Sync directions download incomplete - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-19-2012, 04:38 PM   #11
slconline
slconline's Avatar
Fan#: 103617
What I Drive: 2012 Silver Titanium
FF Reputation: 1 slconline Good Standing Member
I'm having this same problem right now. I use an iPhone 4S with AT&T. Thought it was the phone, but I suspect not after reading this. I'm pretty frustrated. Any suggestions or resolutions since last message here?
slconline is offline
Old 09-19-2012, 04:56 PM   #12
Risa.Simon
Fan#: 101935
What I Drive: 2012 Silver Focus Hatchback
FF Reputation: 1 Risa.Simon Good Standing Member
From the extremely helpful Jaclyn:
Although you'll have to pair your phone again once this is complete, I recommend resetting your system.
To do so, press the clock and go through the following menu sequence: SETTINGS > SYSTEM > MASTER RESET
Before pairing your phone again, remove the battery from your device. This will reset the Bluetooth chip.
If you need helping with pairing, check out our support page:
http://Support.Ford.com/sync-technol...our-phone-sync
Risa.Simon is offline
Old 09-19-2012, 05:43 PM   #13
slconline
slconline's Avatar
Fan#: 103617
Thanks Risa! I'm going to try the reset, but can't take the battery out of my iPhone. Stupid apple.
Old 09-20-2012, 12:38 AM   #14
slconline
slconline's Avatar
Fan#: 103617
Originally Posted by Risa.Simon View Post
Jaclyn,
Any solutions? I am having the same problems:
1) directions download repeatedly does not complete;
2) on the two occasions when the download did complete (following several "retries"), no directions were provided;
3) Sometimes when the download fails, I recieve audio directions anyway and cannot cancel the route because no route is active.
Vehicle: 2012 Focus Hatchback Titanium w/ My Touch
Phone: iPhone 3G on Straight Talk Network
P.S. I followed your reverse pairing directions. While this solved a couple other problems I'd been having, it did not resolve the above-mentioned issue.
Thanks in advance for your help!
Risa
I'm having the exact same problem as Risa, all three items exactly as she described, though my phone is an iPhone 4S on AT&T. I have now done a master reset and repaired my phone with the reverse pairing method. Can't remove the battery from the iPhone though. Tried to download directions again and failed again. It worked the first time before I left the dealer, then failed multiple times, worked one more time, has now failed dozens more times. I've had the car two weeks and bought it specifically for the sync system over a Honda. Not happy.
Any more suggestions? Jaclyn, are you still around with some more insights?
Old 09-21-2012, 03:25 PM   #15
FordIVTteam
Official Ford Rep
FordIVTteam's Avatar
Fan#: 87765
What I Drive: Ford Focus
Points 2,194, Level 28
Points: 2,194, Level: 28 Points: 2,194, Level: 28 Points: 2,194, Level: 28
Level Up 30% Completed
FF Reputation: 3 FordIVTteam Good Standing Member
Aww, thanks, Risa.Simon!
Hi, slconline -
I'm still hanging around. Sorry you didn't hear from me yesterday, I've been slammed with iPhone 5 questions. ;)
Since you cannot remove the battery, we recommend resetting your iPhone. (Don't worry you won't lose any settings)To do so, press and hold the home button and sleep button simultaneously, until the Apple logo appears.
Please PM me your VIN or email address so I can confirm your account is set up correctly.
Jaclyn
FORD IN-VEHICLE TECHNOLOGY TEAM
p: 800.392.FORD (Prompts 1 then 3)
f: facebook.com/FordFocus facebook.com/Ford
FordIVTteam is offline
Old 09-21-2012, 06:30 PM   #16
Stars4jon
Stars4jon's Avatar
Fan#: 103518
What I Drive: 2012 Candy Blue SE HB
Points 120, Level 2
Points: 120, Level: 2 Points: 120, Level: 2 Points: 120, Level: 2
Level Up 40% Completed
FF Reputation: 1 Stars4jon Good Standing Member
Hi Jaclyn, I have sent two PMs in regards to Sync questions. Could you please respond. Thanks.
Cheers and Clear Skies
Jon Betancourt
2012 Ford Focus SE Candy Blue
Stars4jon is offline
Old 09-21-2012, 07:01 PM   #17
slconline
slconline's Avatar
Fan#: 103617
Hi Jaclyn, I bet you are slammed with iPhone 5... Thanks for getting back to me! i actually abandoned my iPhone for a Galaxy S2 Skyrocket last night - I'll send you a pm with my info. I did another master reset, then reverse paired the Galaxy S2. Still having the problem. PM coming up next.
Old 09-21-2012, 07:13 PM   #18
slconline
slconline's Avatar
Fan#: 103617
Jaclyn - you mention making sure my account is set up correctly. There wasn't actually an option for my exact system. The choices were either MFT with Nav or Sync with the two little screens and no touch at all I think? I picked one the first day and then I may have changed it? What should it be set to? I have MFT, no nav obviously. :)
Old 09-27-2012, 10:48 AM   #19
lewisra
Fan#: 93289
What I Drive: 2012 Tuxedo Black SEL
Points 1,395, Level 20
Points: 1,395, Level: 20 Points: 1,395, Level: 20 Points: 1,395, Level: 20
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
FF Reputation: 3 lewisra Good Standing Member
If you have MFT and you've tried Jaclyn's suggestions and it still doesn't work. Try the delayedreboot.cab(google it). This or removing the battery from the phone seems to fix the issue for me.
lewisra is offline
Old 09-27-2012, 11:09 AM   #20
FordIVTteam
Official Ford Rep
Fan#: 87765
I hope you received my reply, Stars4jon. Your Focus is equipped with the latest software.
No problem, slconline, I received your PM and replied, I have a couple more questions for you. To be perfectly honest, it doesn't matter which picture you select when setting up your account. We know which system you have based upon the VIN that's entered. When I mentioned your account being setup correctly, I wanted to make sure you didn't have more than one account created. Believe it or not, it happens all the time and that of course in an easy fix. I see that you have only one. I'll look for your reply later.
Jaclyn
