Go Back   Focus Fanatics > Model Specific Discussions > MK1 Focus
Old 07-06-2012, 12:03 PM   #1
BowerR64
BowerR64's Avatar
Fan#: 78699
What I Drive: 2007 DX3 SE
FF Reputation: 12 BowerR64 Great Standing Member
pinch weld jack or floor jack adaptor?
Anyone have an insert or a floor jack for jacking the car up at the pinch welds like that junk emergency jack that comes with the car?
Im tearing up my pinch welds when i jack up my car ide like to get something to insert into the floor jack or something so when i jack up the car i dont bend them up any more then they are.
I know there are other places better but some times this spot is the easiest to get to.
DX3?.. huh?.. well ZX3 = Zetec the 05-07 has a Duratec so DX3
BowerR64 is offline
Fan#: 1
Old 07-06-2012, 12:29 PM   #2
Nickgt40
Wheel King, Bow Down
Nickgt40's Avatar
Fan#: 40924
What I Drive: 01 Black ZX3, 09 FSWerks SEMA Coupe
FF Reputation: 16 Nickgt40 Great Standing Member
Does your floor jack have any kind of rubber pad on it? If not, that will help quite a bit.
Feb 2011 Ride of the Month ~ 2011 Hatch Nation Hatch of the Year ~ 2011 Focus Fanatics Ride of the Year!
Hatch Nation #2
Nickgt40 is offline
Old 07-06-2012, 01:19 PM   #3
speedracer ZX3
Fan#: 85172
What I Drive: 2013 Performance Blue ST & 2003 SVT
FF Reputation: 2 speedracer ZX3 Good Standing Member
Buy-Sell-Trade Rating: (14)
harbor freight sells rubber jack stand covers.
Originally Posted by ZX4STDoug
I hugged two trees today to make up for running catless.
Give Rep If You've Been Helped
speedracer ZX3 is offline
Old 07-06-2012, 05:48 PM   #4
BowerR64
BowerR64's Avatar
Fan#: 78699
i might try a block of wood with a slot cut in it. My brothers car needs the same type of jack we talked about using bolts threw the block so it doesnt split.
We also need the jack to raise up a little more as well so we can slide the jack stands under the car in different spots.
Both our cars sit so low we need to jack them WAY up just to get the stand under it in the safe spots.
Maybe using a thicker block will also help in lifting it up a little more. W now use a 3/4" section of scrap MDF under the wheels of the jack to raise it a little more but that begins to be a pain at times.
Massive or FSworks needs to make an adaptor or something for the pinch welds other then upgrade parts tools that help make things easier as well to change the upgraded parts.
BowerR64 is offline
Old 07-07-2012, 01:28 AM   #5
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
What I Drive: 2007 TorD-Red ZX5 SES
FF Reputation: 77 S0C0nFused Excellent Standing Member
I can tell you how to make what you want. But personally, I found the aformentioned pad works very well.
P.S. I also cleaned and epoxied the pinch weld areas quite some time ago as I think I was having the very problem your describing.
Steeda SRI w/CAI intake. Trubendz SS 2.5" . FR Susp/Struts. Tune by Tom (FocusPower). Rota Grids. SAP rear spoiler. Custom front air dam, rocker panel bits and Rear valance.
Last of the Hatches #28
S0C0nFused is offline
Old 07-07-2012, 01:53 AM   #6
Neptune15
Neptune15's Avatar
Fan#: 91691
What I Drive: '07 ZX3
FF Reputation: 1 Neptune15 Good Standing Member
Mine are all wrinkled up as well.
I think the problems lies with the floor jack is supporting the welds at two very small points (the edges of the disc), so the weight of the car is concentrated on a very small surface area. I've been using a thick work glove on top of the jack, and it seems to be working fine.
Then there's always the hockey puck idea.
Neptune15 is offline
Old 07-08-2012, 01:57 AM   #7
bringler26
Brokus
bringler26's Avatar
Fan#: 59705
What I Drive: 03 ZX3 & 07 Impreza 2.5i
FF Reputation: 26 bringler26 Great Standing Member
I never use the pinch welds to jack the car up. I use the rear subframe as on point and there are two decent spots just behind the pinch welds that can be used to for the front.
2003 Ford Focus ZX3(Brokus) - old and busted
2007 Subaru Impreza 2.5i - current DD
bringler26 is offline
Old 07-08-2012, 02:55 AM   #8
S0C0nFused
S0C0nFused's Avatar
Fan#: 39405
You should always jack on the pinch welds (unless your lifting via the subframe). Think of it this way. When you use the pinch welds, your lifting all segments that come together at that point together. If you lift anywhere else, your depending on the weld. The pinch weld by it shape also forms an upside down 'L' shape. If you lift on the horizontal (floor pan or rocker), you risk deforming the shape as that is the weakest segment. All one really needs to do is to bring all the separate elements that join at the point to a 'solid'. This is most easily attained by simply adding some additional "L" channel along the pinch weld so that the individual segments cannot separate.
Old 07-08-2012, 04:21 AM   #9
BowerR64
BowerR64's Avatar
Fan#: 78699
Well when i use jack stands i dont put them on the pinch welds. Just replacing wheels or working on the suspension. Is when i use ht epinch weld to jack the car up with.
Alot of times i dont want to jack up the whole car i want as much of the car to stay on the ground as i can so it doesnt slip off the jack.
They seem easy to get to without getting under the car to put the jack in a better spot.
It says in the instructions on changing the tire to jack it up in that spot so i figured that was the best place to do it.
BowerR64 is offline
Old 07-08-2012, 01:30 PM   #10
bringler26
Brokus
bringler26's Avatar
Fan#: 59705
Never deformed the floor pan( at least not due to the floor jack) I put my jack stands on the pinch welds though.
