
FF Reputation: 2 SteezMuffin Good Standing Member
This is going to be really helpful once my switchbacks come in
SteezMuffin is offline
Old 07-19-2012, 09:07 AM   #14
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
FF Reputation: 5 DarderSauce Good Standing Member
Originally Posted by champjfocus View Post
I thought you didnt have to solder or cut anything........
You don't have to but that means you are using the Vamp Clamp which can lead to corrosion (because of the exposed wires). Blueflow's way is better/will last longer, but you should use heat shrink instead of electric tape. And don't forget, if you are using heat shrink.... PUT THAT ON THE WIRE BEFORE YOU SOLDER! You don't want to have to pull your wiring apart because you forgot it.
If you can't wear it out, burn it off
DarderSauce is offline
Old 07-19-2012, 09:20 AM   #15
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 8,540, Level 62
Points: 8,540, Level: 62 Points: 8,540, Level: 62 Points: 8,540, Level: 62
Level Up 30% Completed
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
lol this^, I heatshrinked all of mine after soldering it last week. Before that I had the little t clamp things but they are not as reliable as a good soldered connection and I don't want to be on the road and a light stop working(=
Galatians 6:14
crice8 is offline
Old 07-19-2012, 09:51 AM   #16
DarderSauce
Fan#: 95564
HA HA WTF Crice do you have a wireless resistor in there or something? I can't see where you soldered it in. Also what kind of heat shrink would you recommend/where did you get it. All I have used is the butt clamps you can heat shrink and don't know what brand of heat shrink works well. I assume anything from 3M would be good but I am not sure if they make any. THANKS!
Old 07-19-2012, 10:05 AM   #17
crice8
crice8's Avatar
Fan#: 84830
lol no i added in about 4" lengths of wire so that i had plenty to work with.
Galatians 6:14
crice8 is offline
Old 07-19-2012, 10:13 AM   #18
SteezMuffin
Fan#: 99549
Technically you really shouldn't have to solder anything as long as the wires are touching and you could just wrap that up with electrical tape and then shrink wrap it to make sure it holds still so the connection isn't moving around. I personally would solder it though.
Old 07-19-2012, 11:39 AM   #19
crice8
crice8's Avatar
Fan#: 84830
Lol I typically am not a big fan of shorts in wires, Small electrical fires, damage to electrical components caused by surges from a short, etc.
haha Don't waste your time doing to wrong the first time when with an added two minutes it will be a flawless long-life proper connection(= thats my mindset on it.
My previous vehicle I learned my lesson in this as all electronic components in a car are linked in some way or another. A small short in a wire for an aux light can cause major damage to other things(=
Walmart has a cheap solder iron for right under $6 and solder for $1. Heat shrink is cheap and it doesn't matter really what brand you use. You don't have to have a heat gun by any means. A lighter works perfectly for shrinking it(=
Also spending less than $10 on these items is totally worth it! You will find all of the little things car and home related that are done much better and more reliable with these few items(=
(Sorry i'm on a study cram and adderall and redbull have me going 90 to nothing on FF haha noone is here to discuss the test we have in 20 mins yet. I think my typing speed is like 150wpm right now haha ever seen limitless? )
Galatians 6:14
crice8 is offline
Old 07-19-2012, 01:01 PM   #20
Slammed_2.0
Boosted HB.
Slammed_2.0's Avatar
Fan#: 84306
What I Drive: 2013 TB ST
Points 6,542, Level 52
Points: 6,542, Level: 52 Points: 6,542, Level: 52 Points: 6,542, Level: 52
Level Up 96% Completed
FF Reputation: 20 Slammed_2.0 Great Standing Member
Let me add to this.
For NON factory intakes you will not need to remove your headlights.
There is plenty of room for the driver side to access it if you have aftermarket intake
As for the passenger I found it plenty easier to just remove the coolant overflow tank and just move it aside to gain access to the passenger side.
Solder is the best and safest way to have a good connection. You can use the quick connects or use the same procedure similar as this but not solder the connections and just use heat shrink to hold it.
Here's a tip about soldering:
Let the bare copper wire get hot then touch the solder on the heat gun and it should connect the wires very well.
Edit:
It's amazing how fast these switchbacks got popular with us 2nd gen. =] I started this trend and I still love my switchbacks.
2013 Ford Focus BOOS[ST]ED
2010 Ford Focus "S"edan (11 Psi, GT28RS) - Sold
ROTM Nov '11 (2010 Focus S)
Slammed_2.0 is offline
