Any interest in headlight modifications? - Page 28 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-13-2013, 05:24 PM   #271
Mrlandy
Fan#: 99623
What I Drive: 2012 focus titanium hatch
Points 28, Level 1
Points: 28, Level: 1 Points: 28, Level: 1 Points: 28, Level: 1
Level Up 56% Completed
FF Reputation: 3 Mrlandy Good Standing Member
You will need a lockpick, or a mft with the backup cam enabled. Lockpick 2 is $300 and lets you add 3cameras. Heres my full writeup:http://www.focusfanatics.com/forum/s....php?p=4723640
Mrlandy is offline
Old 05-15-2013, 01:16 AM   #272
thejordan
thejordan's Avatar
Fan#: 107706
What I Drive: 2013 SGM Focus 5 Speed
Points 1,041, Level 17
Points: 1,041, Level: 17 Points: 1,041, Level: 17 Points: 1,041, Level: 17
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 4 thejordan Good Standing Member
still looking to sell my retrofits:
thejordan is offline
Old 05-15-2013, 02:20 AM   #273
Now534
Now534's Avatar
Fan#: 76549
What I Drive: 2013 Tuxedo Black ST2
Points 1,795, Level 24
Points: 1,795, Level: 24 Points: 1,795, Level: 24 Points: 1,795, Level: 24
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
FF Reputation: 6 Now534 Good Standing Member
How much you looking to get for them?
Sent from my Rooted Galaxy S3 using FF Mobile
Now534 is online now
Old 05-23-2013, 01:01 PM   #274
amoosenamedhank
Fan#: 96374
What I Drive: 2012 SE Hatch
Points 880, Level 15
Points: 880, Level: 15 Points: 880, Level: 15 Points: 880, Level: 15
Level Up 80% Completed
FF Reputation: 3 amoosenamedhank Good Standing Member
So where did this land on the best method for opening them. Oven vs cutting the black housing.
What's that?? You'd like an eco-tune...
amoosenamedhank is offline
Old 05-30-2013, 01:16 PM   #275
Franmorganmk3
Fan#: 105229
What I Drive: 2013 ford focus zetec s 1.6 Red
FF Reputation: 1 Franmorganmk3 Good Standing Member
How did you bypass the " dipped beam fault" ?
Resistors or relays or something ?
Franmorganmk3 is offline
Old 05-30-2013, 01:42 PM   #276
Mrlandy
Fan#: 99623
Points 28, Level 1
I did the heat gun trick and spent nearly 4 hours opening my headlights. On my second set, I used a dremel to cut off the top housing lip and pried the front right off. Dremel was better for me, it took 20 minutes. Hot knife took way too long even with a 60 watt iron.
Mrlandy is offline
Old 09-08-2013, 06:03 AM   #277
xMarcox
xMarcox's Avatar
Fan#: 105697
What I Drive: Focus mk3 2012 Sport 115 Tdci
Points 542, Level 10
Points: 542, Level: 10 Points: 542, Level: 10 Points: 542, Level: 10
Level Up 84% Completed
FF Reputation: 1 xMarcox Good Standing Member
Why not "cook" the headlights? is a good idea?
xMarcox is offline
Old 09-08-2013, 02:28 PM   #278
JRicky
Fan#: 84998
What I Drive: 2012 Kona Blue SE Sport
Points 267, Level 5
Points: 267, Level: 5 Points: 267, Level: 5 Points: 267, Level: 5
Level Up 34% Completed
FF Reputation: 1 JRicky Good Standing Member
I cut mine too, and painted more than just the Ti ones have..
JRicky is offline
Old 10-03-2013, 07:42 PM   #279
FX4life
FX4life's Avatar
Fan#: 99227
What I Drive: 2012 White Platinum Titanium
FF Reputation: 1 FX4life Good Standing Member
Hey guys. Started my retrofit this afternoon, first headlight came apart with little effort compared to the lens on my truck.
I've hit a snag though, I ground out enough material from the locking part of the bulb socket to get the projector through the bulb hole, but not nearly enough of the projector's thread pokes through to get the silicone thing, lock ring, washer and bulb holder in place. I can only thread the main nut enough to hold it in place. Anyone have any suggestions on how I can get the projector far enough back in the housing to get it secured?
2012 White Platinum Titanium Hatchback - Loaded - 35% tint, Bridgestone Blizzak WS70 winter tires
2013 Oxford White F-150 FX4 5.0 Supercrew - Loaded - Tint-to-match, Wheel-well liners, 3M Protection, Spray-in bedliner
FX4life is offline
Old 01-14-2014, 05:20 PM   #280
klotche
klotche's Avatar
Fan#: 91834
What I Drive: 2012, Oxford white, Focus
Points 4,453, Level 42
Points: 4,453, Level: 42 Points: 4,453, Level: 42 Points: 4,453, Level: 42
Level Up 52% Completed
Forum Activity 3%
FF Reputation: 3 klotche Good Standing Member
Originally Posted by craigsfocus View Post
Finally got the projectors installed! This is a very time consuming thing especially if you live in a apartment without a garage.
