Any interest in headlight modifications? - Page 20 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-16-2013, 07:20 PM   #191
thejordan
thejordan's Avatar
Fan#: 107706
What I Drive: 2013 SGM Focus 5 Speed
Points 1,041, Level 17
Points: 1,041, Level: 17 Points: 1,041, Level: 17 Points: 1,041, Level: 17
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 4 thejordan Good Standing Member
Originally Posted by JL330 View Post
I royally messed up the last set of headlights I put in the oven. One of the lenses melted a little and both of them ended up looking etched really bad. That oven may have run hotter than it should though.
It should only be on warm which is maybe 250 degrees.
Originally Posted by e30og View Post
Someone correct me if Im wrong, but condensation just means either a crack somewhere or some part of the edges glued together isnt 100% sealed, right? As long as you really get the pieces glued together well, there should be no issue?
Also Chickenmuffin did this with a heat gun, which wont heat the entire lens. Here is his writeup:
http://www.focusfanatics.com/forum/s...eadlight+bezel
Ya it just means it's not perfectly sealed. Do not use a heat gun, you risk cracking the lens when pulling it apart due to the uneven heat distribution.
thejordan is offline
Old 01-16-2013, 10:47 PM   #192
e30og
e30og's Avatar
Fan#: 83765
What I Drive: '13 SG 4dr, Manual
FF Reputation: 2 e30og Good Standing Member
explain please?
e30og is offline
Old 01-16-2013, 10:56 PM   #193
novus
novus's Avatar
Fan#: 107022
What I Drive: '12 Tuxedo Black Focus SEL
Points 933, Level 16
Points: 933, Level: 16 Points: 933, Level: 16 Points: 933, Level: 16
Level Up 33% Completed
Forum Activity 2%
FF Reputation: 5 novus Good Standing Member
Thought about doing this for a while. But buying just the projectors from TRS and the HIDs from DDMTuning. Saving a bit of $$ in the end.
novus is offline
Old 01-17-2013, 12:51 AM   #194
thejordan
thejordan's Avatar
Fan#: 107706
explain please?
just use an oven.
Old 01-20-2013, 03:51 PM   #195
-Shin-
Fan#: 105167
What I Drive: MK3 Focus
FF Reputation: 1 -Shin- Good Standing Member
Retrofit complete.
Headlight opened and closed with Dremel Versatip, amazing tool.
Tnx to Craigsfocus and Chickenmuffn for inspiration.
-Shin- is offline
Old 01-20-2013, 04:27 PM   #196
JL330
Fan#: 99616
What I Drive: 2012 silver focus S
FF Reputation: 1 JL330 Good Standing Member
I may have to invest in this versatip. How hard is the sealing procedure with it? Do you just melt it back together?
JL330 is offline
Old 01-20-2013, 07:02 PM   #197
-Shin-
Fan#: 105167
Yes, melt back. Cut precise an regular in the opening and it will be easier to melt it back.
Flat blade to cut, large rounded tip to melt back. Need a lot of patience, however.
You can see detailed picture in the link.
-Shin- is offline
Old 01-20-2013, 10:10 PM   #198
novus
novus's Avatar
Fan#: 107022
Forum Activity 2%
Originally Posted by -Shin- View Post
Retrofit complete.
Here full thread:
http://fordfocus2011.forumcommunity.net/?t=53480773
Can you bring the thread here?
You do not have permission to view this topic
Don't really feel like joining another forum just to view a thread.
novus is offline
Old 01-20-2013, 11:36 PM   #199
thejordan
thejordan's Avatar
Fan#: 107706
+1 please no cross-posting.
I have a set of projectors sitting on my desk right now too :D
Old 01-21-2013, 05:04 AM   #200
-Shin-
Fan#: 105167
images here, in chronological order:
-Shin- is offline
