Any interest in headlight modifications? - Page 15 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-30-2012, 02:16 AM   #141
craigsfocus
craigsfocus's Avatar
Fan#: 97985
What I Drive: 2012 Race Red SE
Points 3,162, Level 34
Points: 3,162, Level: 34 Points: 3,162, Level: 34 Points: 3,162, Level: 34
Level Up 75% Completed
FF Reputation: 6 craigsfocus Good Standing Member
Originally Posted by F35-JSF View Post
Question did you remove all the wiring out of the headlight before you put it in the oven or just the bulbs?
I just removed the rubber plugs and the bulbs. The wires did get a little soft but they were fine. My setup is still working perfectly.
Sorry, I have been pretty busy lately so I haven't been on the forum for a while
2012 Ford Focus SE Hatchback Race Red. 203A Spec. Window Tint. K&N Typhoon CAI. FSWerks Race Exhaust. Weathertech Digital Fit Floormats. HIDs with Projectors. Build Date: 2/14/2012
Active Duty US Army. MOS 91E (Machinist). OEF Vet.
craigsfocus is offline
Old 10-01-2012, 10:54 AM   #142
Fraychild
Fraychild's Avatar
Fan#: 37309
What I Drive: 2012 Ford Focus SE
Points 62, Level 1
Points: 62, Level: 1 Points: 62, Level: 1 Points: 62, Level: 1
Level Up 24% Completed
FF Reputation: 2 Fraychild Good Standing Member
Hey Craig - Do you think you could've done the same using a Heat Gun instead of putting them in the oven? I'm really interested in this and I'm planning on giving a try really soon; but I'm a bit concerned with the whole "baking" business...
Thanks!
2012 Candy Red SE Manual... I smell serious trouble.
Fraychild is offline
Old 10-04-2012, 09:58 PM   #143
craigsfocus
Fan#: 97985
Thanks!
No. I do not believe the heat gun will work for this. Not enough heat and I think the plastic will start melting before you got the adhesive to soften and by the time it go from one end of the headlight to the other, it will have cooled off and the adhesive will be hard again. The adhesive is serious. The baking is safe if you stay within the time limits/ temperature and you are careful, very careful. It takes a lot of patience and time.
Old 10-04-2012, 10:36 PM   #144
beefcrinkle
Fan#: 101144
What I Drive: top banna dodge charger
FF Reputation: 1 beefcrinkle Good Standing Member
craig you should start a shop doing this have a core return on good lights so people just pay a fee and if they send you the stock lights then you only have to invest in one set and can make a profit after you recover from the loss.
beefcrinkle is offline
Old 10-04-2012, 10:43 PM   #145
F35-JSF
F35-JSF's Avatar
Fan#: 102775
What I Drive: 13' Tuxedo Black ST3, 08' ZZR-600
Points 588, Level 11
Points: 588, Level: 11 Points: 588, Level: 11 Points: 588, Level: 11
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 4%
FF Reputation: 2 F35-JSF Good Standing Member
Que me up for that..
TB is not a color, it's a part time job.
Originally Posted by MoncefA33 View Post
:lol:Modding is whatever you define it as. Some people wanna boost, some people need 10 TVs, and some of these homos feel compelled to LED their cars front to back.
F35-JSF is offline
Old 10-04-2012, 11:18 PM   #146
craigsfocus
Fan#: 97985
I would be have barely have any free time as it is. The Army keeps me pretty busy. Plus, I will be starting EOD school in January so most of my focus will be directed toward that for a year.
Old 10-17-2012, 01:09 PM   #147
Fraychild
Fraychild's Avatar
Fan#: 37309
Points 62, Level 1
Thanks for the feedback on the heat gun - I'll take your word for it since you've already been through the process and know what you dealt with! I'm really considering this, so if/when I decide to jump on that ship; I'll definitely share some more pics with everyone!
Old 10-17-2012, 04:30 PM   #148
jfsiutza
jfsiutza's Avatar
Fan#: 97007
What I Drive: 2012 Ford Focus SE Hatch Tuxedo Blk
Points 1,113, Level 18
Points: 1,113, Level: 18 Points: 1,113, Level: 18 Points: 1,113, Level: 18
Level Up 13% Completed
FF Reputation: 1 jfsiutza Good Standing Member
hmmmmmmm open up shop huh? but who will buy?
jfsiutza is offline
Old 10-17-2012, 04:51 PM   #149
Chickenmuffn
Fan#: 103458
What I Drive: 2011 Focus Zetec 1.6
FF Reputation: 9 Chickenmuffn Good Standing Member
Hey man, from what I understand the warning light is because your HID's are pulling less amps from the BCM so the BCM thinks your bulbs are blown. This is because HID use less wattage but more likey because you are using a relay harness so the current draw is very low.
To solve this problem, I believe you will need something like this: (a 6 ohm 50 watt resistor)
http://www.ebay.co.uk/itm/2-X-LED-Tu...item20c8b57b15
You will have to wire this into your original headlight +ve wire. (This is the factory wire that you plugged into the relay harness). So one end of this resistor must be tapped into that +ve wire, and the other end should be grounded to the chassis. I believe this will simulate the correct current draw and remove your warning. You must do this to both sides. (please note, this is my understanding of this issue and is what I will be doing in the next month when I retrofit. I am by no means an automotive electrical expert, but I have done previous retrofits before.)
*EDIT: Oh the reason why the CANBUS harness you purchased didn't work was because they are not made to be used with the relay harness.
Chickenmuffn is offline
Old 10-23-2012, 08:11 AM   #150
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
Points 2,716, Level 31
Points: 2,716, Level: 31 Points: 2,716, Level: 31 Points: 2,716, Level: 31
Level Up 78% Completed
FF Reputation: 4 calebstubstad Good Standing Member
when you say time consuming, how long did it take? (hours? days?)
Rally Revolution #43
[HOONIGAN]
Originally Posted by matmatician View Post
Not the bear the zoo deserves, but the bear the zoo needs.
calebstubstad is offline