Here is my write up.
Disclaimer: I am no way responsible for any damages to your car or headlights due to your decision to tackle this project. If you feel this project is too challenging for you, hire a professional to do this modification.
Things you will need:
1) BI-XENON MORIMOTO MINI STAGE III KIT (H1) with Mini Gatling Gun Shrouds & H11 Wire Harness & 35w Bulbs/Ballasts- $270.00
2) Morimoto H11 Stand Alone Can Bus Harness- $30.00
3) Lots of Time
4) Lots of Patience
Step One: Very carefully get the headlights out of the car by removing the two screws and sliding them forward to remove them off the car. Then remove the headlight plugs.
Step Two: Now pre heat your oven to 275 degrees. While you are waiting for the oven to heat up, take a sharp hobby knife around the gap of the headlight to score the adhesive, as you are doing that remove the access adhesive that is sticking out from the factory. Once the oven is heated up, place one of the headlights in the oven for 7-8 minutes. Once 7-8 minutes have passed remove from the oven (BE CAREFUL ITS HOT SO USE OVEN MITTS) and start going at the headlight adhesive with sharp razor and scoring the adhesive, try to remove as much as possible. I also used a small flat head screw driver to pry up on the black plastic. BE CAREFUL TO WITH THE PLASTIC BECAUSE ITS HOT AND SOFT, IF YOU PRESS TOO HARD ON THE PLASTIC WITH THE FLAT HEAD YOU WILL PUNCTURE IT OR TEAR IT. Repeat this process until you have the headlight separated. Once you have the headlight separated, you need to remove the reflector from the black plastic piece. It just pops off with a some pulling. Firmly but carefully. If you wanna remove the crome inner-ring of the lens, you need to remove the screws by the turn signal housing with a T-10 screw driver. The it will require some wiggling around and it will come out easily.
All apart
Step Three: Next remove the little head light bulb end cap. Its a single screw (T-20) on the base of the reflector. Once you get that out, take a dremel and sand some material out of the bulb socket, go a little at a time until you are able to fit the projector in the hole snugly. Now. Where the bulb end cap was, grind out a little material so you can get the projector solenoid wire through it. Once you are done with that. Clean up all the dust. Install the silicon washer on the projector and install the projector by feeding the threads through the hole. If you look on the back of the projector (the shiny side) on the lip you will see "TOP" make sure that it is upright and on the top and as level as possible. Once you get the projector in place, you will need to wire the solenoid wire into the high beam harness. I pushed the blade tips into the backside of the pin connector on the black housing. Once you get that done, you will need to slice the rubber access covers that go on the backside of the black housing to make way for the the factory wire and the bulb wiring. The bulb wiring from Morimoto has a rubber grommet on it so I just pulled that through. Now reattach the reflector housing to the black housing by aligning the holes to the silver poles, done this firmly but carefully.
This is where I did the grinding to the slot where the little bulb end cap was.
This picture shows where the wire went through the slot and how the silicon grommet has to go on the projector.
The projector installed
The projector installed with the Min Gatling Gun Shroud.
How I fed the wires through the rubber plugs
Step Four: Reassemble the entire headlight assembly. Make sure you have removed most of the factory adhesive if not all. Now lay down your butle adhesive that you got from TRS. This stuff is very reactive so as soon as you start pushing the lens back on, it will start sticking so make sure you have the two plastic pins lined up as you are placing the lens back on. Then start pushing the lens on firmly. Once you have the headlights together place them in the oven at 275 degrees for 7-8 minutes. Once they come out the oven you may have to press some places of the headlight together again. Let the headlights cool off.
Step 5: Install the headlights into the car and wire the bulbs and ballasts. Everything in the kit connects together with 9006 plugs. I tried using the Stand alone Can-Bus Harness by itself as TRS advertises but it doesn't work, well it works part of the time. I think the harness overheats. So you have to use the regular harness that TRS normally packs in their kits.
Very Awesome, Good job, your car is very nice looking!
I absolutely want retrofit projector as I think HID in stock housing are somehow dangerous....
I have a question about what you bought,
"BI-XENON MORIMOTO MINI STAGE III KIT (H1) with Mini Gatling Gun Shrouds"
they are Bi-Xenon? once they are installed, you can put single beam HID in them and keep your High beam on the other bulb? (halogen bulb).
I already have my HID kit and all that working perfectly on low beams only, so i'm wondering what I need to buy exactly...
Thanks for your help guyz,
and again Craig, very well done ! looks pretty !
klotche is offline
