Any interest in headlight modifications? - Page 19 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-05-2013, 05:00 PM   #181
JL330
Fan#: 99616
What I Drive: 2012 silver focus S
FF Reputation: 1 JL330 Good Standing Member
Originally Posted by -Shin- View Post
On this car you need also the resistors or CAN-BUS wire harness.
Anyway, i'm going to cut the headlight, a spare pair, like this:
http://www.youtube.com/watch?v=xSD-eW6tEGk
and melt plastic back like this:
http://www.youtube.com/watch?v=eQpr4Umy8CI
in addition, i'm going to seal and add strenght on the joint with something like this:
http://www.stealth316.com/2-dp8005.htm
a good one on PP plastic.
I can't really tell what he's doing in the 2nd vid. It looks too easy so I'm hoping I can pull it off. I'm still scared to use my stock headlights.
JL330 is offline
Old 01-13-2013, 07:15 PM   #182
thejordan
thejordan's Avatar
Fan#: 107706
What I Drive: 2013 SGM Focus 5 Speed
Points 1,041, Level 17
Points: 1,041, Level: 17 Points: 1,041, Level: 17 Points: 1,041, Level: 17
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 4 thejordan Good Standing Member
At the low temp of 250-275, ovens (especially older ones) are inaccurate. Try it at 250 for 15-20min. Make sure remove all of the torx screws (I don't know how many). Use a razor blade or small pocket knife to cut the adhesive (it smells like pine tar). Use 3M clear adhesive to reseal. Make sure you wear gloves so you don't contaminate the inside bits. I use work gloves when prying it apart because it's pretty hot. I also use a couple flat head screwdrivers to help pry the lens off. Just be patient and take your time. Sometimes if you take too long, you'll have to throw it back in the oven.
BTW, for those on a budget, you can email The Retrofit Source asking for the previous gen Morimoto mini H1 with mini-gatling shrouds, they're a bit cheaper.
I've done retrofits on plenty of Subarus, and personally, I don't think the 5 hours will be worth it for me to do it on a new Focus.
thejordan is offline
Old 01-14-2013, 02:08 PM   #183
Kevastator
Kevastator's Avatar
Fan#: 104674
What I Drive: 05 Slowbaru Outback
FF Reputation: 2 Kevastator Good Standing Member
When resealing, is there something that you do to ensure you don't get any condensation spots in the lens?
College Yo
[Rally Revolution #7]
ASPECT Motorsports
Kevastator is offline
Old 01-14-2013, 04:04 PM   #184
thejordan
thejordan's Avatar
Fan#: 107706
yeah, add the 3M clear silicone adhesive, push together, put in oven for 15min, and push together again and put the screws in.
Old 01-14-2013, 04:13 PM   #185
Kevastator
Kevastator's Avatar
Fan#: 104674
And this kept out condensation for you?
College Yo
ASPECT Motorsports
Old 01-14-2013, 07:42 PM   #186
JL330
Fan#: 99616
I royally messed up the last set of headlights I put in the oven. One of the lenses melted a little and both of them ended up looking etched really bad. That oven may have run hotter than it should though.
JL330 is offline
Old 01-16-2013, 07:55 AM   #187
-Shin-
Fan#: 105167
What I Drive: MK3 Focus
FF Reputation: 1 -Shin- Good Standing Member
Hi craigsfocus,
Originally Posted by craigsfocus View Post
... you need to remove the reflector from the black plastic piece. It just pops off with a some pulling. Firmly but carefully. ...
This picture shows where the wire went through the slot and how the silicon grommet has to go on the projector.
I have 2 questions for you:
1) removing chrome reflector: of the 3 joint balls, one is easy with hands, second with nr.11 wrench, the third is very difficult: it doesnt pop up. I feel polycarbonate may crack.. Did you only pull?
2) in the photo above: why did you use the H4 silicon grommet and not the H7 one? Isn't H7 your stock halogen bulb?
TIA
-Shin- is offline
Old 01-16-2013, 10:36 AM   #188
Fraychild
Fraychild's Avatar
Fan#: 37309
What I Drive: 2012 Ford Focus SE
Points 62, Level 1
Points: 62, Level: 1 Points: 62, Level: 1 Points: 62, Level: 1
Level Up 24% Completed
FF Reputation: 2 Fraychild Good Standing Member
Hi craigsfocus,
TIA
In the US, we don't have H7 in our headlights at all; they come with H11 for Low Beams and H1 for High Beams.
2012 Candy Red SE Manual... I smell serious trouble.
Fraychild is offline
Old 01-16-2013, 11:01 AM   #189
-Shin-
Fan#: 105167
ok: h11 for low beam,
but in the The Retrofit Source guide (link: http://www.theretrofitsource.com/pdf..._Guide_2-2.pdf) there is H4 silicon grommet, large one like above photo, and non h4 one (smaller).
So H7 or H11 is the same.
-Shin- is offline
Old 01-16-2013, 01:08 PM   #190
e30og
e30og's Avatar
Fan#: 83765
What I Drive: '13 SG 4dr, Manual
FF Reputation: 2 e30og Good Standing Member
Someone correct me if Im wrong, but condensation just means either a crack somewhere or some part of the edges glued together isnt 100% sealed, right? As long as you really get the pieces glued together well, there should be no issue?
Also Chickenmuffin did this with a heat gun, which wont heat the entire lens. Here is his writeup:
http://www.focusfanatics.com/forum/s...eadlight+bezel
e30og is offline
