At a loss... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-06-2012, 08:56 PM   #1
_AdriaN_
Fan#: 64817
What I Drive: 00 Focus SE
FF Reputation: 1 _AdriaN_ Good Standing Member
At a loss...
I'm at wits end trying to figure out what is the matter with my Foci. Lately it has been running VERY rough at lower speeds.
It's a 2000 SE w/ 2.0 SPI AUTO.
Symptoms
It spits and sputters then it will "catch" and take off. When this happens you can smell a bit of gas in the cabin. Once it takes off, the miss isn't there (much). You can cruise along at 80-90 MPH no problems. The issue is at lower speeds no matter the engine temperature.
Stuff recently done...
  1. Hollowed out CAT... Was glowing cherry red EDIT: Cannot afford a new one right now.
  2. New plugs
  3. New wires
  4. New fuel filter
  5. Used ignition coil
Side notes
OBD codes P0102 (MAF circuit low) and P0302 (Cylinder 2 Misfire) *On both coils
Oil on Cylinder 2 plug, rest look brand new
I've checked for vacuum leaks, can't find any
I've checked the wiring to the coil
Spark tested cylinder 2 and it has good spark
Have not compression tested but I'm not sure if it's needed??? It also seems unplugging the MAF makes it run a little different and sometimes kills the engine.
Also, I've pulled power to each injector as its running and 1,3,4 kill the engine however, 2 doesn't.
Any ideas?
_AdriaN_ is offline
Old 07-06-2012, 10:03 PM   #2
Indy'sexclusiveZx3
Fan#: 65419
What I Drive: 2013 tuxedo black st
FF Reputation: 7 Indy'sexclusiveZx3 Good Standing Member
Bad injector Or going bad simple fix you already had the answer
Parts for sale check out my thread, got a new st need to sale old parts
Indy'sexclusiveZx3 is offline
Old 07-06-2012, 10:44 PM   #3
_AdriaN_
Fan#: 64817
That's what I was thinking... It affected the performance but not like the other 3.
Is the oil on the plug a sign of anything?
_AdriaN_ is offline
Old 07-07-2012, 12:41 AM   #4
Indy'sexclusiveZx3
Fan#: 65419
Maybe just a leaky valve cover gasket that would be my guess
Old 07-07-2012, 02:35 AM   #5
follown
Fan#: 83711
What I Drive: 2005 black zx4, 2004 tahoe z-71
FF Reputation: 1 follown Good Standing Member
Yes oil in the plug is due to bad valve cover gasket. I replaced mine a few months ago because it was leaking outside and once I started I found oil in 2 plugs.
follown is offline
Old 07-07-2012, 08:30 AM   #6
_AdriaN_
Fan#: 64817
Thanks guys, I will try to get around to fixing these soon and report back.
To clarify, the oil is on the part spark plug down by the electrode(inside the block) not the outside. I took the valve cover off and the gasket didn't look too good as it was grooved in spots which I thought was weird.
_AdriaN_ is offline
Old 07-07-2012, 04:43 PM   #7
_AdriaN_
Fan#: 64817
Swapped injectors around on 2 & 3 and still throwing a Cylinder 2 misfire. I'm going to compression test it when I get a chance, nobody to help today.
I'm hoping it's not something internal but if the compression test shows #2 has bad compression, what's the possible culprits?
_AdriaN_ is offline
Old 07-09-2012, 03:30 PM   #8
jesusamares
jesusamares's Avatar
Fan#: 64713
What I Drive: 2000 Rainforest SE SOHC SPI
FF Reputation: 1 jesusamares Good Standing Member
Have you checked your EGR gasket it, my old 2.0 had the same issue I swear I changed everything on that car and the day I changed out the EGR gasket the car started to work again.
!Stock_2000_Focus!---[S.E.-S.O.H.C.-S.P.I.]
jesusamares is offline
Old 07-10-2012, 08:17 PM   #9
_AdriaN_
Fan#: 64817
I will look into this. I have not checked the EGR stuff yet.
_AdriaN_ is offline
Old 07-12-2012, 12:28 PM   #10
ImmortalMort
Fan#: 96639
What I Drive: 2000 Black SE Sedan SPI
FF Reputation: 1 ImmortalMort Good Standing Member
how does your pcv tube look? off the valve cover into the intake, just below the throttle body. Mine was causing some driveability issues, bad idle, ect. I replaced the whole tube assembly (not the valve, however) and my SPI has been working great so far.. not the answer your looking for but a possible solution to future drivability isues
Its not turbo lag... Its foreplay.
ImmortalMort is offline
