DURATEC Ti-VCT Performance (2012-2013) The place to chat about any Duratec 2.0L Ti-VCT engine performance, tuning and exhaust related upgrades.
#21 | ||||
FF Affiliate
Why are you not posting what your air fuel is doing on the graph ?
Focus-Power: Your #1 Source for Ford Focus Speed, Tuning & Performance! Customer Support AIM: hpdyno Email: tom@focus-power.com Phone: 704-249-3745 Site: focus-power.com Elder 1turbofocus |
#22 | ||||
Sonic Mk3 Crew #01
I try to balance that 'friend hooking up another friend' with the 'data obsessed send me every-possible-graph'. ..
HN Member #161 *155 hp / 143 lb ft (DCT)* Moderator for- DURATEC Ti-VCT Performance (2012-2013) ST Performance (2013) MK3 Focus ST Focus Sonic's MK3 Crew |
#23 | ||||
Sonic Mk3 Crew #01
So I just checked with him and he said that we didn't collect AFR. The next time we get on the dyno we will get a couple runs including AFR on my current setup, and also collect it with the addition of the newmission mod.
HN Member #161 *155 hp / 143 lb ft (DCT)* Moderator for- DURATEC Ti-VCT Performance (2012-2013) ST Performance (2013) MK3 Focus ST Focus Sonic's MK3 Crew Last edited by dyn085; 07-17-2012 at 04:28 PM. |
#24 | ||||
Sonic Mk3 Crew #01
Ok, quick update. I finally got a chance to fab up my scoop for the Newmission mod. It is curing up overnight and I will pull it off the mold for final fitment and paint tomorrow. I am meeting up with my buddy this weekend for some cosmetic work and to take some measurements, and while I'm on the lift we may roll it onto the dyno to run a few pulls and collect some more data. Previous pulls have been made without AFR, but future pulls will be collecting data on that as well.
If things fall through this weekend then it will probably occur next weekend.
#25 | ||||
Sonic Mk3 Crew #01
Quick update. Same numbers as the last pull despite being 8° hotter with twice the humidity. Standard airflow. Two more pulls with air directed at the scool to simulate real world driving.
Afr is not collecting for some reason. Trying to get it sorted out.
#26 | ||||
Sonic Mk3 Crew #01
Ok, finally got the graphs. Each one was sent separately (odd) but I'll post them nonetheless. He also sent the uncorrected, because that is what he and I use to evaluate, but for those that were interested the conditions were approximately 87 degrees, 30.02 hg, and 45% humidity.
![]() ![]() ![]() ![]() TQ comparo- ![]() HP comparo- ![]() The first two runs were done with the Newmission mod as the addition, fan blowing on the radiator. The last two runs were done with the fan aimed at the scoop to simulate being driven. While the power difference is negligible, there is a tiny gain in being driven (self-explanatory). Ultimately, the numbers are very much the same as without the Newmission mod. I don't feel that this is in any way a bad sign for the Newmission mod; I simply feel that I am currently exhaust limited by the stock set-up. Future tests, with a more open exhaust, will probably backtrack a step or so to see how the mod affects the car. Final note-We did try collecting AFR data, but the machine is either inop or has a loose wire. During the first three runs it wasn't collecting anything, then I accidentally bumped it while climbing out of the car and it began showing 14.7. This would have been good had that actually changed while doing the pull (which it never did
#27 | ||||
Sonic Mk3 Crew #01
First off, thank you Vluc for supplying this and I greatly appreciate your help and contribution in data collection.
For those not in the know I received a K&N Typhoon intake from forum member Vluc for some same-car dyno testing. I have been overly curious as to whether the homemade intakes would be comparable to the big-name manufacturers. My overall decision-it's kind of a draw. I'll explain why below, but here is a quick phone shot of the graphs from today. I will get clearer files later, but I wanted something to be able to post quickly. ![]() Sorry for the crappy pic, but it gives a decent idea of the numbers I was looking at and the condition differences between runs. Basically, the first two runs I did were on my current setup (drop-in, ram-ish, Newmission). That is represented by run file 2 in the pic. Run file 3 was from the last set of dyno runs, as I was unsure of whether my first two of the day were affected by heat soak (I had been driving most of the morning and his dyno is across town). Run file 4 was the last of two pulls with the Typhoon installed, because there was a considerable amount of time to cool down while I did the install. It is highlighted in red. The reason I called it a draw, despite the Typhoon clearly pulling more hp and tq, is due to the loss of power below 4200 rpm. Considering the fact that most people will be under that during their day-to-day use, the additional power down low is nice to have. I was a little disappointed in my setup after seeing that the Typhoon blew it away above that rpm range. I was convinced that I was at the point of being exhaust limited, but after seeing this information I know that I have a different type of limitation in my setup (most likely the MAF housing to throttle body connection). Anyways, that's the down-and-dirty. Feel free to discuss or ask questions and I will post the actual graphs after I receive them for a clearer picture.
#28 | ||||
So the typhoon actually loses power over stock below 4200,?
2012 Ford Focus SEL Hatchback K&N Typhoon Intake | 3d Carbon Wing HN #167 |
#29 | ||||
Sonic Mk3 Crew #01
Not when compared to stock, but when compared to my current setup of K&N drop-in, snorkel delete, ram-ish mod, and Newmission mod. There is about the same amount of loss below 3500-4200 rpm as there is gain above 4200 rpm.
#30 | ||||
Interesting. Any ideas why as far as a design standpoint?
| Thread Tools | |
| Display Modes | |
