Which boost controller? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-06-2012, 09:27 AM   #1
sporadic
sporadic's Avatar
Fan#: 12724
What I Drive: 06 Sonic Blue ZX5 SES turbo
Points 12,857, Level 74
Points: 12,857, Level: 74 Points: 12,857, Level: 74 Points: 12,857, Level: 74
Level Up 2% Completed
Forum Activity 4%
FF Reputation: 61 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Question Which boost controller?
Which boost controller do you use, and which would you avoid? Up to now I have had an internal wastegate that I adjusted with a turnbuckle. Now I have the GT2871r with a 38mm Tial external wastegate and need manual adjustment.
Should I go manual or electronic? Let's assume cost is not a concern, but I obviously don't want to spend more than necessary.
I have the tools and skill to make one myself, but I mainly don't want to play guessing games and spend 20 hours finding the right tension spring, dialing in the boost, etc.
I was looking at this: TurboSmart Dual Stage Mechanical Boost Controller
I don't daily drive this car, and I won't be adjusting the boost frequently after I set it. I will adjust to to around 10-12psi for now, and then as high as 20-25psi after I build the spare motor.
My thought with the dual stage is I could run 12-15psi around town and have a setting for 25psi at the track, which I could flip (manually or automatically) after in 2nd gear.
Thanks all
2006 sonic blue zx5 GT2871r turbo.
sporadic is online now
Old 07-06-2012, 10:13 AM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,834, Level 100
Points: 51,834, Level: 100 Points: 51,834, Level: 100 Points: 51,834, Level: 100
Level Up 0% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
Buy-Sell-Trade Rating: (28)
I am not a fan at all of the turbosmart products , if thats your choise there is a killer deal on a new on on ebay for 119.00 right now in blue
I like the very hard to find Greddy type S but NOT the specII type S
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 07-06-2012, 10:16 AM   #3
Roushturboedzx3
I Fab Too Much
Roushturboedzx3's Avatar
Fan#: 42814
What I Drive: 2002 Liquid Gray ZX3
Points 14,483, Level 78
Points: 14,483, Level: 78 Points: 14,483, Level: 78 Points: 14,483, Level: 78
Level Up 9% Completed
FF Reputation: 20 Roushturboedzx3 Great Standing Member
Buy-Sell-Trade Rating: (18)
If money wasn't a option i would figure out how to wire up a AMS-1000 unit, but its not realistic lol. I like my greedy type S i put the hi/low boost on a button so in second gear i run around 12psi to hook then hit the button in 3rd-4th are 18-19psi. simple to setup and cheap boost controller. I do like the HKS EVC also.
New: 2012 Mustang GT premium
SOLD:RACE GAS 602whp 501tq Pump Gas SAE 454whp
Garrett GT3582r, Topmount, built motor, Ported head,Tuned by Fernando@RacingPartsSolution
I may not be the baddest, but the baddest dont Fu** with me
Roushturboedzx3 is offline
Old 07-06-2012, 10:17 AM   #4
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 4%
Yeah I saw that deal.
Do you not like them because they don't hold boost properly or spike?
Old 07-06-2012, 10:23 AM   #5
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 4%
I hear an echo, lol. Thanks, looking into those. A guy on Steel City Stangs also recommended the AMS-1000 if price wasn't a concern. I think that might be a bit extreme for my purposes.
Old 07-06-2012, 01:37 PM   #6
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 4%
I went with a TurboSmart dual stage mechanical. I will let everyone know how it goes.
Old 07-06-2012, 03:51 PM   #7
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 32%
std mechanical would of been fine
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 07-06-2012, 03:54 PM   #8
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 4%
I wanted the dual stage for the track. If the manual switch is inconvenient while "in the moment" then I'll rig up a timed switch so it will switch to full boost after x seconds.
Old 07-11-2012, 09:56 AM   #9
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 4%
This is the boost controller I went with:
I bought it open-box from ebay, so I wanted to make certain it wasn't busted up so I took it apart. This is what is inside. This one is indeed new.
For those wondering how this works, it is a bleed-off type boost controller. That means it will bleed off a preset amount of air going to the wastegate.
This controller has two stages of bleed-off, controlled by a switch. The only electronic part in this system is the solenoid that opens the path to the second bleed dial. It appears it would work fine as a single-stage without any 12v signal.
The dials are reverse threaded. Turning counter-clockwise closes the bleeder valves. Turning clockwise opens the bleeder valves to increase boost.
I have not installed this yet. I ordered a vacuum block and it won't be here until later this week. I'm going to clean up some vac/boost lines so my boost gauge, boost controller and bov all get the signal from the same vac block.
I'm going backpacking/flyfishing for a few days next week, so don't expect any updates until after.
Old 07-11-2012, 04:25 PM   #10
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
I wish I had the greddy type S
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
