No Parking - Tail - License Tag Lights - Fuse blows - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-29-2013, 02:25 PM   #31
FocusFactorDave
Fan#: 37073
What I Drive: '07 Liquid Grey ST
FF Reputation: 1 FocusFactorDave Good Standing Member
I checked out all the wiring again in the trunk and its all neatly wrapped up and has all type of protection, chance of there being a broken wire in there is slim to none, in my opinion. There is a bit of corrosion I didn't notice last time, but not where it makes contact with the bulb, but the part thats connected to the plastic.
Do you know if it matters which way the bulb sits in there?
(EDIT) I tore it all apart, and re cleaned with a dremel tool and some alcohol after and cleaned up the bulbs with some aswell and reinstalled and tried the right side first, was ok.. so I decided to be brave and try the left side again which is a bit more corroded in the inside of the connector from the trunk, but it seems to be alright now.. Nothing really changed besides maybe a little dust and fuzzys. So hopefully the junkyard will take this switch back since I guess I dont need it...
If first you don't succeed... try again..
FocusFactorDave is offline
Old 06-29-2013, 09:40 PM   #32
Milton
Fan#: 89715
What I Drive: 2007 Black Focus SES 2.0 L4 4 Door
Points 325, Level 6
Points: 325, Level: 6 Points: 325, Level: 6 Points: 325, Level: 6
Level Up 50% Completed
Forum Activity 7%
FF Reputation: 8 Milton Good Standing Member
Green corrosion can conduct electricity. In this case that would cause a short blowing the fuse.
Milton is offline
Old 06-30-2013, 05:31 PM   #33
FocusFactorDave
Fan#: 37073
I tried to pop them connects out of the plastic housing but they wouldn't budge so I jammed my dremel tool sanding bit in there to get as much as I could.
I would think any corrosion in that area would of been harmless though since its only touching plastic
Old 06-30-2013, 06:56 PM   #34
Milton
Fan#: 89715
Points 325, Level 6
Forum Activity 7%
Corrosion breeds more corrosion. Get a spray can of electrical contact cleaner and a brush.
Milton is offline
Old 07-01-2013, 09:07 AM   #35
FocusFactorDave
Fan#: 37073
Had to go on a late night run last night for baby formula and on the way home my fuse blew again :| so am going to go out and try to find some electrical cleaner as mentioned, a quick google search i found a handful of expensive cans and ran across this one at home depot for 3$
http://www.homedepot.com/p/CRC-2-26-...4#.UdBOCDtOPVc
Old 07-01-2013, 09:31 AM   #36
Milton
Fan#: 89715
Points 325, Level 6
Forum Activity 7%
Hmmm, I followed the link and I would stay away from any electrical cleaner labeled as a lubricant. I would look for something that dries leaving no residue. That said I would not be against using some dielectric grease.
While cleaning corrosion from electrical contacts IS ALWAYS a good thing and should be done, you may still have an issue elsewhere. If the issue has changed from a constant short to an intermittent short it will be harder to find.
Milton is offline
Old 07-01-2013, 09:35 AM   #37
Milton
Fan#: 89715
Points 325, Level 6
Forum Activity 7%
I would use something along these lines:
http://www.crcindustries.com/ei/prod....aspx?id=03070
Milton is offline
Old 07-01-2013, 09:51 AM   #38
FocusFactorDave
Fan#: 37073
was consdering that aswell, but im always down to save a buck, but being that is available less than a mile away ill go with that instead of running out to ace hardware, I found two different kinds of that CRC at advance auto,
One is safe for plastic parts and also states - A petroleum distillates and alcohol blended precision cleaner designed as an alternative to CFC based cleaners. Cleans contacts, connectors and sensitive electronic equipment. Quick drying, plastic safe formula.
Cleans and protects sensitive electronic equipment
Helps prevent contact failure
Plastic safe
Leaves no residue
Quick drying formula http://shop.advanceautoparts.com/web...searchTerm=crc
then theres this one that states - An aggressive cleaner specifically for electric motors, transformers and machinery. Dissolves grease, oil, dirt and wax without having to remove parts - and is http://shop.advanceautoparts.com/web...searchTerm=crc
Wasn't able to find the same cleaner you mentioned locally. Also what kind of brush would you recommend? Not able to find any brushes besides ones that are like tooth brushes which I don't think would fit in the little contacts
Thanks for your help Milton
Old 07-02-2013, 08:59 PM   #39
FocusFactorDave
Fan#: 37073
that electric contact cleaner didn't do anything at all to the corrosion on the terminals, so I tried to sand em down a bit and sprayed that stuff on it since it says it helps protect, if I blow another fuse Ima end up taking off the connector and replacing it
Old 08-21-2014, 08:23 AM   #40
FocusFactorDave
Fan#: 37073
8 months later and I've run into the same problem once again...
