#1 | ||||
LED Switchback Wiring Help
I looked for a walk-through and could not find one. I don't have much wiring expirience.
From what I understand you need to tap into the wire that makes the turn signal blink, through the resistor, and then tap in to the ground to make a loop.Which wires are which? There is a yellow w/ purple stripe, purple w/ white stripe, and a black. Also, what should I use to "tap into" the wires? If someone has a picture it would be a really big help. |
Remove Advertisements |
Fan#: 1
#2 | ||||
2011 Sterling Gray SES SES #025/ Sedan Revolution #221 |
#3 | ||||
There is another thread about this too but the wire colors he supplied were different than on my car.
2008 Vista Blue SES Coupe 5spd FRPP Zx3B Suspension 5000K D2S Retrofit 125,000+ miles and still on factory brakes and clutch! Rep Points dont add themselves |
#4 | ||||
Thanks for the diagram. That is pretty much what I thought. This is what they recommended to me at the auto parts store: ![]() It does't look that waterproof, but what ever. Now all I need to know which wire is which. Also, where did you guys mount the resistors? I heard they can get pretty hot.
#5 | ||||
i bought and used them but they didnt cut through the insulation. i would pull my light for you but they are such a pita. do you have a dvom? would be the quickest way
#6 | ||||
The turn signal and ground wire are the two outer wire on the plug. the middle wire is for the parking light.
Team Duratec #23 Official SES Registry #49 Tom's Tune, DDMTUNING 5000k HI/LO & FOGS, Switchback LED turn signals, AR103's gapped .54, FSWerks CAI. more to come |
#7 | ||||
#8 | ||||
Random question kind of related to this, if you had the led tails would you need the resistors at all? Either in the front or back or both? Hope the op doesn't mind me asking in his thread
#9 | ||||
i have led tails and no resistors up front:) i have no hyper flash either, i contacted v-leds (where i bought mine from) and they told me that in theory my outcome was possible since the tails come prewired with resistors already. people kinda bugged out on me here and said that it wasn't possible and it would burn my bulbs out faster, but they are easy enough to replace if they ever go bad:) so heed their warnings and proceed as you see fit!
#10 | ||||
good to know. thats kind of what i was thinking but i would still like some others to chime in. how long have you been running it like that?
| Thread Tools | |
| Display Modes | |
