Rotor Upgrade Questions - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-17-2012, 03:45 PM   #1
DarderSauce
DarderSauce's Avatar
Fan#: 95564
What I Drive: '08 Vermillion Red 5 speed SEdan
FF Reputation: 5 DarderSauce Good Standing Member
Cool Rotor Upgrade Questions
Hello All!
Well I finally got everything I needed to upgrade my rear drum breaks to disk breaks. Well almost everything, I told the seller I did not want the rear rotors because they looked to be rather rusty and I wasn't sure if there was any warping so I figured I would just get a new set, plus the parts were cheaper to ship w/out them. The break lines were also not included.
The only problem I am having now is trying to figure out which rotors/lines I should purchase
Wondering if anyone can recommend a solid set of rotors that would work for a long time in bad MN winters with lots of salt. I would like to get rotors that have the center (hub) painted black because in my experience removing a set that is rusted on can be a PITA (see -->) and that's supposed to help prevent rust
Rotors by DarderSauce, on Flickr
Also not really looking for drilled/slotted for the following reasons:
1. I think they are more likely to crack (may be wrong)
2. most of them (excluding the very expensive) are not cast like that, instead they are machined afterwards
3. I have solid rotors on the front so drilled/slotted on just the rear would look dumb (IMHO).
I know I need to get new break lines that are a bit longer but don't want to have to go through the hassle of having them made. I want to make sure I get a set that has all the correct fittings on both ends so I don't have to do any modifications to get them to work. If you could recommend a set of lines as well I would appreciate it. Remember..... links on where each can be purchased are GGGGRRRRRRRRRRRRRRRRRREEEEAT!!
I apologize for starting a new thread about this as I am sure the information is out there but asking a quick question will save me time in searching so I appreciate all responses, especially since I am sure the answers to these questions will be repeats. Thanks so much fellas!
If you can't wear it out, burn it off
DarderSauce is offline
Old 07-17-2012, 04:43 PM   #2
jasonbi
jasonbi's Avatar
Fan#: 13305
What I Drive: 2002 SVT
Points 4,592, Level 43
Points: 4,592, Level: 43 Points: 4,592, Level: 43 Points: 4,592, Level: 43
Level Up 21% Completed
FF Reputation: 3 jasonbi Good Standing Member
napa premium if you looking for a good set for not a lot of $$$.....been using them for the last maybe 25,000km with no issues...i painted the hats black when i got them and covered the hub and behind the rotor with anti-seize. i also live in a snowy/salty/sh** ty climate so rust is an issue for me as well!!
#3286 OF 4788
jasonbi is offline
Old 07-17-2012, 05:22 PM   #3
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
Centric is the most popular manufacturer of coated rotor (hats and edges). Just remember these are E-coated which is not as durable as powder coating or paint. It will eventually fade, wear, and rust like any other rotor. But they are, nevertheless, a well made rotor for the price. Other good (non coated) solid rotors include Brembo and the mentioned NAPA premiums.
You are justified in not wanting slotted or especially drilled rotors. Slotted rotors have a place on the track but that's about it. The drilled rotors you see on an occasional Porsche, Benz, etc. bear little resemblance to the ones commonly sold online. Their primary function is to minimize water vapor forming under the huge calipers those cars often have. They have small "cast" in holes that are chamfered and are made of premium (high carbon content) metals. They will still spider web (structural heat induced cracks) and can cost a small fortune to replace. Both drilled and or slotted rotors will also accelerate pad wear. The primary function of a slotted rotor is to scape the rotor surface of any glazing that might occur from overheating. The easiest way to solve this problem is to use a pad with friction material of the proper heat range for the intended use.
Geezer is offline
Old 07-17-2012, 08:00 PM   #4
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
Points 9,384, Level 65
Points: 9,384, Level: 65 Points: 9,384, Level: 65 Points: 9,384, Level: 65
Level Up 12% Completed
Forum Activity 6%
I have centric blank rotors on my impreza and with hawk pads and it stops better than just about anything I have ever driven. It had the oem brakes on it before hand(58k miles) and the change was amazingly pleasing. Stops fast resists heat well and has thus far held up amazingly to my abusive driving. I have yet to cause the brakes to fade due to heat.
2007 Subaru Impreza 2.5i - current DD
I always moderate naked!
bringler26 is offline
Old 07-17-2012, 11:02 PM   #5
DarderSauce
Fan#: 95564
Alright so since all ford foci from 01-11 have the same bolt pattern (4x108 IIRC) all I have to say is I want rear rotors for a ford focus correct? I know it is a dumb question but I would rather sound dumb on the internet than when I am face to face with someone.
Sorry but I have a feeling if I try explaining my brake setup they will look at me like I am a tard/say you can't do that.
Any way, sorry for the noob questions.
Old 07-17-2012, 11:13 PM   #6
bringler26
FUBARCUS
bringler26's Avatar
Fan#: 59705
Forum Activity 6%
where are you ordering from?
Old 07-18-2012, 08:24 AM   #7
DarderSauce
Fan#: 95564
I figured I would just go grab a set of premo's from Napa. Now all I need to get are the break lines.
Old 07-18-2012, 08:41 AM   #8
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,606, Level 53
Points: 6,606, Level: 53 Points: 6,606, Level: 53 Points: 6,606, Level: 53
Level Up 28% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
Stainless lines are a great upgrade.
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 07-18-2012, 10:22 AM   #9
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
Points 18,945, Level 87
Points: 18,945, Level: 87 Points: 18,945, Level: 87 Points: 18,945, Level: 87
Level Up 19% Completed
Forum Activity 7%
FF Reputation: 7 badazz2010focus Good Standing Member
Anyone know who naoes stainless for the front?
badazz2010focus is offline
Old 07-18-2012, 11:43 AM   #10
Geezer
Fan#: 1427
I'd simply tell them you want SVT rotors for the rear (or whatever model you got them from) and front rotors for the particular year and model Focus you have. It need not be anymore difficult than that. If they give you a dumb look simply tell them you upgraded the rear from drums to discs using available stock parts from another model Focus.
Geezer is offline
