Any interest in headlight modifications? - Page 16 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-23-2012, 08:21 AM   #151
craigsfocus
craigsfocus's Avatar
Fan#: 97985
What I Drive: 2012 Race Red SE
Points 3,162, Level 34
Points: 3,162, Level: 34 Points: 3,162, Level: 34 Points: 3,162, Level: 34
Level Up 75% Completed
FF Reputation: 6 craigsfocus Good Standing Member
Originally Posted by calebstubstad View Post
when you say time consuming, how long did it take? (hours? days?)
Hours. It took me probably about 8-10 hours.
2012 Ford Focus SE Hatchback Race Red. 203A Spec. Window Tint. K&N Typhoon CAI. FSWerks Race Exhaust. Weathertech Digital Fit Floormats. HIDs with Projectors. Build Date: 2/14/2012
Active Duty US Army. MOS 91E (Machinist). OEF Vet.
craigsfocus is offline
Old 10-23-2012, 04:39 PM   #152
Fraychild
Fraychild's Avatar
Fan#: 37309
What I Drive: 2012 Ford Focus SE
Points 62, Level 1
Points: 62, Level: 1 Points: 62, Level: 1 Points: 62, Level: 1
Level Up 24% Completed
FF Reputation: 2 Fraychild Good Standing Member
Hey Craig,
Sorry for all the questions; I think you mentioned that you baked them one at a time and tried to pry them open individually? Did you sit them on anything (tray, foil) when you put them in the oven? Or you just sat the housing on the grill as is? Also, you painted some of your Chrome parts black - which paint did you use? Were you worried about condensation/droplets after opening the housing? (I know it's not exactly air-tight), but just curious... Thanks for all the info!
2012 Candy Red SE Manual... I smell serious trouble.
Fraychild is offline
Old 10-23-2012, 08:20 PM   #153
craigsfocus
Fan#: 97985
Originally Posted by Fraychild View Post
Hey Craig,
Its cool. I like to help out when I can.
I just set each headlight on the rack in the oven. One at a time. I had some condensation because I didn't evenly place the new adhesive in one spot correctly. So I just corrected it and reheated to reseal it and its fine now.
I used Krylon Fusion For Plastic-Stain Black. You can get it at Wal-Mart
http://www.amazon.com/Krylon-2421-Fu.../dp/B000C0158E
Old 10-24-2012, 06:24 PM   #154
-Shin-
Fan#: 105167
What I Drive: MK3 Focus
FF Reputation: 1 -Shin- Good Standing Member
Amazing result Craig, I'm seriously thinking on this work.
You used Morimoto Mini because of size or you think a larger model will fit? There is also a problem in lenght?
-Shin- is offline
Old 10-24-2012, 07:39 PM   #155
craigsfocus
Fan#: 97985
I used the Morimoto Mini kit because it offered relatively easy installation because of the threaded end. Its was also a size I was comfortable with as I was traveling down a dark untraveled road with this project. I think there is about an inch of clearance from the lens to the lens on the projector. The bigger projectors will not work unless you plan on cutting into the reflectors.
The Morimoto Mini kit also offered a great value. I wanted to keep the cost down without sacrificing quality. That makes this kit an affordable alternative to the Factory Projector lights for now.
Old 10-25-2012, 11:22 AM   #156
-Shin-
Fan#: 105167
So you didnt cut the reflector? You made a thread in the original hole for the alogen lamp?
-Shin- is offline
Old 10-25-2012, 12:49 PM   #157
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
Points 2,716, Level 31
Points: 2,716, Level: 31 Points: 2,716, Level: 31 Points: 2,716, Level: 31
Level Up 78% Completed
FF Reputation: 4 calebstubstad Good Standing Member
no, the "threaded end" sticks through the hole that the halogen bulb did, its like a perfect fit, then theres a silicone right you put on, nut, then lock nut that twist onto the threads of the projector. it just attaches perfectly to the original housing, and then you can either drill a small hole for the solenoid (high beam control) wires, or just run them through the back as well. and if it's done right, you should barely have to, if at all, aim the lights again, and they will be stuck right in exactly how the halogen bulb was. the morimoto minis from TRS are a perfect fit for the focus, no doubt
Rally Revolution #43
[HOONIGAN]
Originally Posted by matmatician View Post
Not the bear the zoo deserves, but the bear the zoo needs.
calebstubstad is offline
Old 10-25-2012, 01:19 PM   #158
-Shin-
Fan#: 105167
Wow this is great.
The weight of the projector requires another fix point? For example a lower support between housing and projector? To avoid oscillations or breakage at the mounting point?
-Shin- is offline
Old 10-25-2012, 01:25 PM   #159
calebstubstad
Chef Boyardee
Fan#: 103240
not that i've seen in my research of doing this. just make sure you get the lock nut tight as crap. my research has been for an mk1, but i cant imagine its too different other than bulb size really. ask the guys at TRS, theyll get you the best you can buy for the cheapest. easy to work with, and super sweet dudes.
[HOONIGAN]
Old 11-12-2012, 05:11 PM   #160
HornedFrog05
HornedFrog05's Avatar
Fan#: 97892
What I Drive: 2013 Tuxedo Black ST2
FF Reputation: 6 HornedFrog05 Good Standing Member
This is F-ing sick... damn I wish I had some patience.
HornedFrog05 is offline
