DCT Shift Into Neutral? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-12-2012, 10:22 PM   #1
awsimons
awsimons's Avatar
Fan#: 100921
What I Drive: Sonic Blue 2012 Ford Focus
FF Reputation: 1 awsimons Good Standing Member
I had my first experience with some weird DCT behavior today. I was in stop and go traffic in South Texas heat today and I started getting some clutch slipping. I had a manual before and the same thing would happen in stop and go traffic sometimes.
I've read recommendations about putting VW's DSG into neutral if you were going to be stationary for more than a few seconds rather than keeping your foot on the brake in D. Apparently in D, the clutch stays very close to engaging, possibly causing more heat to build up, whereas in N, the clutch is completely disengaged and no heat is building up. Does our DCT operate like this? Should we be shifting to N in traffic?
Alan
awsimons is offline
Old 07-12-2012, 10:42 PM   #2
MyThIc3LiTe
MyThIc3LiTe's Avatar
Fan#: 95163
What I Drive: 2012 Focus Titanium Blue Candy
FF Reputation: 4 MyThIc3LiTe Good Standing Member
Alan
You really shouldn't need to.
I've fooled around at stoplights and going from N to D just takes more time then leaving it in D.
If anything my foot is on brake and gas and I let it rev to 1500-2000 and then go; no issues. Usually I only do this if I am at the front of the line, never if I am behind someone for obvious reasons.
2012 Ford Focus Titanium Blue Candy Hatch 2009 Suzuki Swift+ - Traded in 2006 Lincoln Zephyr - Traded in
http://www.aniteshjaswalphotography.com
If you live in Edmonton, AB I would be more then happy to do a shoot with you!
MyThIc3LiTe is offline
Old 07-13-2012, 08:44 AM   #3
cbdallas
cbdallas's Avatar
Fan#: 100296
What I Drive: 2014 Titanium 5-speed
Points 2,446, Level 29
Points: 2,446, Level: 29 Points: 2,446, Level: 29 Points: 2,446, Level: 29
Level Up 98% Completed
FF Reputation: 3 cbdallas Good Standing Member
Your car should be able to sit at a stoplight in D without causing itself problems. As far as I can tell, the clutch totally disengages when the transmission receives a signal from the brake light circuit, and the wheel speed = 0.
Having said that....I do put mine in N when I get stopped at lights that I know are long, just so I can take my foot off the brake.
cbdallas is offline
Old 07-13-2012, 10:35 AM   #4
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
What I Drive: 2012 Silver SE Sport
Points 2,299, Level 28
Points: 2,299, Level: 28 Points: 2,299, Level: 28 Points: 2,299, Level: 28
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
Forum Activity 4%
FF Reputation: 13 BetaDnB Great Standing Member
Since these are automated manual transmissions I would assume there's a throwout bearing. I don't know. If there is I would put it in neutral at stops of more than a few seconds.
Sedan Revolution #249 - 2012 SE Sport - ╠╬╝ - Ingot Silver - 201A - K&N w/ snorkel delete - Blox Type R Knob
BetaDnB is offline
Old 07-13-2012, 03:25 PM   #5
AZfocus2012
AZfocus2012's Avatar
Fan#: 92484
What I Drive: 2012 White Platinum SEL 303A Focus
FF Reputation: 2 AZfocus2012 Good Standing Member
In my previous Pontiacs with automatics, I would shift into N at long lights and stop and go congestion, as it was mentioned in the owners manual to do so to reduce heat build up in the torque converter. I tried the same with 2012 and it didn't really work that well. I am not sure but it seems to me the car shifts into N for you when stationary, thus the roll back on hills when letting of the brake from a dead stop. I would be the smart thing for the computer to tell the transmission to do. Not sure if it does it though.
AZfocus2012 is offline
Old 07-13-2012, 03:34 PM   #6
BetaDnB
Drum n Bass Lover
BetaDnB's Avatar
Fan#: 87466
Forum Activity 4%
That doesn't necessarily mean it shifts into neutral. It could be that it's left in first gear with the clutches disengaged.
BetaDnB is offline
Old 07-13-2012, 03:55 PM   #7
AZfocus2012
Fan#: 92484
It could, I said I didn't know, but it seems to me the if all it had to do was release a clutch the process would be quicker. In my car it feels like the car is shifting into gear and releasing the clutch. Just a sort of seat of the pants feel. Maybe some tech or other person with actual knowledge of what it does will step in here and clear it up.
Old 07-13-2012, 04:56 PM   #8
oritpro
oritpro's Avatar
Fan#: 96148
What I Drive: 2012 Subaru Impreza Sport Limited
Points 749, Level 14
Points: 749, Level: 14 Points: 749, Level: 14 Points: 749, Level: 14
Level Up 49% Completed
FF Reputation: 2 oritpro Good Standing Member
@awsimons
I've been experiencing the same problem lately since the temps in my area started climbing into the 90's, and noticed that turning off the A/C seems to help quite a bit.
Have you tried that?
oritpro is offline
Old 07-14-2012, 05:11 PM   #9
suss6052
suss6052's Avatar
Fan#: 95752
Points 10,052, Level 67
Points: 10,052, Level: 67 Points: 10,052, Level: 67 Points: 10,052, Level: 67
Level Up 1% Completed
Level up: 1% Level up: 1% Level up: 1%
Forum Activity 23%
Activity: 23% Activity: 23% Activity: 23%
The DCT uses something referred to in the documentation as neutral idle. Of course initially it was also described as allowing the car to freewheel while under deceleration. I think that portion was deprogrammed out later, but still prior to release in favor of the a-dfso, but it would also put the car into neutral at speed while coasting or decelerating.
It would make more sense that the car would be in neutral with the clutches engaged fully at a stop rather than having the car in first with the clutch disengaged. If its bad for the manual transmission's throwout bearing then chances are they've not done this to what is essentially two sequential 3 speed manual gearboxes in a single case.
Even in select shift manual mode with the car stating that it is in 1st it really is in neutral when the vehicle speed is equal to zero. This is why it takes at least a few fractions of a second or two for the clutch to engage and the gear to be re-selected upon take off. Just as in a manual. If it was simply a matter of releasing the clutch and going it would potentially be quicker, but it would be causing undue wear on throwout bearing and lay shafts.
"Neutral idle: This feature helps improve fuel economy by eliminating the drag a traditional hydraulic transmission puts on the engine when a vehicle is idling"
http://media.ford.com/article_displa...ticle_id=34218
suss6052 is offline
Old 07-14-2012, 09:02 PM   #10
Hodge Podge
Hodge Podge's Avatar
Fan#: 96120
What I Drive: 2012 5-Dr Se Sport Pkg Ingot Silver
FF Reputation: 1 Hodge Podge Good Standing Member
Not sure where I read this (a thread on here somewhere perhaps), but if memory serves, the clutches on the DCT are normally "open" or not engaged, unlike a traditional manual transmission. Picture a clutch pedal working in reverse, where you have to push it to start moving.
____________________
Hodge Podge
2012 Se Ingot Silver 5-Door w/ 201A & Se Sport Package
2001 Silverado 1500 RCLB 4x4 4.8L 5-Speed
Hodge Podge is offline
