Moar TQ Down Low? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-17-2012, 02:46 PM   #11
StockTalon
Guest
Fan#: 94771
What I Drive: 2012 Focus Titanium
FF Reputation: 1 StockTalon Good Standing Member
Originally Posted by JL330 View Post
I'm scared to turbo mine, I'm expecting over 400 rwhp n/a.
86mm in a T4 frame and call it done.
StockTalon is offline
Old 07-17-2012, 04:21 PM   #12
JL330
Fan#: 99616
What I Drive: 2012 silver focus S
FF Reputation: 1 JL330 Good Standing Member
I saw a guy with a similar setup and a more restrictive intake put down 700 with a 76 mm turbo. I'll probably eventually go that route, it's just not in the works until I get my business started. I'd like to get 900 to the wheels when I do though.
JL330 is offline
Old 07-17-2012, 05:56 PM   #13
SkyPilot
Jetsetter
SkyPilot's Avatar
Fan#: 22350
Points 13,753, Level 76
Points: 13,753, Level: 76 Points: 13,753, Level: 76 Points: 13,753, Level: 76
Level Up 26% Completed
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
FF Reputation: 45 SkyPilot Great Standing Member
Buy-Sell-Trade Rating: (18)
Tb = throttle body. It's just a spacer between the throttle body and intake, I honestly don't see it being too beneficial.
You got that right, A TB spacer was beneficial on an older carbureted car because it gave the air and fuel more time to mix before reaching the cylinder. Since on our cars (and every care these days) fuel is introduced right at the cylinder they serve no purpose.
Makes a nifty paperweight tho!
SkyPilot is offline
Old 07-17-2012, 05:58 PM   #14
StockTalon
Guest
Fan#: 94771
A phenolic one will help keep heat out of the intake manifold since, most cars have coolant lines running through the throttle body. It also, indirectly makes the plenum larger.
Old 07-17-2012, 11:26 PM   #15
JL330
Fan#: 99616
The time spent making it isn't worth the gains you'd get from it. Lengthening the intake runners with a phenolic spacer, you could fab this using a gasket to match the ports, would likely be a better option. Until someone tries it, we'll never know.
JL330 is offline
Old 07-19-2012, 11:46 PM   #16
malinowski
Fan#: 100365
What I Drive: 2012 Black SEL
FF Reputation: 1 malinowski Good Standing Member
The engine is a 2 liter 4 banger, low to mid-range torque is gonna be hard to come by. I really don't know much about this engine but I would assume that the most torque you'll pull out of it at usable RPMs could come from a supercharger or stroking/boring the engine.
If you put a supercharger on the engine, it would have a good increase in torque and horsepower throughout the entire powerband, but especially more-so at lower RPMs (compared to a turbocharger or N/A mods).
If you were to bore or stroke the engine, you would increase the displacement, so the engine would go from a 2.0 liter to, say, 2.3 liters. If the Focus puts out 159hp and 146tq at 2000cc stock, or 79.5hp/L and 73tq/L, you could assume that another 300ccs would boost those numbers to 183hp and 168tq. Those numbers are definitely just predictions. But still, a theoretical extra 22 ft lbs of torque would be helpful and would most definitely be felt at the low and mid-range.
My advice for right now-- wait for others to lay the foundation for mods and prove the reliability of them.
malinowski is offline
Old 08-11-2012, 03:30 PM   #17
2005zx4thewin
2005zx4thewin's Avatar
Fan#: 90285
What I Drive: 2005 black zx4
FF Reputation: 1 2005zx4thewin Good Standing Member
Adjustable cam gears allow you to shift your power band either direction, u could add a cam kit to really widen your powerband, along with shorty headers and full exhuast, with a short ram or cold air intake, you could really do work on your powerband as far as tweaking goes
First
On
Race
Day
2005zx4thewin is offline
Old 08-19-2012, 01:47 PM   #18
thepuma09
Fan#: 102716
What I Drive: 2012 race car red Focus
FF Reputation: 1 thepuma09 Good Standing Member
I've always worked on modulars that shine on the top end and suck down low. I can't wait to finish up my 5.4 project, it should make tons of low end and can still rev to around 8k if my intake doesn't max out, not a lot of testing on the boss 260 intakes.
not tryin to hate but a 5.4l that revs to 8 isn't seen everyday wat bottom end u running
thepuma09 is offline
Old 08-19-2012, 09:16 PM   #19
JL330
Fan#: 99616
A 5.4 4v isn't seen every day. Lol
It's got a ford forged crank, before they switched to the cast ones, Mahle pistons and forged I beams but I forgot what brand because I build the block a couple years ago.
I have stage 3 ported c heads and a ported boss 260 intake too. I'm thinking of making it a short runner.
JL330 is offline
