Go Back   Focus Fanatics > Ford Focus Tech Discussions > General Forced Induction
General Forced Induction The place to chat about turbochargers, superchargers and Nitrous systems.
Old 07-08-2012, 02:54 PM   #1
beansfocus
beansfocus's Avatar
Fan#: 83771
What I Drive: A dark haired donkey!!
FF Reputation: 1 beansfocus Good Standing Member
fswerks stage 2 possibly have a dying cylinder
About 4 months ago I purchased a used fsw stage 2 kit for my 2009 Focus with a stock 2.0 duratec. Threw it on my car, got it tuned all was well.
Then oh about a month ago, I started noticing a bunch of white/oily smoke coming out from both my valve cover breather tube and pcv delete tube that both route under the car.
I did a compression test and results were 1.) 160 3.) 165 4.)160 2.) 110.
Now Cylinder 2 is obviously low, and I had oil on the spark plug threads of 1 and 2 which would indicate valve cover gasket, as it was just on the threads not up on the porcelain.
I poured an oil quart cap full of oil down cylinder 2 and tested compression again, came up to 155 which would cause me to believe that the oil rings are bad??
Anyone have any thoughts?
Thanks!
beansfocus is offline
Fan#: 1
Old 07-08-2012, 03:47 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 2002 Land Yacht (Windstar)
FF Reputation: 263 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
I'm going to refer you to the Forced Induction forum where the experts on these modifications reside. I'm going to say you're right though, you have one bad compression ring on that cylinder.
Moved to Ecoboost and Forced Induction Chat.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 07-08-2012, 04:59 PM   #3
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
FF Reputation: 4 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (10)
yea im going to assume that as well. it isnt really a hard thing to replace. just alot of thigns to take off to get to. bout a weekend job thou
FF MODERATOR
RISE AGAIN EGGYOLK130 WHP 124 WTQ ZETEC CREW #271
RIFF CREW
TURBO DYNO COMING SOON
ZXthrizzle05 is offline
Old 07-08-2012, 05:11 PM   #4
beansfocus
beansfocus's Avatar
Fan#: 83771
I assume its easy enough to pull the oil pan and head and do it while the block is still in the car?
I'm just wondering if I'd be better off buying a used motor to throw in or building this one, instead of just fixing the issue??
Old 07-08-2012, 07:16 PM   #5
ZXthrizzle05
TURBO ZX3
Fan#: 24434
depends on your budget. either way all you have to do is yea pull the pan and hea doff while its still in the car or you can pull it out for easier access. an while ur there just erplace all the rings so you can start with a clean slate
FF MODERATOR
RIFF CREW
Old 07-09-2012, 05:51 AM   #6
whynotthinkwhynot
Captain TMI
Fan#: 18416
You can't put rings in through underneath, so you have to take the head off.
Be eclectic.
Old 07-09-2012, 09:38 AM   #7
beansfocus
beansfocus's Avatar
Fan#: 83771
yup I figured I'd need to pull the head. So I'm really contemplating going that route:
Now should I purchase oem parts:
Head gasket
Rings
Connecting rod bearings
Or do are there better alternatives for a mild boost application?
RockAuto seems to have some of the best prices on OEM parts that I could find. I'm not sure where to look into aftermarkets rings, etc..
Old 07-09-2012, 02:05 PM   #8
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Well if I were u id go for the more stronger route. Cuz u can run large boost amount then and small amount. It wouldn't hurt a thing
FF MODERATOR
RIFF CREW
Old 07-09-2012, 02:26 PM   #9
beansfocus
beansfocus's Avatar
Fan#: 83771
I agree with that, now where would I hunt for parts then?
Old 07-09-2012, 04:46 PM   #10
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT , Turbocharged
FF Reputation: 146 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
I dont agree , your weak poing is still going to be your rods and Pistons , I would go back with all stock on the rings , bearings , gaskets etc they work well and there cheaper , a better bearing wont do anything for you
My thoughts would be to spend another 1000.00 1300.00 and put in pistons and rods unless you just changing the one hole thats bad ?????
Customer Support
AIM: hpdyno
Email: tom@focus-power.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
