How to install switchbacks - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-18-2012, 05:09 PM   #1
indy_11
Panamasian
indy_11's Avatar
Fan#: 81404
What I Drive: 2011 Blue Flame SES
Points 8,314, Level 61
Points: 8,314, Level: 61 Points: 8,314, Level: 61 Points: 8,314, Level: 61
Level Up 55% Completed
FF Reputation: 7 indy_11 Good Standing Member
Buy-Sell-Trade Rating: (4)
alright so i finally built up enough courage to do this so here goes. this will show you that even the guy with no knowledge of wiring can do this
step one: remove your grill (brad white made a how to on that, just search how to remove grill)
step 2: remove light - there are three bolts you need to remove, after that it's jsut a simple finagle out
TIP: PLACE A TOWEL ON THE BUMPER IF YOU DON'T WANT TO SCRATCH IT. it's happened before to many people but with patience you don't really need it
step 3: remove all bulbs and place lamp away from car
step 4: check out your kit (this should really be step one but i'm sure you've already done so) - you should have a bulb and resistor. supply your own soldering iron and soldering wire, electric tape wire cutters and wire splicer
step 5: cut the heatshrink to access more wire
step 6: ok so here's where it gets interesting. you're going to need to cut the two outside wires for the turn signal. don't cut the middle wire
thankfully for me i had my wire cutters in my fire gear so it made the job easier
step 7: splice about 1/4 off your wire on each side you want to solder.
step 8: twist three wires together (that'll hold it in place for your solder) and solder together
as you can see my first soldering was horrible but after you get use to it it's not so bad
step 9: plug your bulb in and turn it on. if it doesn't work flip it 180 degrees. if not that check that you soldered the right things together
step 10: cover your soldering in electrical tape
step 11: put all your bulbs and head lamp back into place do the other side and admire your work
at first i was like nawl, i'm gonna sell these but after it's all said and done i feel pretty proud of what i've done. i'll post vids in a little. as for the resistors, i read that slammed used self drilling screws to hold them in place on the radiator support, but i couldn't find ones the size to fit in the holes so right now they are just hanging. hope this helps!
2011 Blue Flame Focus SES #011
December 2011 ROTM Winner! :)
I always take a poo before driving to reduce weight and increase performance
you tell me your auto is fun to drive, I laugh in your face.
indy_11 is offline
Old 07-18-2012, 06:32 PM   #2
cmmike1
cmmike1's Avatar
Fan#: 63736
What I Drive: 2008 Silver Coupe SES
Points 1,061, Level 17
Points: 1,061, Level: 17 Points: 1,061, Level: 17 Points: 1,061, Level: 17
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
FF Reputation: 1 cmmike1 Good Standing Member
great write up blue! i look forward to doing this mod.
it should be noted that you should cover the 2 soldering points separately before you wrap them together. don't want the wires touching otherwise bad things can happen.
cmmike1 is offline
Old 07-18-2012, 06:35 PM   #3
VonKrause
Unicorn Owner
VonKrause's Avatar
Fan#: 72283
What I Drive: 2009 Ice Blue 5 speed 4 door FoFo
Points 36,103, Level 100
Points: 36,103, Level: 100 Points: 36,103, Level: 100 Points: 36,103, Level: 100
Level Up 0% Completed
FF Reputation: 7 VonKrause Good Standing Member
So in a nut shell (if I understand correctly) you are taking a resistor and bridging the positive and ground wires to the turn signal?
Get your trunk or hatch LED conversion kits here http://www.focusfanatics.com/forum/showthread.php?p=4542652#post4542652
"2nd Gen problems"
I've spent too long looking into the abyss. It's starting to look back.
SR #233
VonKrause is offline
Old 07-18-2012, 06:41 PM   #4
minesweaper
Fan#: 99342
What I Drive: 2008, Black, SE
FF Reputation: 1 minesweaper Good Standing Member
I plan to use heat shrink on mine and what bulb did you use? I went to idjm and put in the part number, but there is like 10 differnt ones.
minesweaper is offline
Old 07-18-2012, 06:41 PM   #5
VonKrause
Unicorn Owner
VonKrause's Avatar
Fan#: 72283
AH question was answered, and yea the resistor bridges the two wires, it was hard for me to see the finished product in the pictures.
"2nd Gen problems"
SR #233
Old 07-18-2012, 06:43 PM   #6
indy_11
Panamasian
indy_11's Avatar
Fan#: 81404
thanks man. i know people, like myself, are more visual learners. i know people told me what to do but i just never pictured it in my head. so i prayed i'd get it right and not pay for a mistake and got it
and thanks for adding that. i almost did that, but i was like....nawlll haha
pretty much. it's simple, but like i said above if i didn't see it visually it wasn't happening.
indy_11 is offline
Old 07-18-2012, 06:48 PM   #7
indy_11
Panamasian
indy_11's Avatar
Fan#: 81404
BTW i'd just like to add, i dont want to take credit for starting this trend. i thought it was cool enough to do, i just figured it'd be nice to have a write up
indy_11 is offline
Old 07-18-2012, 11:02 PM   #8
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 7,090, Level 55
Points: 7,090, Level: 55 Points: 7,090, Level: 55 Points: 7,090, Level: 55
Level Up 70% Completed
FF Reputation: 15 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (10)
Nice write up. Where did you get the bulb and the resistor??
No I don't think my car needs "moar low". I apologize to everyone for my car not looking like all the other Foci at FR14.
PSUrivie is offline
Old 07-18-2012, 11:07 PM   #9
champjfocus
champjfocus's Avatar
Fan#: 96072
What I Drive: 2009 Ford Focus SES in Sangria Red
Points 4,379, Level 42
Points: 4,379, Level: 42 Points: 4,379, Level: 42 Points: 4,379, Level: 42
Level Up 15% Completed
FF Reputation: 1 champjfocus Good Standing Member
I thought you didnt have to solder or cut anything........
SES #035:
LED plate lights, LED map lights, LED cargo lights, remote start system, Sylvania LEDriving reverse lights
champjfocus is offline
Old 07-18-2012, 11:14 PM   #10
PSUrivie
PSUrivie's Avatar
Fan#: 67329
oh yeah, how do you know type of resistor to get?? 6 ohm, 30W???
PSUrivie is offline
