Dropping a Valve - PREVENTION - ??? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-10-2012, 05:09 PM   #1
focusauto01
Fan#: 101157
What I Drive: 2002
FF Reputation: 1 focusauto01 Good Standing Member
Does anyone have any directions or special steps for preventing Valve Seating by doing general maintenance?
How many of you installed a new head? Where can you purchase one for a decent price?
focusauto01 is offline
Old 07-10-2012, 09:15 PM   #2
starfuryt550
I Speed Often.
starfuryt550's Avatar
Fan#: 18440
What I Drive: Audi S4, Turbo ZX3
Points 23,065, Level 93
Points: 23,065, Level: 93 Points: 23,065, Level: 93 Points: 23,065, Level: 93
Level Up 72% Completed
Forum Activity 23%
Activity: 23% Activity: 23% Activity: 23%
FF Reputation: 23 starfuryt550 Great Standing Member
Buy-Sell-Trade Rating: (58)
eBay had new, re-manufactured heads for cheap. They also have the valve seats fixed.
Your best prevention? Get a different motor.
Daily: Audi S4 b5 | Project: Turbo ZX3
LED Conversions | Vinyl Carbon Wrapping | Powdercoated Valve Covers
starfuryt550 is offline
Old 07-10-2012, 10:12 PM   #3
roughrider3211
roughrider3211's Avatar
Fan#: 96990
What I Drive: 2011,cloud9white,se
Points 55, Level 1
Points: 55, Level: 1 Points: 55, Level: 1 Points: 55, Level: 1
Level Up 10% Completed
FF Reputation: 1 roughrider3211 Good Standing Member
If you dont mind a check engine light unhook the vacuum going to the egr valve and cap off the line
Sent from my DROID RAZR using FF Mobile
roughrider3211 is offline
Old 07-13-2012, 12:55 AM   #4
amc49
Fan#: 96610
Points 3,279, Level 35
Points: 3,279, Level: 35 Points: 3,279, Level: 35 Points: 3,279, Level: 35
Level Up 53% Completed
Forum Activity 13%
It's not preventable with normal maintenance. The head is aluminum and the seat is steel, the aluminum expands more with heat and sooner or later the part will work loose and fall out. The seat could have been engineered by design to not do so, but Ford elected not to do that.
Luck of the draw...............
amc49 is offline
Old 07-13-2012, 09:40 AM   #5
budmur
Fan#: 97970
What I Drive: 2011 Black Focus SEL
FF Reputation: 1 budmur Good Standing Member
Just out of curiosity, how would dropping your fuel mileage and increasing the cylinder/combustion chamber temperature (both caused by lack of EGR) prevent valve seats from popping out?
budmur is offline
Old 07-13-2012, 09:41 AM   #6
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,649, Level 94
Points: 23,649, Level: 94 Points: 23,649, Level: 94 Points: 23,649, Level: 94
Level Up 30% Completed
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
^^ this.
mikebontoft is offline
Old 07-13-2012, 08:09 PM   #7
amc49
Fan#: 96610
Forum Activity 13%
It won't, guy's dreamin'..............
amc49 is offline
Old 07-14-2012, 08:07 AM   #8
roughrider3211
Fan#: 96990
Points 55, Level 1
It will because now the two metal are staying the same temps constantly instead of the two metals of constantly cooling and heat and well fuel suffers a bit it still better then driving and all the sudden car runs like shit or just locks up and i have done a test on 2 2001 my wifes is still with 255078 miles orginal owns was us my 2001 die at 175154 miles try and dont like undo it as simple as that
Old 07-14-2012, 08:31 AM   #9
poppop
poppop's Avatar
Fan#: 59702
What I Drive: 2001,Red,LX
Points 251, Level 5
Points: 251, Level: 5 Points: 251, Level: 5 Points: 251, Level: 5
Level Up 2% Completed
Forum Activity 2%
FF Reputation: 2 poppop Good Standing Member
http://mechdb.com/index.php/Valve_seat
poppop is offline
Old 07-14-2012, 09:13 AM   #10
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,930, Level 100
Points: 51,930, Level: 100 Points: 51,930, Level: 100 Points: 51,930, Level: 100
Level Up 0% Completed
Forum Activity 34%
Activity: 34% Activity: 34% Activity: 34%
Buy-Sell-Trade Rating: (28)
Any time you put Alum and steel under the same conditions (combustion chamber) you wont have the same temps , the valve seat is there to also remove heat from the valve,
to say the head is aluminum and the seat is steel, the aluminum expands more with heat and sooner or later the part will work loose and fall out. is just silly there are BILLIONS of Alum heads out there that dont have the issues of the SPI head , the problem with the SPI head was that SOME of the seats were not install tight enough in the head and they come loose
Unhooking the EGR valve wont keep the seat from falling out but it also wont make for higher EGT and bad MPG , Yes I know what the EGR does and how it works , I also know what the EGT goes to on an engine before and after I have removed them and see no drop in MPG at all and on some a gain in removing the EGR
In my opinion the EGR is 90% emmisions , 9% BS and 1% useable and very questionable on the 1% in my opinion
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
